Discuss
Whirlpool top gas oven works for half hour then stop re-igniting
 in
My Whirlpool range Model WGG755S0BS01 top oven pre-heats and reaches the set 400 degrees temperature. The oven cycles on and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool top gas oven works for half hour then stop re-igniting
  #1 (permalink)
Old 12-21-2017, 07:49 PM
Junior Member
Nakhle is on a distinguished road
Question Whirlpool top gas oven works for half hour then stop re-igniting
Model Number: WGG755S0BS01   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool range Model WGG755S0BS01 top oven pre-heats and reaches the set 400 degrees temperature. The oven cycles on and off and maintain the set 400 deg. temperature inside the oven for about 35 minutes. After 35 minutes of normal operation, and even though the digital display still shows the set temperature is 400 degrees and the bake light is on, the temperature inside oven drops. Once temperature drops the ignitor glows and stays on but the oven does not start. No gas smell is observed or identified.
If I cancel bake, and re-start the bake process again, the oven starts and the 35 minute process repeat again.
Please note that even after installing a new Clock Control board and a new oven ignitor, the top oven did the same thing and nothing change. The oven works normally for about 35 minutes maintaining the 400 degrees then stops heating.
Please help and suggest.
Related Models
Whirlpool WGP30802 30" Electric Range Coil Cooktop
Whirlpool WGP32801 30" Electric Range Self Clean Oven
Whirlpool WGP34804 30" Electric Range Self Clean Oven
Whirlpool WGP34805 30" Electric Range Self Clean Oven
Whirlpool WGP34904 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Whirlpool WGP34905 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
White Westinghouse WGQ332HS1 GAS DRYER
White Westinghouse WGR211ES0 White Westinghouse/dryer
White Westinghouse WGR211ES1 DRYER
White Westinghouse WGR211ES2 DRYER
White Westinghouse WGR242AQ2 White Westinghouse/gas Dryer
White Westinghouse WGR242AQ3 White Westinghouse/gas Dryer
White Westinghouse WGR242AS2 White Westinghouse/gas Dryer
White Westinghouse WGR242AS3 White Westinghouse/gas Dryer
White Westinghouse WGR242AS4 White Westinghouse/dryer
White Westinghouse WGR242AS5 White Westinghouse/dryer
Whirlpool WGT3300SQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300SQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300SQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300XQ0 LAUNDRY SYSTEM
General Electric WHDRE526E1WW Washer
General Electric WHDRE526E6WW Washer
General Electric WHDRR418E1WW Washer
General Electric WHDRR418E3WW Washer
General Electric WHDRR418E4WW Washer
General Electric WHDRR418E5WW Washer
General Electric WHDRR418E6WW Washer
General Electric WHDRR418G0WW Washer
General Electric WHDRR418G1WW WASHER
General Electric WHDRR418G2WW WASHER
General Electric WHDRR418G3WW WASHER
General Electric WHDRR418G4WW WASHER
General Electric WHDRR418G5WW WASHER
General Electric WHDRR418G6WW WASHER
General Electric WHDSE820C0WW Washer
General Electric WHDSE820C1WW Washer
General Electric WHDSE820C9WW Washer
General Electric WHDSR109J5WW WASHER
General Electric WHDSR109J6WW WASHER
General Electric WHDSR109J7WW WASHER
General Electric WHDSR109J8WW WASHER
General Electric WHDSR109J9WW WASHER
General Electric WHDSR209D0WW Washer
General Electric WHDSR209D1WW Washer
General Electric WHDSR209D3WW Washer
General Electric WHDSR209D4WW Washer
General Electric WHDSR209D5WW Washer
General Electric WHDSR209D6WW Washer
General Electric WHDSR209D7WW Washer
General Electric WHDSR209DAWW Washer
General Electric WHDSR209DBWW Washer
General Electric WHDSR209DCWW Washer
General Electric WHDSR209DDWW Washer
General Electric WHDSR209G0WW Washer
General Electric WHDSR209G2WW Washer
General Electric WHDSR209G3WW WASHER
General Electric WHDSR209G8WW WASHER
General Electric WHDSR209G9WW WASHER
General Electric WHDSR315D0WW Washer
General Electric WHDSR315D5WW Washer
General Electric WHDSR315DAWW Washer
General Electric WHDSR315DBWW Washer
General Electric WHDSR315DCWW Washer
General Electric WHDSR315DDWW WASHER
General Electric WHDSR316G0WW Washer
General Electric WHDSR316G1WW WASHER
General Electric WHDSR316G2WW WASHER
General Electric WHDSR316G3WW WASHER
General Electric WHDSR316G4WW WASHER
General Electric WHDSR316G5WW WASHER
General Electric WHDSR316G6WW WASHER
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH626H1GG WASHER
General Electric WHDVH626H1WW WASHER
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0MB WASHER
General Electric WHDVH660H0MS WASHER
General Electric WHDVH660H0WW Washer
General Electric WHDVH660H1BB WASHER
General Electric WHDVH660H1GG WASHER
General Electric WHDVH660H1MB WASHER
General Electric WHDVH660H1MS WASHER
General Electric WHDVH660H1WW WASHER
General Electric WHDVH680J0BB WASHER
General Electric WHDVH680J0GG WASHER
General Electric WHDVH680J0MB WASHER
General Electric WHDVH680J0MR WASHER
General Electric WHDVH680J0MS WASHER
General Electric WHDVH680J0WW WASHER
General Electric WHDVH680J1MR WASHER
General Electric WHDVH680J1MS WASHER
General Electric WHDVH680J1WW WASHER
Whirlpool WHE33311 30" Electric Range
Whirlpool WHE383311 30" ELECTRIC RANGE COOKTOP
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer works fine, but only half of refrigerator works, other half is frozen w/ ice Ctelfer127 Refrigerator & Freezer Repair 0 08-27-2015 09:53 PM
Oven works but keeps re-igniting JD6557 Oven Repair (including Ranges and Cooktops) 0 01-22-2012 10:32 AM
dryer runs then shuts of and won't start for half an hour skilroy Dryer Repair 1 02-12-2011 02:13 AM
