Discuss
Kenmore 790 series Range F10/F15 errors
 in
I have a Kenmore Electric Range/Oven, Model 79092803015, that recently had a failure. Upon turning the oven off after baking
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore 790 series Range F10/F15 errors
  #1 (permalink)
Old 12-25-2017, 12:36 PM
Junior Member
tieshoe is on a distinguished road
Default Kenmore 790 series Range F10/F15 errors
Model Number: 79092803015   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Electric Range/Oven, Model 79092803015, that recently had a failure. Upon turning the oven off after baking a meal, there was a fizzling sound from behind the control unit and a bit of ash blew out from behind the unit. I checked all the functions of the oven and saw no visible problems. The next day, upon turning on the oven, it gave the error code F10 (check RTD sensor probe, replace EOC). I then removed the back panel, and did a closer inspection of the components and found that the R1 resistor on the circuit board for the EOC had blown up. I checked the temperature sensor (with a meter) and found it's resistance to be correct for room temperature, so assumed the problem was with the EOC. I ordered a new EOC (same part number: 316560127) and replaced. Upon reapplying power to the oven and setting it to bake to test out the new board, after about 10 seconds of attempted preheating, the oven shut down with an F15 error code (Controller Self Check Failed - replace EOC).
So I have a couple of questions:
1. Did I receive a defective replacement EOC? I'd hate to just replace it again and have the same issue.
2. What would have caused the resistor to blow up in the first place (if not in the EOC circuitry), and could this problem reappear? Again, the temperature probe seems to be functioning properly and I did check the heating elements - they too seem to be functioning properly.
Any help is appreciated.
Related Models
Kenmore 79092804010 ELECTRIC RANGE
Kenmore 79092804011 ELECTRIC RANGE
Kenmore 79092804012 ELECTRIC RANGE
Kenmore 79092809010 ELECTRIC RANGE
Kenmore 79092809011 ELECTRIC RANGE
Kenmore 79092809012 ELECTRIC RANGE
Kenmore 79092850300 ELECTRIC RANGE
Kenmore 79092850301 ELECTRIC RANGE
Kenmore 79092850302 ELECTRIC RANGE
Kenmore 79092851300 ELECTRIC RANGE
Kenmore 79092851301 ELECTRIC RANGE
Kenmore 79092851302 ELECTRIC RANGE
Kenmore 79092852300 ELECTRIC RANGE
Kenmore 79092852301 ELECTRIC RANGE
Kenmore 79092852302 ELECTRIC RANGE
Kenmore 79092853300 ELECTRIC RANGE
Kenmore 79092853301 ELECTRIC RANGE
Kenmore 79092853302 ELECTRIC RANGE
Kenmore 79092853303 ELECTRIC RANGE
Kenmore 79092854300 ELECTRIC RANGE
Kenmore 79092854301 ELECTRIC RANGE
Kenmore 79092854302 ELECTRIC RANGE
Kenmore 79092859301 ELECTRIC RANGE
Kenmore 79092859302 ELECTRIC RANGE
Kenmore 79092882300 ELECTRIC RANGE
Kenmore 79092882301 ELECTRIC RANGE
Kenmore 79092882302 ELECTRIC RANGE
Kenmore 79092884300 ELECTRIC RANGE
Kenmore 79092884301 ELECTRIC RANGE
Kenmore 79092884302 ELECTRIC RANGE
Kenmore 79092889300 ELECTRIC RANGE
Kenmore 79092889301 ELECTRIC RANGE
Kenmore 79092889302 ELECTRIC RANGE
Kenmore 79092902010 ELECTRIC RANGE
Kenmore 79092902011 ELECTRIC RANGE
Kenmore 79092902012 ELECTRIC RANGE
Kenmore 79092903010 ELECTRIC RANGE
Kenmore 79092903011 ELECTRIC RANGE
Kenmore 79092903012 ELECTRIC RANGE
Kenmore 79092903013 ELECTRIC RANGE
Kenmore 79092909010 ELECTRIC RANGE
Kenmore 79092909011 ELECTRIC RANGE
Kenmore 79092909012 ELECTRIC RANGE
Kenmore 79093553300 ELECTRIC RANGE
Kenmore 79093553301 ELECTRIC RANGE
Kenmore 79093553302 ELECTRIC RANGE
Kenmore 79093553303 ELECTRIC RANGE
Kenmore 79093671001 ELECTRIC RANGE
Kenmore 79093750100 ELECTRIC RANGE
Kenmore 79093750102 ELECTRIC RANGE
Kenmore 79093750103 ELECTRIC RANGE
Kenmore 79093750104 ELECTRIC RANGE
Kenmore 79093751100 ELECTRIC RANGE
Kenmore 79093751102 ELECTRIC RANGE
Kenmore 79093751103 ELECTRIC RANGE
Kenmore 79093751104 ELECTRIC RANGE
Kenmore 79093752100 ELECTRIC RANGE
Kenmore 79093752101 RANGE
Kenmore 79093752102 ELECTRIC RANGE
Kenmore 79093752103 ELECTRIC RANGE
Kenmore 79093752104 ELECTRIC RANGE
Kenmore 79093754100 ELECTRIC RANGE
Kenmore 79093754101 RANGE
Kenmore 79093754102 ELECTRIC RANGE
Kenmore 79093754103 ELECTRIC RANGE
Kenmore 79093754104 ELECTRIC RANGE
Kenmore 79093761000 RANGE
Kenmore 79093762000 RANGE
Kenmore 79093762001 ELECTRIC RANGE
Kenmore 79093767000 RANGE
Kenmore 79093767001 ELECTRIC RANGE
Kenmore 79093768000 RANGE
Kenmore 79093768001 ELECTRIC RANGE
Kenmore 79093771100 ELECTRIC RANGE
Kenmore 79093772100 ELECTRIC RANGE
Kenmore 79093777100 ELECTRIC RANGE
Kenmore 79093778100 ELECTRIC RANGE
Kenmore 79093850300 ELECTRIC RANGE
Kenmore 79093850301 ELECTRIC RANGE
Kenmore 79093850302 ELECTRIC RANGE
Kenmore 79093850303 ELECTRIC RANGE
Kenmore 79093851300 ELECTRIC RANGE
Kenmore 79093851301 ELECTRIC RANGE
Kenmore 79093851302 ELECTRIC RANGE
Kenmore 79093851303 ELECTRIC RANGE
Kenmore 79093852300 ELECTRIC RANGE
Kenmore 79093852301 ELECTRIC RANGE
Kenmore 79093852302 ELECTRIC RANGE
Kenmore 79093852303 ELECTRIC RANGE
Kenmore 79093853300 ELECTRIC RANGE
Kenmore 79093853301 ELECTRIC RANGE
Kenmore 79093853302 ELECTRIC RANGE
Kenmore 79093853303 ELECTRIC RANGE
Kenmore 79093854300 ELECTRIC RANGE
Kenmore 79093854301 ELECTRIC RANGE
Kenmore 79093854302 ELECTRIC RANGE
Kenmore 79093854303 ELECTRIC RANGE
Kenmore 79093859301 ELECTRIC RANGE
Kenmore 79093859302 ELECTRIC RANGE
Kenmore 79093859303 ELECTRIC RANGE
Kenmore 79094000400 ELECTRIC RANGE
Kenmore 79094000401 ELECTRIC RANGE
Kenmore 79094000402 ELECTRIC RANGE
Kenmore 79094000403 ELECTRIC RANGE
Kenmore 79094001400 ELECTRIC RANGE
Kenmore 79094001401 ELECTRIC RANGE
Kenmore 79094001402 ELECTRIC RANGE
Kenmore 79094001403 ELECTRIC RANGE
Kenmore 79094002600 ELECTRIC RANGE
Kenmore 79094002601 ELECTRIC RANGE
Kenmore 79094012600 ELECTRIC RANGE
Kenmore 79094012601 ELECTRIC RANGE
Kenmore 79094013600 ELECTRIC RANGE
Kenmore 79094013601 ELECTRIC RANGE
Kenmore 79094014600 ELECTRIC RANGE
Kenmore 79094014601 ELECTRIC RANGE
Kenmore 79094019600 ELECTRIC RANGE
Kenmore 79094019601 ELECTRIC RANGE
Kenmore 79094022600 ELECTRIC RANGE
Kenmore 79094022601 ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE5T SUD & F35 Errors - What To Try Next??? Annie515GW Washer Repair 0 01-25-2014 12:49 PM
Kenmore He2+ F01 & F11 errors carter76112 Washer Repair 6 07-22-2013 09:57 AM
Kenmore errors and door locked LorettaNash Oven Repair (including Ranges and Cooktops) 0 11-15-2011 05:04 PM
GE Profile range with F5, F3, F2 errors mpearson88 Oven Repair (including Ranges and Cooktops) 4 01-11-2011 10:32 AM
Kenmore Washing Machine errors Vintagecharms Washer Repair 3 06-10-2009 09:29 AM
