Discuss
Yellow flame, all four burners
 in
Last night, I noticed that a burner on my cooktop was giving off a yellowish flame, indicating insufficient air in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Yellow flame, all four burners
  #1 (permalink)
Old 02-09-2018, 08:08 AM
Junior Member
Paddle2thesea is on a distinguished road
Default Yellow flame, all four burners
Model Number: 6498vvv   Brand: Magic Chef   Age: More than 10 years
Last night, I noticed that a burner on my cooktop was giving off a yellowish flame, indicating insufficient air in the mixture. I turned on the other three burners and got the same yellow-ish flame.
Because it affects all four burners, Iím guessing it is caused by an obstruction to the air intake that feeds all of the burners, and the fix may be as simple as removing a clump of dog hair somewhere. I canít figure out where that would be, though. My trusty Readerís Digest fix-it-yourself manual says I should be looking for an air shutter somewhere. I have successfully lifted up the cooktop to expose the guts, but I canít find anything that looks like the picture in the book.
Suggestions?
Related Models
Magic Chef 6498VVV RANGE- S/C S/I GAS
Magic Chef 6498XRA RANGE- S/C S/I GAS
Magic Chef 6498XRS RANGE- S/C S/I GAS
Magic Chef 6498XRW RANGE- S/C S/I GAS
Magic Chef 6498XTA RANGE- S/C S/I GAS
Magic Chef 6498XTS RANGE- S/C S/I GAS
Magic Chef 6498XTW RANGE- S/C S/I GAS
Magic Chef 6498XVB RANGE- S/C S/I GAS
Magic Chef 6498XVS RANGE- S/C S/I GAS
Magic Chef 64EA-3CKW RANGE- S/C S/I GAS
Magic Chef 64EB-3CKW RANGE- S/C S/I GAS
Magic Chef 64EN-3CKW RANGE- S/C S/I GAS
Magic Chef 64EY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKX RANGE- S/C S/I GAS
Magic Chef 64FA-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FB-3CKW RANGE- S/C S/I GAS
Magic Chef 64FK-3CKX RANGE- S/C S/I GAS
Magic Chef 64FK-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKX RANGE- S/C S/I GAS
Magic Chef 64FN-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKX RANGE- S/C S/I GAS
Magic Chef 64FY-3CKXW RANGE- S/C S/I GAS
Magic Chef 64H-4TKVW RANGE- S/C S/I GAS
Magic Chef 64H-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HK-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKXW RANGE- S/C S/I GAS
Hoover 65
Amana 650.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 650.001 RANGE- S/C S/I DDRAFT GAS
Magic Chef 6500PRA RANGE- S/I STD ELE
Magic Chef 6500PRW RANGE- S/I STD ELE
Magic Chef 6500SRS RANGE- S/I STD ELE
Frigidaire 6504A WASHER
Frigidaire 6504B WASHER
Frigidaire 6504C WASHER
Frigidaire 6504D WASHER
Frigidaire 6504E WASHER
Frigidaire 6504E-87 WASHER
Frigidaire 6505A WASHER
Frigidaire 6505B WASHER
Frigidaire 6505C WASHER
Frigidaire 6506-87A WASHER
Frigidaire 6506-87C WASHER
Frigidaire 6506-87D TOP LOAD WASHER
Frigidaire 6506-87E TOP LOAD WASHER
Frigidaire 6506A WASHER
Frigidaire 6506B WASHER
Frigidaire 6507-87A WASHER
Frigidaire 6507-87C WASHER
Frigidaire 6507-87D WASHER
Frigidaire 6507-87E TOP LOAD WASHER
Frigidaire 6507A WASHER
Frigidaire 6508D WASHER
Hoover 651
Amana 651.000 RANGE- S/C S/I DDRAFT GAS
Amana 651.001 RANGE- S/C S/I DDRAFT GAS
Amana 651.002 RANGE- S/C S/I DDRAFT GAS
Amana 651.003 RANGE- S/C S/I DDRAFT GAS
Amana 651.004 RANGE- S/C S/I DDRAFT GAS
Amana 651.006 RANGE- S/C S/I DDRAFT GAS
Kenmore 65189918100 WRINGER WASHER
Admiral 651AH RANGE- S/C F/S ELE
Admiral 651WH RANGE- S/C F/S ELE
Admiral 653AH-HV RANGE- F/S STD ELE
Admiral 653AH-V RANGE- F/S STD ELE
Admiral 653AJ-HV RANGE- F/S STD ELE
Admiral 653AJ-V RANGE- S/C F/S ELE
Admiral 653AJ-V-CX RANGE- F/S STD ELE
Admiral 653WH-HV RANGE- F/S STD ELE
Admiral 653WH-V RANGE- F/S STD ELE
Admiral 653WJ-HV RANGE- F/S STD ELE
Admiral 653WJ-V RANGE- S/C F/S ELE
Admiral 653WJ-V-CX RANGE- F/S STD ELE
Admiral 654AD-HVW RANGE- F/S STD ELE
Admiral 654AG-HVW RANGE- F/S STD ELE
Admiral 654AH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654AH-EVW RANGE- F/S STD ELE
Admiral 654AH-EW RANGE- F/S STD ELE
Admiral 654WD-HVW RANGE- F/S STD ELE
Admiral 654WG-HVW RANGE- F/S STD ELE
Admiral 654WH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-ELW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-EW RANGE- F/S STD ELE
Magic Chef 6551WRA RANGE- S/I STD ELE
Magic Chef 6551WRW RANGE- S/I STD ELE
Magic Chef 6551WUA RANGE- S/I STD ELE
Magic Chef 6551WUB RANGE- S/I STD ELE
Magic Chef 6551WUW RANGE- S/I STD ELE
Magic Chef 6551XRA RANGE- S/I STD ELE
Magic Chef 6551XRW RANGE- S/I STD ELE
Magic Chef 6551XUA RANGE- S/I STD ELE
Magic Chef 6551XUB RANGE- S/I STD ELE
Magic Chef 6551XUW RANGE- S/I STD ELE
Admiral 655AH-CVW RANGE- F/S STD ELE
Admiral 655WH-CVW RANGE- F/S STD ELE
Admiral 656AH-EHVW RANGE- F/S STD ELE
Admiral 656HH-EHVW RANGE- F/S STD ELE
Admiral 656WH-EHVW RANGE- F/S STD ELE
Frigidaire 6589-80 WASHER
Frigidaire 6589-80B WASHER
Frigidaire 6589-87 WASHER
Maytag 65C DRYER- GAS
Magic Chef 65HA-1 RANGE- S/I STD ELE
Magic Chef 65HA-3W RANGE- S/I STD ELE
Magic Chef 65HA-3X RANGE- S/I STD ELE
Magic Chef 65HN-1 RANGE- S/I STD ELE
Magic Chef 65HN-3W RANGE- S/I STD ELE
Magic Chef 65HN-3X RANGE- S/I STD ELE
Hoover 66
Admiral 663AH-CV RANGE- S/C F/S ELE
Admiral 663WH-CV RANGE- S/C F/S ELE
Kenmore 6644098997 BUILT IN OVEN
  #2 (permalink)
Old 02-09-2018, 03:31 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Most likely it has to do with gas pressure. Bad or weak regulator, low gas pressure. Are you on propane?
The burners each have a air shutter. I believe its the "clamp" in this picture.
  #3 (permalink)
Old 02-09-2018, 03:45 PM
Junior Member
Default
Thanks for the reply.
Natural gas. If each burner has its own air shutter, it seems unlikely that all four shutters went funny. Is there a way to test the regulator, other than by replacing the old one and seeing what happens?
  #4 (permalink)
Old 02-10-2018, 01:31 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
You could call your gas supplier and have them check your house regulator.
Most appliance places can check the regulator inside the range.
Do you have anything else that runs on natural gas? You might check their burner flames.
  #5 (permalink)
Old 02-10-2018, 07:29 AM
ohm ohm is offline
Member
ohm is on a distinguished road
Default
If you have a humidifier in the house shut it off for a day and see if it fixes your problem. Just had a friend call me yesterday about this and fixed his problem.
  #6 (permalink)
Old 02-10-2018, 10:51 AM
Junior Member
Default
Quote:
Eureka! (Probably.) Just got a new ultrasonic humidifier the same day I noticed that the flame color changed. I've switched off the humidifier and will check the stove later this afternoon. You probably just saved me a $ervice call!
  #7 (permalink)
Old 02-10-2018, 08:49 PM
ohm ohm is offline
Member
Default
How did you make out?
  #8 (permalink)
Old 02-11-2018, 07:49 AM
Junior Member
Default
Fixed it! Thanks!
  #9 (permalink)
Old 02-11-2018, 08:44 AM
ohm ohm is offline
Member
Default
Thanks for getting back as this may help others!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Yellow flame in oven DarrenT66 Oven Repair (including Ranges and Cooktops) 0 06-11-2013 12:57 PM
Yellow flame and shuts off after 12 seconds dsbemus Dryer Repair 0 12-30-2012 09:07 PM
yellow flame on gas stove sdgallop Oven Repair (including Ranges and Cooktops) 3 05-03-2010 07:29 PM
Erratic High Yellow FLame oakley349 Oven Repair (including Ranges and Cooktops) 1 07-04-2009 12:50 PM
Yellow flame stu442 Oven Repair (including Ranges and Cooktops) 1 04-28-2009 06:05 AM
