Discuss
Frigidaire Gas Range
 in
Hello, I am running into an odd error and I am hoping someone can help or has run into this.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Gas Range
  #1 (permalink)
Old 12-20-2017, 10:10 AM
Junior Member
ChrisL1972 is on a distinguished road
Default Frigidaire Gas Range
Model Number: FGF348KCF   Brand: Frigidaire   Age: 1 - 5 years
Hello,
I am running into an odd error and I am hoping someone can help or has run into this. I have a 5 burner stove-top and the center burner (Large one) is having an issue lighting the burner with the electronic starter. I have taken the gas distributor apart and gave it a good cleaning and now if I hold a flame to it, it will light fully. The issue is when I use the spark ignitor, it won't start the burner (I do see a spark) but then the clock on the stove goes to a "0" display and resets to blinking 12:00 after 5-7 seconds. I believe it may be a grounding issue with the center ignitor as it doesn't do this with any of the other burners and they also light fine. I have done a bit of research but I haven't found this exact error. I am hoping your forums will save the day. Thanks for your time.
Related Models
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
Frigidaire FGF348KSB GAS RANGE
Frigidaire FGF348KSC GAS RANGE
Frigidaire FGF348KSD GAS RANGE
Frigidaire FGF348KSE GAS RANGE
Frigidaire FGF348KSF GAS RANGE
Frigidaire FGF348KSG GAS RANGE
Frigidaire FGF348KSH GAS RANGE
Frigidaire FGF348KSJ GAS RANGE
Frigidaire FGF350BBDA Frg(v1) / Gas Range
Frigidaire FGF350BBDB Frg(v1) / Gas Range
Frigidaire FGF350BBDC Frg(v1) / Gas Range
Frigidaire FGF350BBDD Frg(v2) / Gas Range
Frigidaire FGF350BBDE Frg(v1) / Gas Range
Frigidaire FGF350BBWA Frg(v2) / Gas Range
Frigidaire FGF350BBWB Frg(v2) / Gas Range
Frigidaire FGF350BBWC Frg(v3) / Gas Range
Frigidaire FGF350BBWD Frg(v4) / Gas Range
Frigidaire FGF350BBWE Frg(v2) / Gas Range
Frigidaire FGF350BFDA Frg(v1) / Gas Range
Frigidaire FGF350BFWA Frg(v2) / Gas Range
Frigidaire FGF350MXASA Frigidaire/gas Range
Frigidaire FGF350MXASB Frigidaire/gas Range
Frigidaire FGF351SGWA Frg(v0) / Gas Range
Frigidaire FGF351SGWB Frg(v0) / Gas Range
Frigidaire FGF351SGWC Frg(v0) / Gas Range
Frigidaire FGF352SBDA Frg(v1) / Gas Range
Frigidaire FGF352SBDB Frg(v1) / Gas Range
Frigidaire FGF352SBDC Frg(v1) / Gas Range
Frigidaire FGF352SBDD Frg(v2) / Gas Range
Frigidaire FGF352SBDE Frg(v1) / Gas Range
Frigidaire FGF352SBWA Frg(v2) / Gas Range
Frigidaire FGF352SBWB Frg(v2) / Gas Range
Frigidaire FGF352SBWC Frg(v3) / Gas Range
Frigidaire FGF352SBWD Frg(v4) / Gas Range
Frigidaire FGF352SBWE Frg(v2) / Gas Range
Frigidaire FGF353BADA Frg(v2) / Gas Range
Frigidaire FGF353BADB Frg(v1) / Gas Range
Frigidaire FGF353BADC Frg(v1) / Gas Range
Frigidaire FGF353BADD Frg(v2) / Gas Range
Frigidaire FGF353BADE Frg(v1) / Gas Range
Frigidaire FGF353BADF Frg(v1) / Gas Range
Frigidaire FGF353BADG Frg(v1) / Gas Range
Frigidaire FGF353BADH Frg(v1) / Gas Range
Frigidaire FGF353BADJ Frg(v1) / Gas Range
Frigidaire FGF353BAWA Frg(v1) / Gas Range
Frigidaire FGF353BAWB Frg(v2) / Gas Range
Frigidaire FGF353BAWC Frg(v3) / Gas Range
Frigidaire FGF353BAWD Frg(v4) / Gas Range
Frigidaire FGF353BAWE Frg(v2) / Gas Range
Frigidaire FGF353BAWF Frg(v2) / Gas Range
Frigidaire FGF353BAWG Frg(v2) / Gas Range
Frigidaire FGF353BAWH Frg(v2) / Gas Range
Frigidaire FGF353BAWJ Frg(v2) / Gas Range
Frigidaire FGF353CASA Frg(v1) / Gas Range
Frigidaire FGF353CASB Frg(v1) / Gas Range
Frigidaire FGF353CASC Frg(v1) / Gas Range
Frigidaire FGF353CASD Frg(v2) / Gas Range
Frigidaire FGF353CASE Frg(v3) / Gas Range
Frigidaire FGF353CASF Frg(v3) / Gas Range
Frigidaire FGF353CASG Frg(v3) / Gas Range
Frigidaire FGF353CASH Frg(v0) / Range
Frigidaire FGF353CASJ Frg/gas Range
Frigidaire FGF353CATA Frg(v1) / Gas Range
Frigidaire FGF353CATB Frg(v2) / Gas Range
Frigidaire FGF353CATC Frg(v3) / Gas Range
Frigidaire FGF353CATD Frg(v4) / Gas Range
Frigidaire FGF353CATE Frg(v4) / Gas Range
Frigidaire FGF353CATF Frg(v4) / Gas Range
Frigidaire FGF353CATG Frg(v4) / Gas Range
Frigidaire FGF354BGDA Frg(v1) / Gas Range
Frigidaire FGF354BGDB Frg(v2) / Gas Range
Frigidaire FGF354BGDC Frg(v1) / Gas Range
Frigidaire FGF354BGDD GAS RANGE
Frigidaire FGF354BGDE GAS RANGE
Frigidaire FGF354BGDF Frigidaire/gas Range
Frigidaire FGF354BGWA Frg(v3) / Gas Range
Frigidaire FGF354BGWB Frg(v4) / Gas Range
Frigidaire FGF354BGWC Frg(v2) / Gas Range
Frigidaire FGF354BGWD GAS RANGE
Frigidaire FGF354BGWE GAS RANGE
Frigidaire FGF354BGWF Frigidaire/gas Range
Frigidaire FGF355ASA Frigidaire/gas Range
Frigidaire FGF355ASB Frigidaire/gas Range
Frigidaire FGF355ASC Frigidaire/gas Range
Frigidaire FGF355ASD Frigidaire/gas Range
Frigidaire FGF355ASE Frigidaire/gas Range
Frigidaire FGF355ASG Frigidaire/gas Range
Frigidaire FGF355ASH Frigidaire/gas Range
Frigidaire FGF355AUA Frigidaire/range
Frigidaire FGF355AUC Frigidaire/gas Range
Frigidaire FGF355AUD Frigidaire/gas Range
Frigidaire FGF355AUE Frigidaire/gas Range
Frigidaire FGF355AUG Frigidaire/gas Range
Frigidaire FGF355AUH Frigidaire/gas Range
Frigidaire FGF355AWA Frigidaire/range
Frigidaire FGF355AWC Frigidaire/gas Range
Frigidaire FGF355AWD Frigidaire/gas Range
Frigidaire FGF355AWE Frigidaire/gas Range
Frigidaire FGF355AWG Frigidaire/gas Range
Frigidaire FGF355AWH Frigidaire/gas Range
Frigidaire FGF355BXAWA Frigidaire/gas Range
Frigidaire FGF355CGBA Frg(v1) / Gas Range
Frigidaire FGF355CGBB Frg(v2) / Gas Range
Frigidaire FGF355CGBC Frg(v1) / Gas Range
Frigidaire FGF355CGBD Frg(v2) / Gas Range
Frigidaire FGF355CGBE Frigidaire/gas Range
Frigidaire FGF355CGBF Frigidaire/gas Range
Frigidaire FGF355CGBG Frigidaire/gas Range
Frigidaire FGF355CGSA Frg(v3) / Gas Range
Frigidaire FGF355CGSB Frg(v4) / Gas Range
Frigidaire FGF355CGSC Frg(v3) / Gas Range
Frigidaire FGF355CGSD Frg(v4) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire range bobhuff Oven Repair (including Ranges and Cooktops) 0 09-30-2014 02:24 PM
Frigidaire Range sweeney Oven Repair (including Ranges and Cooktops) 0 08-15-2010 01:32 PM
Frigidaire Range dtrumbll4 Oven Repair (including Ranges and Cooktops) 1 04-30-2010 04:37 AM
Help With Frigidaire Gas Range! rcoffee2 Oven Repair (including Ranges and Cooktops) 0 12-08-2009 04:59 PM
Frigidaire Range Stevevo Oven Repair (including Ranges and Cooktops) 1 11-05-2009 05:53 AM
