Discuss
Bosch HEI7052U Error Code 160
 in
Hi, for the last few months I have a problem with my electric range. I select a bake mode (bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bosch HEI7052U Error Code 160
  #1 (permalink)
Old 01-20-2018, 11:03 AM
Junior Member
Hubitom is on a distinguished road
Default Bosch HEI7052U Error Code 160
Model Number: HEI7052U   Brand: Bosch   Age: 5 - 10 years
for the last few months I have a problem with my electric range. I select a bake mode (bake or convection bake), select temp, and hit start. After a few seconds the range will beep at me, and telling me "Error 160". I try a few times, shift between modes, and then it works again. More often than not will I have to try multiple times to get it to work.
I called Bosch and they told me that unplugging the range for 20 minutes might help because of resetting the PCB. I did this, and it did not help. The other possible solution is to change the main board. Before I spend hundreds of Dollars on a "possible" solution I would like to see if someone here had the same issues, and knows of a proper solution.
Also, would this be the right main board? I did look up the model number on the back of the range but it didn't give me a extension (i.e. /02 or 03 or ...) Are they the correct part for all extensions?
Module
by Bosch
Part Number AP5263087
Related Models
Amana HET-480 RANGE- S/C S/I DDRAFT GAS
Amana HEU-516 RANGE- S/C S/I DDRAFT GAS
Magic Chef HF309-2 HOOD
Magic Chef HF309-3 HOOD
Magic Chef HF309-4 HOOD
Frigidaire HF30M Frg(v3) / Range Vent Hood
Magic Chef HF30R-1 HOOD
Magic Chef HF30R-1A HOOD
Magic Chef HF369-2 HOOD
Magic Chef HF369-3 HOOD
Magic Chef HF369-4 HOOD
Frigidaire HFA180FM1D Kel(v1) / Chest Freezer
Frigidaire HFA180FM2D Kel(v2) / Chest Freezer
Frigidaire HFP158DM1W Kel(v2) / Chest Freezer
Frigidaire HFP158DMOW Kel(v1) / Chest Freezer
Frigidaire HFS156AM3W Kel(v1) / Chest Freezer
Frigidaire HFS156SM2W Kel(v2) / Chest Freezer
Frigidaire HFS156SM4W Kel(v3) / Chest Freezer
Frigidaire HFS156SM5W Kel(v1) / Chest Freezer
Frigidaire HFS158DM1W Kel(v1) / Chest Freezer
Frigidaire HFS158DMOW Kel(v2) / Chest Freezer
Frigidaire HFS158FM1W Kel(v1) / Chest Freezer
Frigidaire HFS158FM2W Kel(v2) / Chest Freezer
Frigidaire HFS158FM3W Kel(v3) / Chest Freezer
Frigidaire HFS158FM7W Kel(v1) / Chest Freezer
Frigidaire HFS158FM8W Kel(v1) / Chest Freezer
Frigidaire HFS180EM1W Kel(v1) / Freezer
Frigidaire HFS180EM2W Kel(v2) / Freezer
Frigidaire HFS204DM1W Kel(v3) / Chest Freezer
Frigidaire HFS204DMOW Kel(v3) / Chest Freezer
Frigidaire HFS204FM1W Kel(v1) / Chest Freezer
Frigidaire HFS204FM2W Kel(v1) / Chest Freezer
Frigidaire HFS204FM3W Kel(v2) / Chest Freezer
Frigidaire HFS204FM4W Kel(v3) / Chest Freezer
Frigidaire HFS204FM5W Kel(v1) / Chest Freezer
Frigidaire HFS208SM4W Kel(v1) / Chest Freezer
Frigidaire HFS230DM0W Kel(v4) / Chest Freezer
Frigidaire HFS230DM1W Kel(v5) / Chest Freezer
Frigidaire HFS230DMOW Kel(v4) / Chest Freezer
Frigidaire HFS260SM4W Kel(v2) / Chest Freezer
Frigidaire HFS262DM1W Kel(v1) / Freezer
Frigidaire HFS262FM1W Kel(v1) / Chest Freezer
Frigidaire HFS262FM5W Kel(v1) / Chest Freezer
Amana HG2090 DRYER- GAS
Amana HG2260 WASHER-TOP LOADING
Amana HG2490 WASHER-TOP LOADING
Amana HG2980 WASHER-TOP LOADING
Amana HG3009 WASHER-TOP LOADING
Amana HG4009 WASHER-TOP LOADING
Amana HG4080 DRYER- GAS
Amana HG4109 WASHER-TOP LOADING
Amana HG4209 WASHER-TOP LOADING
Amana HG4280 DRYER- GAS
Amana HG4360 WASHER-TOP LOADING
Amana HG4390 DRYER- GAS
Amana HG4490 DRYER- GAS
Amana HG4509 WASHER-TOP LOADING
Amana HG5009 DRYER- GAS
Amana HG5390 WASHER-TOP LOADING
Amana HG6009 DRYER- GAS
Amana HG6360 WASHER-TOP LOADING
Amana HG6380 DRYER- GAS
Amana HG6490 WASHER-TOP LOADING
Amana HG6494 WASHER-TOP LOADING
Amana HG6660 WASHER-TOP LOADING
Amana HG7009 DRYER- GAS
Amana HG7290 WASHER-TOP LOADING
Amana HG9260 WASHER-TOP LOADING
Amana HG9280 WASHER-TOP LOADING
Maytag HGD4300TQ0 29" GAS DRYER
Maytag HGD4400TQ0 29" GAS DRYER
Thermador HGSI42TS
Thermador HGSW36TS
Maytag HJ61201JRT ELECTRIC WATER HEATER
Maytag HJ61202JRT ELECTRIC WATER HEATER
Maytag HJ6301JLS ELECTRIC WATER HEATER
Maytag HJ6301JLSCSA ELECTRIC WATER HEATER
Maytag HJ6301JRT2 ELECTRIC WATER HEATER
Maytag HJ6301JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6302JLS ELECTRIC WATER HEATER
Maytag HJ6302JLSCSA ELECTRIC WATER HEATER
Maytag HJ6302JRT2 ELECTRIC WATER HEATER
Maytag HJ6302JRT2CSA ELECTRIC WATER HEATER
Maytag HJ630NORT GAS WATER HEATER
Maytag HJ630NORT2 GAS WATER HEATER
Maytag HJ630NORT2CGA GAS WATER HEATER
Maytag HJ630NORTCGA GAS WATER HEATER
Maytag HJ630PORT GAS WATER HEATER
Maytag HJ630PORT2 GAS WATER HEATER
Maytag HJ630PORT2CGA GAS WATER HEATER
Maytag HJ630PORTCGA GAS WATER HEATER
Maytag HJ6401JLS ELECTRIC WATER HEATER
Maytag HJ6401JLSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRS ELECTRIC WATER HEATER
Maytag HJ6401JRSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2 ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6401JRT2F ELECTRIC WATER HEATER
Maytag HJ6401JT4W ELECTRIC WATER HEATER
Maytag HJ6401JT4WCSA GAS WATER HEATER
Maytag HJ6402JLS ELECTRIC WATER HEATER
Maytag HJ6402JLSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRS ELECTRIC WATER HEATER
Maytag HJ6402JRSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2 ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6402JRT2F ELECTRIC WATER HEATER
Maytag HJ6402JT4W ELECTRIC WATER HEATER
Maytag HJ6402JT4WCSA GAS WATER HEATER
Maytag HJ640NBDS GAS WATER HEATER
Maytag HJ640NBDSCGA GAS WATER HEATER
Maytag HJ640NBDVT GAS WATER HEATER
Maytag HJ640NBDVTCGA GAS WATER HEATER
Maytag HJ640NBPDT GAS WATER HEATER
Maytag HJ640NBPDTCGA GAS WATER HEATER
Maytag HJ640NBRS GAS WATER HEATER
Maytag HJ640NBRSCGA GAS WATER HEATER
Maytag HJ640NBRT GAS WATER HEATER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch error code e24 larrym37 Dishwasher Repair 0 02-11-2017 12:32 PM
Bosch Assix Error Code 06 CURKing Washer Repair 1 09-03-2015 03:45 AM
Bosch Washer Error Code E.01 - Test Code C.06 trav329 Washer Repair 0 08-09-2015 02:08 PM
Bosch Dishwasher Error code E:24 ollebolle Dishwasher Repair 0 02-18-2013 02:29 PM
bosch nexxt 500 error code e22 bearhvs Dryer Repair 0 01-16-2010 02:58 AM
