Discuss
Jenn Air Keypad Ribbon Repair
 in
Hello - I have a Jennair SVD48600W range and the OFF button on the keypad is not working. I have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air Keypad Ribbon Repair
  #1 (permalink)
Old 12-28-2017, 01:50 PM
Junior Member
mangomango is on a distinguished road
Default Jenn Air Keypad Ribbon Repair
Model Number: SVD48600W   Brand: Jenn-Air   Age: 5 - 10 years
Hello - I have a Jennair SVD48600W range and the OFF button on the keypad is not working. I have narrowed it down to a fault in the ribbon cable connecting the oven control panel and the keypad. Unfortunately, we do not get the keypad panel in white anymore, due to which I have to fix the cable in the ribbon cable. The ribbon cable has about 16 wires. How do I figure out which is the one for the OFF button? I would to 'jump' it with a wire and a solder. Thanks !!
Related Models
Jenn-Air SVD48600W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600WC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVE47100B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
keypad Jenn Air Range Teacher Jim Oven Repair (including Ranges and Cooktops) 3 06-18-2015 04:07 PM
keypad does not work on Jenn-air range hoodzies Oven Repair (including Ranges and Cooktops) 5 04-29-2015 10:05 AM
ribbon repair gcolsen Refrigerator & Freezer Repair 0 11-22-2010 04:23 PM
Jenn-Air ribbon cable sfjinarl Oven Repair (including Ranges and Cooktops) 0 09-30-2009 04:08 PM
Jenn Air #9 and #0 on keypad do not respond Landman Oven Repair (including Ranges and Cooktops) 1 09-29-2009 03:08 AM
