Discuss
Oven doesn't maintain temperature
 in
Howdy, We have a KitchenAid double oven that won't maintain temperature when it's on. Here's the scenario. I turn on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn't maintain temperature
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-20-2018, 09:44 PM
Junior Member
kelemvor is on a distinguished road
Default Oven doesn't maintain temperature
Model Number: kebs207bss00   Brand: Kitchen Aid   Age: 1 - 5 years
Howdy,
I turn on the oven and set it to 350. The temperature readout will start with "Lo" and then eventually shows the temperature numbers as it heats up to 350. After it preheats I put in what I'm cooking. 25 minutes later, I press Cancel on the Oven and then immediately turn it right back on to 350. What *should* happen is the temperature readout should say 350 or something very close to it and then go right back up to 350. Instead, what happens is the readout will show a number far lower. I did it just now and after 25 minutes the readout was only showing 300 degrees.
The oven was purchased from Sears and we got the extended warranty which is still good until this fall. We've already had it looked at twice. I think they replaced a computer board the first time and a sensor (and maybe another board) the second time. It obviously hasn't helped.
So, my question is, is what my oven is doing considered normal? It certainly doesn't seem normal and it does seem like things take longer to cook than they should. If the oven is really cooking at 50 degrees lower than it says, that would explain why.
I'm going to place another service call on it and maybe the 3rd time is the charm. If not, I don't know if they'll offer to replace the oven, or if I can insist they do if the 3rd fix doesn't work? Are there still lemon laws?
Here's a video I took tonight to show the problem.
https://youtu.be/5dW7oWBSFu0
Thanks for any ideas.
Related Models
Whirlpool KEBS207BWH0 30" ELECTRIC OVEN - CONVECTION
Whirlpool KEBS207BWH1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS207BWH2 30"ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS207DAL1 Built-In Oven, Electric
Whirlpool KEBS207DAL2 Built-In Oven, Electric
Whirlpool KEBS207DAL4 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207DAL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DBL1 Built-In Oven, Electric
Whirlpool KEBS207DBL10 OVEN
Whirlpool KEBS207DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS207DBL12 30" BUILT IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS207DBL2 Built-In Oven, Electric
Whirlpool KEBS207DBL4 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207DBL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DBL8 BUILT IN ELECTRIC OVEN
Whirlpool KEBS207DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207DBT10 OVEN
Whirlpool KEBS207DBT11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS207DBT12 30" BUILT IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS207DBT6 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DBT7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DBT8 BUILT IN ELECTRIC OVEN
Whirlpool KEBS207DBT9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207DWH1 Built-In Oven, Electric
Whirlpool KEBS207DWH10 OVEN
Whirlpool KEBS207DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS207DWH12 30" BUILT IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS207DWH2 Built-In Oven, Electric
Whirlpool KEBS207DWH4 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207DWH6 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DWH7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS207DWH8 BUILT IN ELECTRIC OVEN
Whirlpool KEBS207DWH9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS207SBL00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SBL02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SSS00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SWH00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207SWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS207YAL0 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YAL1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YAL2 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YAL3 ELEC BUILT IN DBL OVEN
Whirlpool KEBS207YBL0 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YBL1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YBL2 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YBL3 ELEC BUILT IN DBL OVEN
Whirlpool KEBS207YWH0 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YWH1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YWH2 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS207YWH3 ELEC BUILT IN DBL OVEN
Whirlpool KEBS208AAL0 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS208AAL1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS208ABL0 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS208ABL1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS208AWH0 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS208AWH1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS208BAL0 30"ELECTIC CONVECTION OVEN
Whirlpool KEBS208BAL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS208BAL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBS208BBL0 30"ELECTIC CONVECTION OVEN
Whirlpool KEBS208BBL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS208BWH0 30"ELECTIC CONVECTION OVEN
Whirlpool KEBS208BWH1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS208BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBS208DBL1 Built-In Oven, Electric
Whirlpool KEBS208DBL10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS208DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS208DBL2 Built-In Oven, Electric
Whirlpool KEBS208DBL4 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBL6 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS208DBL8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBS10 BUILT IN OVEN-ELECTRIC
Whirlpool KEBS208DBS11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS208DBS6 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBS7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS208DBS8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DBS9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DSS10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS208DSS11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS208DSS6 OVEN
Whirlpool KEBS208DSS7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS208DSS8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DSS9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DWH1 Built-In Oven, Electric
Whirlpool KEBS208DWH10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS208DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS208DWH2 Built-In Oven, Electric
Whirlpool KEBS208DWH4 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DWH6 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DWH7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS208DWH8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208DWH9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS208SBL00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SBL02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SBT00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
KitchenAid KEBS227BAL0 27" ELEC DOUBLE OVEN - CONVECTION
Whirlpool KEBS245SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBS245SBL1 Ranges, Electric*
Whirlpool KEBS246BBL0 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BBL1 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246BBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BBL3 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246BWH0 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BWH1 24" BUILT-IN DOUBLE OVEN
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven won't maintain temperature rowland Oven Repair (including Ranges and Cooktops) 0 08-29-2014 08:46 PM
Won't maintain oven temperature Ingridmoore66 Oven Repair (including Ranges and Cooktops) 1 04-20-2014 06:18 AM
Oven doesn't maintain temperature after an hour Happychef Oven Repair (including Ranges and Cooktops) 2 10-01-2013 01:00 PM
Oven won't maintain temperature marilynjessup Oven Repair (including Ranges and Cooktops) 0 12-07-2009 07:17 AM
GE Oven will not maintain temperature diracdelta Oven Repair (including Ranges and Cooktops) 8 10-20-2009 09:21 AM
