Discuss
L G Stove oven and burner don't work
 in
I moved the stove out to clean behind it. After moving it back the oven or stove top will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » L G Stove oven and burner don't work
  #1 (permalink)
Old 01-16-2018, 01:32 PM
Junior Member
craig59 is on a distinguished road
Default L G Stove oven and burner don't work
Model Number: LSC5683WS   Brand: -other-   Age: 5 - 10 years
I moved the stove out to clean behind it. After moving it back the oven or stove top will not work. Checked power to it everything is good there. Thanks for the help.
Related Models
Whirlpool LSC6244AW0 Washers*
Whirlpool LSC6244BQ0 Washers*
Whirlpool LSC6244BW0 Washers*
Whirlpool LSC8244BG0 AUTOMATIC WASHER
Whirlpool LSC8244BG1 AUTOMATIC WASHER
Whirlpool LSC8244BN0 AUTOMATIC WASHER
Whirlpool LSC8244BN1 AUTOMATIC WASHER
Whirlpool LSC8244BQ0 AUTOMATIC WASHER
Whirlpool LSC8244BQ1 AUTOMATIC WASHER
Whirlpool LSC8244BW0 AUTOMATIC WASHER
Whirlpool LSC8244BW1 AUTOMATIC WASHER
Whirlpool LSC8244BZ0 AUTOMATIC WASHER
Whirlpool LSC8244BZ1 AUTOMATIC WASHER
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
Maytag LSE7804ACL STACKED LAUNDRY- ELE
Maytag LSE7804ACM STACKED LAUNDRY- ELE
Maytag LSE7804ADE STACKED LAUNDRY- ELE
Maytag LSE7804ADL STACKED LAUNDRY- ELE
Maytag LSE7804ADM STACKED LAUNDRY- ELE
Maytag LSE7804AEE STACKED LAUNDRY- ELE
Admiral LSE7804AGE STACKED LAUNDRY- ELE
Admiral LSE7804AGL STACKED LAUNDRY- ELE
Admiral LSE7804AGM STACKED LAUNDRY- ELE
Maytag LSE7806ACE STACKED LAUNDRY- ELE
Maytag LSE7806ACM STACKED LAUNDRY- ELE
Maytag LSE7806ACQ STACKED LAUNDRY- ELE
Maytag LSE7806ADE STACKED LAUNDRY- ELE
Maytag LSE7806ADM STACKED LAUNDRY- ELE
Maytag LSE7806ADQ STACKED LAUNDRY- ELE
Maytag LSE7806AEE STACKED LAUNDRY- ELE
Maytag LSE7806BCE STACKED LAUNDRY- ELE
Admiral LSE7806GGE STACKED LAUNDRY- ELE
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 STACKED LAUNDRY- ELE
Maytag LSE9900ACE STACKED LAUNDRY- ELE
Maytag LSE9900ACL STACKED LAUNDRY- ELE
Maytag LSE9900ACW STACKED LAUNDRY- ELE
Maytag LSE9900ADE STACKED LAUNDRY- ELE
Maytag LSE9900ADL STACKED LAUNDRY- ELE
Maytag LSE9900ADW STACKED LAUNDRY- ELE
Maytag LSE9900AEE STACKED LAUNDRY- ELE
Maytag LSE9900AEL STACKED LAUNDRY- ELE
Maytag LSE9900AEW STACKED LAUNDRY- ELE
Maytag LSE9900AFL STACKED LAUNDRY- ELE
Maytag LSE9900AFW STACKED LAUNDRY- ELE
Maytag LSE9904ACE STACKED LAUNDRY- ELE
Maytag LSE9904ACL STACKED LAUNDRY- ELE
Maytag LSE9904ACM STACKED LAUNDRY- ELE
Maytag LSE9904ADE STACKED LAUNDRY- ELE
Maytag LSE9904ADL STACKED LAUNDRY- ELE
Maytag LSG1000 STACKED LAUNDRY- GAS
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W STACKED LAUNDRY- GAS
Jenn-Air LSG2704W STACKED LAUNDRY- GAS
Maytag LSG7800 STACKED LAUNDRY- GAS
Maytag LSG7800AAE STACKED LAUNDRY- GAS
Maytag LSG7800AAL STACKED LAUNDRY- GAS
Maytag LSG7800AAW STACKED LAUNDRY- GAS
Maytag LSG7800ABE STACKED LAUNDRY- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Stove Top Burner Does not Work JohnStrauss Oven Repair (including Ranges and Cooktops) 0 06-26-2015 08:59 AM
Oven, display only work if stove burner is on chrisjclay Oven Repair (including Ranges and Cooktops) 2 11-14-2010 09:00 AM
replaced stove top burner still does not work rcaple Oven Repair (including Ranges and Cooktops) 1 09-23-2010 05:35 PM
replaced stove top burner and infinite switch but burner still does not work rcaple Oven Repair (including Ranges and Cooktops) 1 09-23-2010 05:34 PM
Burner on stove will not work dlankford Oven Repair (including Ranges and Cooktops) 0 06-09-2008 11:55 AM
