Discuss
Oven door hinges
 in
Hi, hopefully someone can help me. I replaced the hinges P/N WP71003353 with supposedly genuine jenn air parts today and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door hinges
  #1 (permalink)
Old 01-20-2018, 04:29 PM
Junior Member
prcummings is on a distinguished road
Default Oven door hinges
Model Number: SVD48600P   Brand: Jenn-Air   Age: More than 10 years
Hi, hopefully someone can help me. I replaced the hinges P/N WP71003353 with supposedly genuine jenn air parts today and now the door does not close up tighht like it did with the worn out hinges. I have to push on the door slightly to get the light switch activated and the self cleaning lock won't engage unless I push alittle bit on the door.
The door works nice and smooth now but it does not close tight against the seal. It seems like the springs are not as tight or they need more tension on them. Could these be inferior hinges?? The oven door has never been off or twisted so it isn't anything like that.
The door seemed to go on the pins inside good but don't know what that looks like. Thanks for any help you can offer.
paul
Related Models
Jenn-Air SVD48600P RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PT RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600WC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVE47100B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
  #2 (permalink)
Old 01-21-2018, 06:37 AM
Junior Member
Default
Can anyone offer any help on this? I'm getting desperate on what to do next? Thank you
paul
  #3 (permalink)
Old 01-22-2018, 04:13 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Does your hinges look like these?
Whirlpool WP71003353 Hinge, Door - AppliancePartsPros.com
Are you sure you have the door all the way into the frame and down on the pins?
Could you post pictures of the door gap, the door frame around the hinge area, and the hinge it's self.
Were there any adjustments on the hinges or door? Perhaps the frame or door are slightly bent.
  #4 (permalink)
Old 01-22-2018, 05:10 PM
Junior Member
Default
Thatguy, the hinges are the same as in the picture. We owned the oven from the delivery. No bent door or frame. Before putting the old hinges back in I inserted an original and new hinge in each receptacle (without door)to see what they looked like. Come to find out the original hinge is positioned at a slight angle in toward the frame where the new hinge is completely vertical, first difference. Second I pulled on each spring to feel the tension of each and the replacement had very little tension at the closing point compared to the original 19 yr old spring. I compared the hinges side by side and they look identical except for the length of the spring which is slightly different. Could this be an issue of being a replacement spring fit for many models and not matching the specs for the weight and geometry of my door?
PS I will send photos when i figure out how. Thank you very much.
Also I have confirmed the hinges are all the way engaged in the receptacles.
  #5 (permalink)
Old 01-27-2018, 05:03 PM
Junior Member
Default
Well I got it fixed. If anyone has the same issue this is what I had to do. The springs on the original hinges were a bit stronger so I replaced the new springs with my old ones in the new hinges. Then I realized the stop against the roller was not allowing the hinge to retract as far as the original so I filed the plate down some to get the hinge to retract further in to the frame.
I also decided to swap the receptacles from side to side to move the indentations in the pins to a different location. This probably didn't make a difference but I thought I would do it anyway. These two fixes allowed me to use the new hinges with the mods mentioned above and now the door works like new again.
paul
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven Door Hinges venicedeer Oven Repair (including Ranges and Cooktops) 0 07-05-2013 06:30 AM
oven door hinges llfraser Oven Repair (including Ranges and Cooktops) 4 06-14-2013 11:39 AM
Oven door Hinges junia mike Oven Repair (including Ranges and Cooktops) 0 10-28-2011 11:43 AM
Oven Door Hinges Kenn Oven Repair (including Ranges and Cooktops) 0 04-15-2011 08:39 AM
Oven Door Hinges GylanAllen Oven Repair (including Ranges and Cooktops) 3 12-19-2008 01:51 PM
