Discuss
Gas Oven won't heat but broiler and burners work fine
 in
Frigidaire Gallery top gas oven quit working about a year ago but the broiler still works. The bottom oven quit
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Oven won't heat but broiler and burners work fine
  #1 (permalink)
Old 03-04-2018, 07:42 AM
Junior Member
Melissabrooks is on a distinguished road
Default Gas Oven won't heat but broiler and burners work fine
Brand: Frigidaire   Age: 5 - 10 years
Frigidaire Gallery top gas oven quit working about a year ago but the broiler still works. The bottom oven quit working yesterday. When I turn either oven on the panel stays on 100 degrees but nothing happens. I removed the bottom plate and there is nothing. All 4 stovetop burners work fine .
  #2 (permalink)
Old 03-04-2018, 02:35 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
If you don't see any glowing its probably a burnt out ignitor.
I need a model number so we can see what kind of parts are inside.
  #3 (permalink)
Old 03-04-2018, 04:58 PM
Junior Member
Default
Fggf304dlf3
  #4 (permalink)
Old 03-04-2018, 05:09 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
On this diagram its part 26.
Parts for Frigidaire FGGF304DLF3: Burner Parts - AppliancePartsPros.com
Ignitor, bake.
Frigidaire 316489406 Ignitor - AppliancePartsPros.com
When you turn the oven on, it should be glowing bright orangish yellow. If not its probably burnt out. Its best to test for voltage just to make sure it's the ignitor.
  #5 (permalink)
Old 03-05-2018, 08:59 AM
Junior Member
Default
Thank you so much. Is the part the same for the upper and lower oven?
  #6 (permalink)
Old 03-05-2018, 09:47 AM
Junior Member
Default
Also, is there an "off brand" part that us not quite as expensive since I'm having to buy 2?
  #7 (permalink)
Old 03-05-2018, 01:43 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Quote:
According to the parts diagram they are the same bake igniter.
Google can be your friend, sometimes.
https://www.amazon.com/s/?ie=UTF8&ke...l_4i6j7gls2m_e
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gallery Oven will not start, broiler and burners work fine Scotts_Spot Oven Repair (including Ranges and Cooktops) 6 04-16-2014 02:37 PM
Oven won't heat right, broiler and burners work piglet59645 Oven Repair (including Ranges and Cooktops) 1 09-27-2011 02:42 AM
magic chef / maytag made oven will not heat - 4 stovetop burners work fine hellotracy Oven Repair (including Ranges and Cooktops) 3 12-22-2009 05:51 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Oven heats to 100 degrees only. Broiler and top burners work fine. Casseopia Oven Repair (including Ranges and Cooktops) 1 03-24-2009 05:34 PM
