Discuss
Oven temperature problem
 in
I am having a problem with the oven temperature. Lots of times it is between 35 and 50 degrees under
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temperature problem
  #1 (permalink)
Old 03-23-2018, 12:30 AM
Junior Member
leonthepc is on a distinguished road
Default Oven temperature problem
Model Number: JGBP28BEA6WH   Brand: GE   Age: More than 10 years
I am having a problem with the oven temperature. Lots of times it is between 35 and 50 degrees under the desired temperature. The Wiring Diagram in the back of the oven says that the flames at the bottom of the oven should be 1 inch long. I opened the bottom of the oven and it is hard to tell because they are not shooting out like the broiler flames do. The flames for the oven are curling up around the pipe.
The Wiring Diagram also says that I can perform and oven temperature calibration by pressing both the Hour up and down buttons. It says that it should say 00. For some reason mine said 35.
I already replaced the thermostat in the oven and it didn't help.
Related Models
General Electric JGBP28BEA6WH Gas range
General Electric JGBP28BEA7WH Gas range
General Electric JGBP28BEH1CT Gas range
General Electric JGBP28BEH1WH Gas range
General Electric JGBP28BEH2CT Gas range
General Electric JGBP28BEH2WH Gas range
General Electric JGBP28BEH3CT Gas range
General Electric JGBP28BEH3WH Gas range
General Electric JGBP28BEJ1CT Gas range
General Electric JGBP28BEJ1WH Gas range
General Electric JGBP28BEJ2CT Gas range
General Electric JGBP28BEJ2WH Gas range
General Electric JGBP28BEJ3CT Gas range
General Electric JGBP28BEJ3WH Gas range
General Electric JGBP28BEK1CT Gas range
General Electric JGBP28BEK1WH Gas range
General Electric JGBP28BEK2CT Gas range
General Electric JGBP28BEK2WH Gas range
General Electric JGBP28BEK3CT Gas range
General Electric JGBP28BEK3WH Gas range
General Electric JGBP28BEL1CT Gas range
General Electric JGBP28BEL1WH Gas range
General Electric JGBP28BEL2CT Gas range
General Electric JGBP28BEL2WH Gas range
General Electric JGBP28BEL3CT GAS RANGE
General Electric JGBP28BEL3WH GAS RANGE
General Electric JGBP28BEL4CT GAS RANGE
General Electric JGBP28BEL4WH GAS RANGE
General Electric JGBP28BEW1AD Gas range
General Electric JGBP28BEW1WH GAS RANGE
General Electric JGBP28CEM1WW GAS RANGE
General Electric JGBP28CEM2WW GAS RANGE
General Electric JGBP28CEM3WW GAS RANGE
General Electric JGBP28CEM4WW GAS RANGE
General Electric JGBP28CEM5WW GAS RANGE
General Electric JGBP28CEM6WW GAS RANGE
General Electric JGBP28DED1CT Gas range
General Electric JGBP28DED1WH Gas range
General Electric JGBP28DED2CT Gas range
General Electric JGBP28DED2WH Gas range
General Electric JGBP28DEH1CT Gas range
General Electric JGBP28DEH1WH Gas range
General Electric JGBP28DEH2CT Gas range
General Electric JGBP28DEH2WH Gas range
General Electric JGBP28DEH3CT Gas range
General Electric JGBP28DEH3WH Gas range
General Electric JGBP28DEJ1CT Gas range
General Electric JGBP28DEJ1WH Gas range
General Electric JGBP28DEJ2CT Gas range
General Electric JGBP28DEJ2WH Gas range
General Electric JGBP28DEJ3CT Gas range
General Electric JGBP28DEJ3WH Gas range
General Electric JGBP28DEL1CT Gas range
General Electric JGBP28DEL1WH Gas range
General Electric JGBP28DEL2CT Gas range
General Electric JGBP28DEL2WH Gas range
General Electric JGBP28DEL3CT GAS RANGE
General Electric JGBP28DEL3WH GAS RANGE
General Electric JGBP28DEL4CT GAS RANGE
General Electric JGBP28DEL4WH GAS RANGE
General Electric JGBP28DEM1BB GAS RANGE
General Electric JGBP28DEM1WW GAS RANGE
General Electric JGBP28DEM2BB GAS RANGE
General Electric JGBP28DEM2WW GAS RANGE
General Electric JGBP28DEM3BB GAS RANGE
General Electric JGBP28DEM3WW GAS RANGE
General Electric JGBP28DEM4BB GAS RANGE
General Electric JGBP28DEM4WW GAS RANGE
General Electric JGBP28DEM5BB GAS RANGE
General Electric JGBP28DEM5WW GAS RANGE
General Electric JGBP28DEM6BB GAS RANGE
General Electric JGBP28DEM6WW GAS RANGE
General Electric JGBP28DEM7BB GAS RANGE
General Electric JGBP28DEM7WW GAS RANGE
General Electric JGBP28DEM8BB GAS RANGE
General Electric JGBP28DEM8WW GAS RANGE
General Electric JGBP28DEM9BB GAS RANGE
General Electric JGBP28DEM9WW GAS RANGE
General Electric JGBP28DET1BB GAS RANGE
General Electric JGBP28DET1WW GAS RANGE
General Electric JGBP28EEH1BB Gas range
General Electric JGBP28EEJ1BB Gas range
General Electric JGBP28EEJ2BB Gas range
General Electric JGBP28EEJ3BB Gas range
General Electric JGBP28EEK1BB Gas range
General Electric JGBP28EEK2BB Gas range
General Electric JGBP28EEK3BB Gas range
General Electric JGBP28EEL1BB Gas range
General Electric JGBP28EEL2BB Gas range
General Electric JGBP28EEL3BB GAS RANGE
General Electric JGBP28EEL4BB GAS RANGE
General Electric JGBP28EEM1CT GAS RANGE
General Electric JGBP28EEM1WH GAS RANGE
General Electric JGBP28EEM2CT GAS RANGE
General Electric JGBP28EEM2WH GAS RANGE
General Electric JGBP28EEM3CT GAS RANGE
General Electric JGBP28EEM3WH GAS RANGE
General Electric JGBP28EEM4CT GAS RANGE
General Electric JGBP28EEM4WH GAS RANGE
General Electric JGBP28EEM5CT GAS RANGE
General Electric JGBP28EEM5WH GAS RANGE
General Electric JGBP28EEM6CT GAS RANGE
General Electric JGBP28EEM6WH GAS RANGE
General Electric JGBP28GEH1SS Gas range
General Electric JGBP28GEH2SS Gas range
General Electric JGBP28GEH3SS Gas range
General Electric JGBP28GEJ1
General Electric JGBP28GEJ1SS Gas range
General Electric JGBP28GEJ2
General Electric JGBP28GEJ2SS Gas range
General Electric JGBP28GEJ3
General Electric JGBP28GEJ3SS Gas range
General Electric JGBP28GEJ4 Gas range
General Electric JGBP28GEJ5 Gas range
General Electric JGBP28GEJ6 Gas range
General Electric JGBP28GEL
General Electric JGBP28GEL2 Gas range
General Electric JGBP28GEV1AD Gas range
General Electric JGBP28GEV1WH Gas range
General Electric JGBP28GEV2AD Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Temperature Problem NabroS Oven Repair (including Ranges and Cooktops) 0 12-03-2015 08:30 AM
Whirlpool Gas Oven Temperature Problem piemaker Oven Repair (including Ranges and Cooktops) 0 07-14-2013 10:28 AM
Problem with oven temperature George Gifford Oven Repair (including Ranges and Cooktops) 0 03-31-2012 07:51 AM
Viking oven temperature problem bob_serio Oven Repair (including Ranges and Cooktops) 1 11-11-2010 06:21 AM
Oven Temperature Problem Richard Summer Oven Repair (including Ranges and Cooktops) 5 09-29-2008 12:57 PM
