My oven started having problems heating. Sometimes it won't heat, sometimes it will heat to a certain temp and stop. Sometimes it will work. I replaced the oven control module with a used unit from ******** and have exactly the same problem. I measured resitance on the baking element and it is good. I have not tested the temp sensor, but it does measure the temp on the display correctly. Is there any other component in the oven that can cause this problem?
