My kitchenaid stove top times out when more than one burner is cut on at a time. If two burners are on at the same time, I have to cut one burner on at a higher temperature than the other is at to keep that burner on. Once i increase the temperature of the first burner, the second burner automatically times out and will not cut back on. Sometimes, only one burner is cut on and it still times out.
