Frigidaire Outer Glass. Tape needed or not?
Hello. I ordered the outer replacement glass (316402603) for this oven. The original glass that shattered had about a 2"
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Outer Glass. Tape needed or not?
  #1 (permalink)
Old 03-10-2018, 01:17 PM
Junior Member
RGS8 is on a distinguished road
Default Frigidaire Outer Glass. Tape needed or not?
Model Number: FGF355DSA   Brand: Frigidaire   Age: 5 - 10 years
Hello. I ordered the outer replacement glass (316402603) for this oven. The original glass that shattered had about a 2" strip of double-sided tape on the left and right side between the glass and the frame.
The replacement glass does not have this tape.
Youtube shows some people using this tape and some not mentioning it.
Is it necessary to use this tape and what is it's purpose, as it does not seem to be sealing anything nor necessarily made to support the glass?
If it should be used, can I just use a general 3M type double-sided tape or does it have to be some kind of high temp tape?
Related Models
Frigidaire FGF355DSA Frigidaire/gas Range
Frigidaire FGF355DSB Frigidaire/range
Frigidaire FGF355DSD Frigidaire/range
Frigidaire FGF355DUA Frigidaire/gas Range
Frigidaire FGF355DUB Frigidaire/range
Frigidaire FGF355DWA Frigidaire/gas Range
Frigidaire FGF355DWB Frigidaire/range
Frigidaire FGF355DWD Frigidaire/range
Frigidaire FGF355FSA Frigidaire/range
Frigidaire FGF355FSB Frigidaire/range
Frigidaire FGF355FSD Frigidaire/gas Range
Frigidaire FGF355FSE Frigidaire/range
Frigidaire FGF355FWA Frigidaire/range
Frigidaire FGF355FWB Frigidaire/range
Frigidaire FGF355FWD Frigidaire/gas Range
Frigidaire FGF355FWE Frigidaire/range
Frigidaire FGF355GWA GAS RANGE
Frigidaire FGF355GWB GAS RANGE
Frigidaire FGF355GWC GAS RANGE
Frigidaire FGF355GWD GAS RANGE
Frigidaire FGF355GWE GAS RANGE
Frigidaire FGF356MXAWA Frigidaire/gas Range
Frigidaire FGF356MXAWB Frigidaire/gas Range
Frigidaire FGF356MXAWD Frigidaire/gas Range
Frigidaire FGF358CGSA Frg(v1) / Gas Range
Frigidaire FGF358CGSB Frg(v2) / Gas Range
Frigidaire FGF358CGSC Frg(v0) / Gas Range
Frigidaire FGF358CGSD Frg(v1) / Gas Range
Frigidaire FGF358CGSE Frg(v2) / Gas Range
Frigidaire FGF363BABA Frg(v4) / Gas Range
Frigidaire FGF363BADA Frg(v2) / Gas Range
Frigidaire FGF363BAWA Frg(v1) / Gas Range
Frigidaire FGF363CASA Frg(v3) / Gas Range
Frigidaire FGF363MXASA Frigidaire/gas Range
Frigidaire FGF363MXASB Frigidaire/gas Range
Frigidaire FGF363MXASE Frigidaire/gas Range
Frigidaire FGF363MXCCA Frigidaire/gas Range
Frigidaire FGF363MXCCB Frigidaire/gas Range
Frigidaire FGF364KCA GAS RANGE
Frigidaire FGF364KCB GAS RANGE
Frigidaire FGF364KCC GAS RANGE
Frigidaire FGF364KCD GAS RANGE
Frigidaire FGF364KCF GAS RANGE
Frigidaire FGF364KCG GAS RANGE
Frigidaire FGF364KSA GAS RANGE
Frigidaire FGF365AQA Frigidaire/range
Frigidaire FGF365ASA Frigidaire/range
Frigidaire FGF365AUA Frigidaire/range
Frigidaire FGF365AWA Frigidaire/range
Frigidaire FGF365DQA Frigidaire/gas Range
Frigidaire FGF365DQC Frigidaire/range
Frigidaire FGF365DSA Frigidaire/gas Range
Frigidaire FGF365DSC Frigidaire/range
Frigidaire FGF365DUA Frigidaire/gas Range
Frigidaire FGF365DUC Frigidaire/range
Frigidaire FGF365DWA Frigidaire/gas Range
Frigidaire FGF365DWC Frigidaire/range
Frigidaire FGF365MXFCA Frigidaire/gas Range
Frigidaire FGF366ASA Frigidaire/gas Range
Frigidaire FGF366ASB Frigidaire/gas Range
Frigidaire FGF366ASD Frigidaire/range
Frigidaire FGF366ASE Frigidaire/gas Range
Frigidaire FGF366AUA Frigidaire/gas Range
Frigidaire FGF366AWA Frigidaire/gas Range
Frigidaire FGF366BCA Frigidaire/gas Range
Frigidaire FGF366BCB Frigidaire/gas Range
Frigidaire FGF366BCC Frigidaire/gas Range
Frigidaire FGF366CBB Frigidaire/gas Range
Frigidaire FGF366CBC Frigidaire/gas Range
Frigidaire FGF366CBD Frigidaire/gas Range
Frigidaire FGF366CBE Frigidaire/gas Range
Frigidaire FGF366CBF Frigidaire/gas Range
Frigidaire FGF366CCA Frigidaire/gas Range
Frigidaire FGF366CCB Frigidaire/gas Range
Frigidaire FGF366CCC Frigidaire/gas Range
Frigidaire FGF366CCD Frigidaire/gas Range
Frigidaire FGF366CQB Frigidaire/gas Range
Frigidaire FGF366CQC Frigidaire/gas Range
Frigidaire FGF366CQD Frigidaire/gas Range
Frigidaire FGF366CQE Frigidaire/gas Range
Frigidaire FGF366CQF Frigidaire/gas Range
Frigidaire FGF366CSB Frigidaire/gas Range
Frigidaire FGF366CSC Frigidaire/gas Range
Frigidaire FGF366CSD Frigidaire/gas Range
Frigidaire FGF366CSE Frigidaire/gas Range
Frigidaire FGF366CSF Frigidaire/gas Range
Frigidaire FGF366DBA Frigidaire/gas Range
Frigidaire FGF366DBB Frigidaire/range
Frigidaire FGF366DBD Frigidaire/range
Frigidaire FGF366DCA Frigidaire/gas Range
Frigidaire FGF366DCB Frigidaire/gas Range
Frigidaire FGF366DCC Frigidaire/range
Frigidaire FGF366DCD Frigidaire/range
Frigidaire FGF366DCE Frigidaire/range
Frigidaire FGF366DCF Frigidaire/range
Frigidaire FGF366DCG Frigidaire/range
Frigidaire FGF366DQA Frigidaire/gas Range
Frigidaire FGF366DQB Frigidaire/range
Frigidaire FGF366DQD Frigidaire/range
Frigidaire FGF366DSA Frigidaire/gas Range
Frigidaire FGF366DSB Frigidaire/range
Frigidaire FGF366DSD Frigidaire/range
Frigidaire FGF366EBA Frigidaire/range
Frigidaire FGF366EBB Frigidaire/range
Frigidaire FGF366EBC Frigidaire/range
Frigidaire FGF366EBD Frigidaire/range
Frigidaire FGF366EBE Frigidaire/range
Frigidaire FGF366EBF GAS RANGE
Frigidaire FGF366EBG GAS RANGE
Frigidaire FGF366EBH GAS RANGE
Frigidaire FGF366ECA Frigidaire/gas Range
Frigidaire FGF366ECB Frigidaire/gas Range
Frigidaire FGF366ECC Frigidaire/range
Frigidaire FGF366ECD Frigidaire/range
Frigidaire FGF366EMB Frigidaire/gas Range
Frigidaire FGF366EMC Frigidaire/range
Frigidaire FGF366EMD Frigidaire/gas Range
Frigidaire FGF366EME Frigidaire/range
Frigidaire FGF366EQA Frigidaire/range
Frigidaire FGF366EQB Frigidaire/range
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Outer oven glass replacement/foil "tape" Debber Oven Repair (including Ranges and Cooktops) 3 10-16-2014 02:01 AM
Outer Glass ShannonRae Oven Repair (including Ranges and Cooktops) 0 07-07-2013 12:56 PM
Frigidaire --freezer too warm--asphalt tape from manufacturer on the freezer coils jpm01609 Refrigerator & Freezer Repair 3 09-19-2011 08:09 AM
Replacing outer glass on Frigidaire oven door 4Manny Oven Repair (including Ranges and Cooktops) 1 08-13-2010 06:09 PM
Outer oven glass needed compatible w/ discontinued model ChrissyE Oven Repair (including Ranges and Cooktops) 1 06-04-2009 12:39 PM
