Discuss
GE Oven overheats only in BAKE mode not convection
 in
GE Oven ZET1PL1SS Overheating only when started in BAKE mode. Problem: Overheats and fluctuates in ~385 to 435F range ONLY
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven overheats only in BAKE mode not convection
  #1 (permalink)
Old 12-13-2017, 01:01 PM
Junior Member
mawinter is on a distinguished road
Default GE Oven overheats only in BAKE mode not convection
Model Number: ZET1PL1SS   Brand: GE   Age: 5 - 10 years
Problem:
Overheats and fluctuates in ~385 to 435F range ONLY when STARTING oven in BAKE mode @350
Works good when started in other Convection Modes (set 350 = actual ~350) or OK if changed to BAKE mode 350 without shutting oven off (set 350 => actual 355-360F) after starting (preheating in Convection mode).
But if oven shut off and restarted after fully up to temp in BAKE mode @ 350 it again overheats and fluctuates in ~385 to 435F range.
No error codes. All elements and temp sensor ohms OK with minor exception, inner Broil measures 23.8 ohms vs 21.34 spec +/- 10% but it heats OK. Relays all at proper power when running in each of the 9 Test modes. All fans working but cooling fan runs on high in step #3 & #5 when broil and convection elements on but when cooling fan not specified. Cooling fan also runs at proper speed when specified in test steps #7 & #9
Temp sensor replaced WB21X22134, Temp encoder replaced WB27T10820, and main logic board replaced WB27T10819 with no change to problem.
Got any ideas what might be going on or what to do next?
Related Models
General Electric ZET1PL1SS Electric range
General Electric ZET1PM1SS ELECTRIC OVEN
General Electric ZET1PM2SS ELECTRIC OVEN
General Electric ZET1PM3SS ELECTRIC OVEN
General Electric ZET1RM1SS ELECTRIC OVEN
General Electric ZET1RM2SS ELECTRIC OVEN
General Electric ZET1RM3SS ELECTRIC OVEN
General Electric ZET1SL1SS Electric range
General Electric ZET1SM1SS ELECTRIC OVEN
General Electric ZET1SM2SS ELECTRIC OVEN
General Electric ZET1SM3SS ELECTRIC OVEN
General Electric ZET2PL1SS Electric range
General Electric ZET2PM1SS ELECTRIC OVEN
General Electric ZET2PM2SS ELECTRIC OVEN
General Electric ZET2PM3SS ELECTRIC OVEN
General Electric ZET2RM1SS WALL OVEN
General Electric ZET2RM2SS ELECTRIC OVEN
General Electric ZET2RM3SS ELECTRIC OVEN
General Electric ZET2SL1SS Electric range
General Electric ZET2SM1SS ELECTRIC OVEN
General Electric ZET2SM2SS ELECTRIC OVEN
General Electric ZET2SM3SS ELECTRIC OVEN
General Electric ZET3038BH1BB Electric range
General Electric ZET3038BH2BB Electric range
General Electric ZET3038BH3BB Electric range
General Electric ZET3038SH1SS Electric range
General Electric ZET3038SH2SS Electric range
General Electric ZET3038SH3SS Electric range
General Electric ZET3038WH1WW Electric range
General Electric ZET3038WH2WW Electric range
General Electric ZET3038WH3WW Electric range
General Electric ZET3058BH1BB Electric range
General Electric ZET3058BH2BB Electric range
General Electric ZET3058BH3BB Electric range
General Electric ZET3058BH4BB ELECTRIC OVEN
General Electric ZET3058SH1SS Electric range
General Electric ZET3058SH2SS Electric range
General Electric ZET3058SH3SS Electric range
General Electric ZET3058SH4SS ELECTRIC OVEN
General Electric ZET3058WH1WW Electric range
General Electric ZET3058WH2WW Electric range
General Electric ZET3058WH3WW Electric range
General Electric ZET736GV1BB Electric range
General Electric ZET737BA1BB Electric range
General Electric ZET737BA2BB Electric range
General Electric ZET737BA3BB Electric range
General Electric ZET737BA4BB Electric range
General Electric ZET737BA5BB Electric range
General Electric ZET737BD1BB Electric range
General Electric ZET737BW1BB Electric range
General Electric ZET737BW2BB Electric range
General Electric ZET737WA1WW Electric range
General Electric ZET737WA2WW Electric range
General Electric ZET737WA3WW Electric range
General Electric ZET737WA4WW Electric range
General Electric ZET737WA5WW Electric range
General Electric ZET737WD1WW Electric range
General Electric ZET737WV1WW Electric range
General Electric ZET737WW1WW Electric range
General Electric ZET737WW2WW Electric range
General Electric ZET756GV1BB Electric range
General Electric ZET757BA1BB Electric range
General Electric ZET757BA2BB Electric range
General Electric ZET757BA3BB Electric range
General Electric ZET757BA4BB Electric range
General Electric ZET757BA5BB Electric range
General Electric ZET757BD1BB Electric range
General Electric ZET757BW1BB Electric range
General Electric ZET757BW2BB Electric range
General Electric ZET757WA1WW Electric range
General Electric ZET757WA2WW Electric range
General Electric ZET757WA3WW Electric range
General Electric ZET757WA4WW Electric range
General Electric ZET757WA5WW Electric range
General Electric ZET757WD1WW Electric range
General Electric ZET757WV1WW Electric range
General Electric ZET757WW1WW Electric range
General Electric ZET757WW2WW Electric range
General Electric ZET837BB2BB Electric range
General Electric ZET837BB3BB Electric range
General Electric ZET837BBBB Electric range
General Electric ZET837BYBB Electric range
General Electric ZET837DB2SB Electric range
General Electric ZET837DB3SB Electric range
General Electric ZET837DBSB Electric range
General Electric ZET837DYSB Electric range
General Electric ZET837SB2SS Electric range
General Electric ZET837SB3SS Electric range
General Electric ZET837SBSS Electric range
General Electric ZET837SYSS Electric range
General Electric ZET837WB2WW Electric range
General Electric ZET837WB3WW Electric range
General Electric ZET837WBWW Electric range
General Electric ZET837WYWW Electric range
General Electric ZET857BB2BB Electric range
General Electric ZET857BB3BB Electric range
General Electric ZET857BBBB Electric range
General Electric ZET857BYBB Electric range
General Electric ZET857DB2SB Electric range
General Electric ZET857DB3SB Electric range
General Electric ZET857DBSB Electric range
General Electric ZET857DYSB Electric range
General Electric ZET857SB2SS Electric range
General Electric ZET857SB3SS Electric range
General Electric ZET857SBSS Electric range
General Electric ZET857SYSS Electric range
General Electric ZET857WB2WW Electric range
General Electric ZET857WB3WW Electric range
General Electric ZET857WBWW Electric range
General Electric ZET857WYWW Electric range
General Electric ZET938BF1BB Electric range
General Electric ZET938BF2BB Electric range
General Electric ZET938BF3BB Electric range
General Electric ZET938BF4BB Electric range
General Electric ZET938BF5BB Electric range
General Electric ZET938BF6BB Electric range
General Electric ZET938BM1BB ELECTRIC WALL OVEN
General Electric ZET938BM2BB ELECTRIC OVEN
General Electric ZET938SF1SS Electric range
General Electric ZET938SF2SS Electric range
  #2 (permalink)
Old 12-19-2017, 09:19 AM
Junior Member
Default No replies so far - Any ideas why temp so variable?
No replies so far. Anybody got an idea why the temp is so variable?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave/Convection/Hood wont heat in convection mode RICKVESPA Microwave Repair 0 12-08-2014 12:44 PM
Broiler element not working on Broil mode but works on Bake mode? Bake yadog Oven Repair (including Ranges and Cooktops) 2 03-01-2014 03:38 AM
Bosch oven bake and convection bake not heating tbnicky Oven Repair (including Ranges and Cooktops) 1 07-27-2010 08:25 PM
convection microwave overheats jmuegge Microwave Repair 0 03-15-2008 10:49 PM
Dacor Oven / Pure convection mode GOP Oven Repair (including Ranges and Cooktops) 3 11-20-2007 06:25 PM
