Discuss
Replaced electronic control panel, still takes lon time to heat up
 in
The cancel button stopped working, and it wouldnt heat up past about 200-250 degrees. I just replaced the electronic control
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replaced electronic control panel, still takes lon time to heat up
  #1 (permalink)
Old 04-07-2018, 06:46 PM
Junior Member
Tomandsu is on a distinguished road
Question Replaced electronic control panel, still takes lon time to heat up
Model Number: Mes5875ban   Brand: Maytag   Age: More than 10 years
The cancel button stopped working, and it wouldnt heat up past about 200-250 degrees. I just replaced the electronic control panel: cancel button works now and oven heated up but took about 30min to get to 350degrees, about 30min to get to 400.
Any suggestions on something else that could be going on, causing it to take so long to heat up?
I checked broil/top burner, and that heated up very quickly. Not sure what else I should test...or if this is just life with 11 yr old electric oven?
Related Models
Maytag MES5875BAN RANGE- S/I STD ELE
Maytag MES5875BAN20 30" Slide-In Electric Range
Maytag MES5875BAS RANGE- S/I STD ELE
Maytag MES5875BAS20 30" Slide-In Electric Range
Maytag MES5875BCB RANGE- F/S STD ELE
Maytag MES5875BCB20 30" Slide-In Electric Range
Maytag MES5875BCF RANGE- F/S STD ELE
Maytag MES5875BCF20 30" Slide-In Electric Range
Maytag MES5875BCS RANGE- F/S STD ELE
Maytag MES5875BCS20 30" Slide-In Electric Range
Maytag MES5875BCW RANGE- F/S STD ELE
Maytag MES5875BCW20 30" Slide-In Electric Range
Maytag MET3800TW0 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET3800TW1 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET3800TW2 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET8665XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8775XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MEV41F-10P MWAVE- CNTRTP / STAND ALONE
Maytag MEW5527BAB WALLOVEN- S/C ELE
Maytag MEW5527BAW WALLOVEN- S/C ELE
Maytag MEW5527DDB WALLOVEN- S/C ELE
Maytag MEW5527DDB16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDS10 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDW WALLOVEN- S/C ELE
Maytag MEW5527DDW16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5530AAB WALLOVEN- S/C ELE
Maytag MEW5530AAW WALLOVEN- S/C ELE
Maytag MEW5530ACB WALLOVEN- S/C ELE
Maytag MEW5530ACW WALLOVEN- S/C ELE
Maytag MEW5530BAB WALLOVEN- S/C ELE
Maytag MEW5530BAW WALLOVEN- S/C ELE
Maytag MEW5530BCB WALLOVEN- S/C ELE
Maytag MEW5530BCW WALLOVEN- S/C ELE
Maytag MEW5530DDB WALLOVEN- S/C ELE
Maytag MEW5530DDB17 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDS10 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDW WALLOVEN- S/C ELE
Maytag MEW5530DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5627BAB WALLOVEN- S/C ELE
Maytag MEW5627BAW WALLOVEN- S/C ELE
Maytag MEW5627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDB16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5627DDS10 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEA
Maytag MEW5627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDW16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630BAB WALLOVEN- S/C ELE
Maytag MEW5630BAW WALLOVEN- S/C ELE
Maytag MEW5630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDB17 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDS10 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDW18 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6527BAB WALLOVEN- S/C ELE
Maytag MEW6527BAC WALLOVEN- S/C ELE
Maytag MEW6527BAQ WALLOVEN- S/C ELE
Maytag MEW6527BAS WALLOVEN- S/C ELE
Maytag MEW6527BAW WALLOVEN- S/C ELE
Maytag MEW6527CAS WALLOVEN- S/C ELE
Maytag MEW6527DDB WALLOVEN- S/C ELE
Maytag MEW6527DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDQ WALLOVEN- S/C ELE
Maytag MEW6527DDS WALLOVEN- S/C ELE
Maytag MEW6527DDS18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDW WALLOVEN- S/C ELE
Maytag MEW6527DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6530AAB WALLOVEN- S/C ELE
Maytag MEW6530AAW WALLOVEN- S/C ELE
Maytag MEW6530ACB WALLOVEN- S/C ELE
Maytag MEW6530ACW WALLOVEN- S/C ELE
Maytag MEW6530BAB WALLOVEN- S/C ELE
Maytag MEW6530BAC WALLOVEN- S/C ELE
Maytag MEW6530BAQ WALLOVEN- S/C ELE
Maytag MEW6530BAS WALLOVEN- S/C ELE
Maytag MEW6530BAW WALLOVEN- S/C ELE
Maytag MEW6530BCB WALLOVEN- S/C ELE
Maytag MEW6530BCW WALLOVEN- S/C ELE
Maytag MEW6530CAS WALLOVEN- S/C ELE
Maytag MEW6530DDB WALLOVEN- S/C ELE
Maytag MEW6530DDB19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDQ WALLOVEN- S/C ELE
Maytag MEW6530DDS WALLOVEN- S/C ELE
Maytag MEW6530DDS19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDW WALLOVEN- S/C ELE
Maytag MEW6530DDW20 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6627BAB WALLOVEN- S/C ELE
Maytag MEW6627BAC WALLOVEN- S/C ELE
Maytag MEW6627BAQ WALLOVEN- S/C ELE
Maytag MEW6627BAS WALLOVEN- S/C ELE
Maytag MEW6627BAW WALLOVEN- S/C ELE
Maytag MEW6627CAS WALLOVEN- S/C ELE
Maytag MEW6627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDB18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDW18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630BAB WALLOVEN- S/C ELE
Maytag MEW6630BAC WALLOVEN- S/C ELE
Maytag MEW6630BAQ WALLOVEN- S/C ELE
Maytag MEW6630BAS WALLOVEN- S/C ELE
Maytag MEW6630BAW WALLOVEN- S/C ELE
Maytag MEW6630CAS WALLOVEN- S/C ELE
Maytag MEW6630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDB19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDW20 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW7530WDB01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7530WDS01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Oven Wont Heat to pre heat or takes a long time rmcgove Oven Repair (including Ranges and Cooktops) 0 04-23-2014 03:05 PM
Kitchenaid Dishwasher Replaced electronic panel, still doesn't work wdt8m Dishwasher Repair 0 05-22-2012 06:12 AM
Replaced Control Panel/Icemaker, Temp not Working on electronic display, not cooling! Mary Roberge Refrigerator & Freezer Repair 0 07-02-2011 09:13 AM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
Pre-heat takes long time if at all samblane Oven Repair (including Ranges and Cooktops) 0 12-10-2009 06:05 PM
