3 burnt recepticals 1 burner working
I replaced the range top receptacles with the kit checked all burners for continuity and have voltage at the burner
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 3 burnt recepticals 1 burner working
  #1 (permalink)
Old 02-20-2018, 11:10 AM
Junior Member
Arnie-Man is on a distinguished road
Default 3 burnt recepticals 1 burner working
Model Number: TEF351EWP   Brand: Tappan   Age: Less than 1 year
I replaced the range top receptacles with the kit checked all burners for continuity and have voltage at the burner receptacles but 3 of the 4 do not get hot. Also the lights for the left and right burners showing they are on are lit and do not turn off this stove is a year old UGH. should i replace the board? the burner switches? what AM I MISSING HERE?????
Related Models
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
Tappan TEF353AUF Tappan/electric Range
Tappan TEF353AWA Tappan/range
Tappan TEF353AWB Tappan/electric Range
Tappan TEF353AWC Tappan/electric Range
Tappan TEF353AWD Tappan/electric Range
Tappan TEF353AWE Tappan/range
Tappan TEF353AWF Tappan/electric Range
Frigidaire TEF354BCDA Tap(v1) / Electric Range
Frigidaire TEF354BCDB Tap(v1) / Electric Range
Frigidaire TEF354BCDC Tap(v1) / Electric Range
Frigidaire TEF354BCDD Tap(v1) / Electric Range
Frigidaire TEF354BCWA Tap(v2) / Electric Range
Frigidaire TEF354BCWB Tap(v2) / Electric Range
Frigidaire TEF354BCWC Tap(v2) / Electric Range
Frigidaire TEF354BCWD Tap(v2) / Electric Range
Frigidaire TEF355BCDA Tap(v1) / Electric Range
Frigidaire TEF355BCDB Tap(v1) / Electric Range
Frigidaire TEF355BCDC Tap(v1) / Electric Range
Frigidaire TEF355BCWA Tap(v2) / Electric Range
Frigidaire TEF355BCWB Tap(v2) / Electric Range
Frigidaire TEF355BCWC Tap(v2) / Electric Range
Frigidaire TEF355BFDA Tap(v1) / Electric Range
Frigidaire TEF355BFWA Tap(v2) / Electric Range
Frigidaire TEF355BXDA Tap(v3) / Electric Range
Frigidaire TEF355BXWA Tap(v4) / Electric Range
Frigidaire TEF356SCWA Tap(v0) / Electric Range
Frigidaire TEF356SCWB Tap(v0) / Electric Range
Frigidaire TEF356SCWC Tap(v0) / Electric Range
Frigidaire TEF356SCWD Tap(v0) / Electric Range
Frigidaire TEF357BCDA Tap(v1) / Electric Range
Frigidaire TEF357BCDB Tap(v1) / Electric Range
Frigidaire TEF357BCDC Tap(v1) / Electric Range
Frigidaire TEF357BCDD Tap(v1) / Electric Range
Frigidaire TEF357BCDE Tap(v1) / Electric Range
Frigidaire TEF357BCWA Tap(v2) / Electric Range
Frigidaire TEF357BCWB Tap(v2) / Electric Range
Frigidaire TEF357BCWC Tap(v2) / Electric Range
Frigidaire TEF357BCWD Tap(v2) / Electric Range
Frigidaire TEF357BCWE Tap(v2) / Electric Range
Frigidaire TEF357BFDA Tap(v1) / Electric Range
Frigidaire TEF357BFDB Tap(v1) / Electric Range
Frigidaire TEF357BFWA Tap(v2) / Electric Range
Frigidaire TEF357BFWB Tap(v2) / Electric Range
Tappan TEF360MXDSA Tappan/electric Range
Tappan TEF360MXDSE Tappan/electric Range
Tappan TEF360MXDSF Tappan/electric Range
Tappan TEF360MXDSG Tappan/range
Tappan TEF361ESA Tappan/range
Tappan TEF361ESB Tappan/range
Tappan TEF361ESC Tappan/range
Tappan TEF361ESD Tappan/electric Range
Tappan TEF361ESF Tappan/range
Frigidaire TEF362BBBA Tap(v0) / Electric Range
Frigidaire TEF362BBBB Tap(v0) / Electric Range
Frigidaire TEF362BBBC Tap(v0) / Electric Range
Frigidaire TEF362BBBD Tap(v0) / Electric Range
Frigidaire TEF362BBBE Tap(v0) / Electric Range
Tappan TEF364AQA Tappan/range
Tappan TEF364AQB Tappan/range
Tappan TEF364AQC Tappan/electric Range
Tappan TEF364AQD Tappan/electric Range
Tappan TEF364AQE Tappan/electric Range
Tappan TEF364AQF Tappan/electric Range
Tappan TEF364AQG Tappan/electric Range
Tappan TEF364AQJ Tappan/electric Range
Tappan TEF364ASA Tappan/range
Tappan TEF364ASB Tappan/range
Tappan TEF364ASC Tappan/electric Range
Tappan TEF364ASD Tappan/electric Range
Tappan TEF364ASE Tappan/electric Range
Tappan TEF364ASF Tappan/electric Range
Tappan TEF364ASG Tappan/electric Range
Tappan TEF364ASJ Tappan/electric Range
Frigidaire TEF365BEDA Tap(v1) / Electric Range
Frigidaire TEF365BEDB Tap(v1) / Electric Range
Frigidaire TEF365BEWA Tap(v2) / Electric Range
Frigidaire TEF365BEWB Tap(v2) / Electric Range
Frigidaire TEF365BHDA Tap(v1) / Electric Range
Frigidaire TEF365BHWA Tap(v2) / Electric Range
Frigidaire TEF365CHSA Tap(v3) / Electric Range
Frigidaire TEF367CCSA Tap(v1) / Electric Range
Frigidaire TEF367CCSB Tap(v1) / Electric Range
Frigidaire TEF367CCSC Tap(v1) / Electric Range
Frigidaire TEF367CCSD Tap(v1) / Electric Range
Frigidaire TEF367CCSE Tap(v1) / Electric Range
Frigidaire TEF367CCTA Tap(v2) / Electric Range
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire stacked washer not working/burnt smell Jenbrooker Washer Repair 0 03-22-2017 06:46 PM
Burner not working on JEC9530ADB cooktop, is it burner or Switch? joelake Oven Repair (including Ranges and Cooktops) 0 12-29-2010 11:07 AM
Freezer stopped working and makes a burnt rubber smell hkrekel Refrigerator & Freezer Repair 0 07-14-2010 07:43 AM
freezer quit working and smells like burnt rubber hkrekel Washer Repair 0 07-14-2010 05:27 AM
GE burner burnt hole in pot infocus4u1973 Oven Repair (including Ranges and Cooktops) 4 08-26-2009 01:26 PM
