Discuss
Oven keeps switching off during pre-heat
 in
Hello, all, and thanks in advance for your advice. I have an ancient Roper wall/built-in oven that came with the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven keeps switching off during pre-heat
  #1 (permalink)
Old 04-20-2018, 09:23 AM
Junior Member
Nikko963 is on a distinguished road
Default Oven keeps switching off during pre-heat
Model Number: 30B5B1A   Brand: Roper   Age: More than 10 years
I have an ancient Roper wall/built-in oven that came with the house we recently bought. It was working great and had better things to do with the money, so have kept it. Now, however, it is giving me grief.
After switching to bake and setting the temp., the digital display will show the oven heat light on and the starting temp (100). Over the next 10-15 seconds, two quiet but audible clicks can be heard, and then the oven witches off--the oven 'on' light goes off and the temperature display disappears. The clock display remains visible, so I know the panel is getting power.
I tried both the Bake and Broil settings, but neither work: the elements warm up a bit but never glow hot.
Now that I think of it, over the last couple of weeks leading up to this, I have twice returned to the oven that I had set to pre-heat and found it off. I had chalked it up to absent-mindedness ("Did I switch it on?"), but maybe the current state is simply the end of a deterioration that began earlier. (In those cases, I simply turned the oven on and it seemed to behave normally.)
As mentioned, this is an ancient oven; you won't find the model number anywhere nor any parts, so unless this involves a generic part, it will be time to break open the piggy bank.
- Nikko
Related Models
Frigidaire 30CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CGMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN3 Tap(v3) / Gas Range
Frigidaire 30DEMBWDD1 Tap(v1) / Electric Range
Frigidaire 30DEMBWDD1-23 Tap(v2) / Electric Range
Frigidaire 30DEMDWED0 Tap(v1) / Electric Range
Frigidaire 30DEMDWED0-23 Tap(v2) / Electric Range
Frigidaire 30DGMBWDN0 Tap(v1) / Gas Range
Frigidaire 30DGMCWAN4 Tap(v1) / Gas Range
Frigidaire 30DPCDWGN-23-01 Tap(v2) / Gas Range
Frigidaire 30DPCDWGN1 Tap(v1) / Gas Range
Frigidaire 30DPMBWAN6 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP4 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP5 Tap(v2) / Gas Range
Frigidaire 30DPMBWAP6 Tap(v3) / Gas Range
Frigidaire 30DPMCWAN5 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWEN2 Tap(v3) / Gas Range
Frigidaire 30DPMDWEN2-23 Tap(v4) / Gas Range
Frigidaire 30DPMDWGN01-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWGN1 Tap(v1) / Gas Range
Frigidaire 30IGCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN6 Tap(v2) / Gas Range
Frigidaire 30IPCDWAN7 Tap(v1) / Gas Range
Frigidaire 30KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 30KEMAWAD5 Tap(v1) / Electric Range
Frigidaire 30KGMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KGMAWAN3-23 Tap(v2) / Gas Range
Frigidaire 30KGMAWAN4 Tap(v3) / Gas Range
Frigidaire 30KGMAWAN4-23 Tap(v4) / Gas Range
Frigidaire 30KPMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KPMAWAN4 Tap(v2) / Gas Range
Frigidaire 30KPMAWAN5 Tap(v3) / Gas Range
Frigidaire 30KPMAWHN1 Tap(v1) / Gas Range
Frigidaire 30KPMAWHN2 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0-23 Tap(v2) / Gas Range
Frigidaire 30PPSKWDN0-32 Tap(v3) / Gas Range
Frigidaire 30TESKWED-04-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-02 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-03 Tap(v4) / Electric Range
Frigidaire 30TESKWED1 Tap(v1) / Electric Range
Frigidaire 30TESKWED2 Tap(v1) / Electric Range
Frigidaire 30TESKWED3 Tap(v3) / Electric Range
Frigidaire 30TESKWED4 Tap(v1) / Electric Range
Hoover 31
Frigidaire 31-1049-00-01 Tap(v1) / Electric Range
Frigidaire 31-1049-00-02 Tap(v3) / Electric Range
Frigidaire 31-1049-00-03 Tap(v1) / Electric Range
Frigidaire 31-1049-00-04 Tap(v1) / Electric Range
Frigidaire 31-1049-00-05 Tap(v1) / Electric Range
Frigidaire 31-1049-00-06 Tap(v1) / Electric Range
Frigidaire 31-1049-23-01 Tap(v2) / Electric Range
Frigidaire 31-1049-23-02 Tap(v4) / Electric Range
Frigidaire 31-1049-23-03 Tap(v2) / Electric Range
Frigidaire 31-1049-23-04 Tap(v2) / Electric Range
Frigidaire 31-1049-23-05 Tap(v2) / Electric Range
Frigidaire 31-1049-23-06 Tap(v2) / Electric Range
Frigidaire 31-2207-00-01 Tap(v1) / Electric Range
Frigidaire 31-2207-00-02 Tap(v4) / Electric Range
Frigidaire 31-2207-00-03 Tap(v7) / Electric Range
Frigidaire 31-2207-23-01 Tap(v2) / Electric Range
Frigidaire 31-2207-23-02 Tap(v5) / Electric Range
Frigidaire 31-2207-23-03 Tap(v8) / Electric Range
Frigidaire 31-2207-66-03 Tap(v9) / Electric Range
Frigidaire 31-2208-00-01 Tap(v1) / Electric Range
Frigidaire 31-2208-00-02 Tap(v4) / Electric Range
Frigidaire 31-2208-00-03 Tap(v7) / Electric Range
Frigidaire 31-2208-23-01 Tap(v2) / Electric Range
Frigidaire 31-2208-23-02 Tap(v5) / Electric Range
Frigidaire 31-2208-23-03 Tap(v8) / Electric Range
Frigidaire 31-2208-66-01 Tap(v3) / Electric Range
Frigidaire 31-2208-66-02 Tap(v6) / Electric Range
Frigidaire 31-2208-66-03 Tap(v9) / Electric Range
Frigidaire 31-2232-00-01 Tap(v1) / Electric Range
Frigidaire 31-2232-00-02 Tap(v1) / Electric Range
Frigidaire 31-2232-00-03 Tap(v1) / Electric Range
Frigidaire 31-2232-23-01 Tap(v2) / Electric Range
Frigidaire 31-2232-23-02 Tap(v2) / Electric Range
Frigidaire 31-2232-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-00-01 Tap(v1) / Electric Range
Frigidaire 31-2237-00-02 Tap(v4) / Electric Range
Frigidaire 31-2237-00-03 Tap(v1) / Electric Range
Frigidaire 31-2237-23-01 Tap(v2) / Electric Range
Frigidaire 31-2237-23-02 Tap(v5) / Electric Range
Frigidaire 31-2237-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-66-01 Tap(v3) / Electric Range
Frigidaire 31-2237-66-02 Tap(v6) / Electric Range
Frigidaire 31-2237-66-03 Tap(v3) / Electric Range
Frigidaire 31-2238-00-05 Tap(v1) / Electric Range
Frigidaire 31-2238-00-06 Tap(v4) / Electric Range
Frigidaire 31-2238-23-05 Tap(v2) / Electric Range
Frigidaire 31-2238-23-06 Tap(v5) / Electric Range
Frigidaire 31-2238-66-05 Tap(v3) / Electric Range
Frigidaire 31-2238-66-06 Tap(v6) / Electric Range
Frigidaire 31-2239-00-01 Tap(v1) / Electric Range
Frigidaire 31-2239-00-02 Tap(v1) / Electric Range
Frigidaire 31-2239-00-03 Tap(v3) / Electric Range
Frigidaire 31-2239-00-04 Tap(v1) / Electric Range
Frigidaire 31-2239-00-05 Tap(v1) / Electric Range
Frigidaire 31-2239-00-06 Tap(v1) / Electric Range
Frigidaire 31-2239-23-01 Tap(v2) / Electric Range
Frigidaire 31-2239-23-02 Tap(v2) / Electric Range
Frigidaire 31-2239-23-03 Tap(v4) / Electric Range
Frigidaire 31-2239-23-04 Tap(v2) / Electric Range
Frigidaire 31-2239-23-05 Tap(v2) / Electric Range
Frigidaire 31-2239-23-06 Tap(v2) / Electric Range
Frigidaire 31-2339-00-01 Tap(v1) / Electric Range
Frigidaire 31-2339-23-01 Tap(v2) / Electric Range
Frigidaire 31-2377-00-01 Tap(v1) / Range
Frigidaire 31-2377-23-01 Tap(v2) / Range
Frigidaire 31-2442-00-01 Tap(v1) / Electric Range
Frigidaire 31-2442-00-02 Tap(v1) / Electric Range
Frigidaire 31-2442-23-01 Tap(v2) / Electric Range
Frigidaire 31-2442-23-02 Tap(v2) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Switching Burner Leads Runninrep Oven Repair (including Ranges and Cooktops) 0 10-19-2016 12:19 PM
switching from lp back to natural gas bud4791 Oven Repair (including Ranges and Cooktops) 0 02-21-2014 03:26 PM
switching regulator to LP gas ??? ANiforos Oven Repair (including Ranges and Cooktops) 0 11-07-2013 01:56 PM
switching from propane to natural gas Tknight85 Oven Repair (including Ranges and Cooktops) 0 12-21-2011 11:04 AM
Oven switching from bake to broil (by itself) The Hammerbeck 5 Oven Repair (including Ranges and Cooktops) 3 04-25-2009 07:27 PM
