Discuss
Maytag Small burner issue
 in
My mother has a Maytag electric range. Model CRE9800CCE. The left front small 6" burner had burned out and I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Small burner issue
  #1 (permalink)
Old 12-04-2017, 12:22 PM
Junior Member
bobcat7131 is on a distinguished road
Default Maytag Small burner issue
Model Number: CRE9800CCE   Brand: Maytag   Age: 5 - 10 years
My mother has a Maytag electric range. Model CRE9800CCE. The left front small 6" burner had burned out and I replaced it with a new burner. After repair turning range burner on it will only heat on high now. I assumed the infinite switch had also had a problem so it was then replaced with a new switch. Burner still heats only on high. I'm stumped.
Related Models
Maytag CRE9800CCE RANGE- S/C F/S ELE
Maytag CRE9800CCM RANGE- S/C F/S ELE
Maytag CRE9800CDB RANGE- S/C F/S ELE
Maytag CRE9800CDE RANGE- S/C F/S ELE
Maytag CRE9800DDB RANGE- S/C F/S ELE
Maytag CRE9800DDE RANGE- S/C F/S ELE
Maytag CRE9800DDM RANGE- S/C F/S ELE
Maytag CRE9830BCB RANGE- S/C F/S ELE
Maytag CRE9830BCE RANGE- S/C F/S ELE
Maytag CRE9830BCM RANGE- S/C F/S ELE
Maytag CRE9830CDB RANGE- S/C F/S ELE
Maytag CRE9830CDE RANGE- S/C F/S ELE
Maytag CRE9830CDM RANGE- S/C F/S ELE
Maytag CRE9900ACB RANGE- S/C F/S ELE
Maytag CRE9900ACE RANGE- S/C F/S ELE
Admiral CREA200ACL RANGE- F/S STD ELE
Admiral CREA200ACW RANGE- F/S STD ELE
Admiral CREA300ACL RANGE- F/S STD ELE
Admiral CREA300ACW RANGE- F/S STD ELE
Admiral CREA400ACL RANGE- F/S STD ELE
Admiral CREA400ACW RANGE- F/S STD ELE
Admiral CREA450ACL RANGE- F/S STD ELE
Admiral CREA450ACW RANGE- F/S STD ELE
Admiral CREA600ACE RANGE- S/C F/S ELE
Admiral CREA600ACL RANGE- S/C F/S ELE
Admiral CREA600ACW RANGE- S/C F/S ELE
Admiral CREA650ACB RANGE- S/C F/S ELE
Admiral CREA650ACL RANGE- S/C F/S ELE
Admiral CREA650ACW RANGE- S/C F/S ELE
Admiral CREA750ACB RANGE- S/C F/S ELE
Admiral CREA750ACE RANGE- S/C F/S ELE
Admiral CREA750ACM RANGE- S/C F/S ELE
Frigidaire CREF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CREF342AS1 Dryer - Frig/best Buy
Frigidaire CREF342AS2 Frigidaire/electric Dryer
Crosley CREF366FBA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FCA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FSA BRADA CANADA/ELECTRIC RANGE
Frigidaire CRER442AS0 Dryer - Frig/best Buy
Frigidaire CRER442AS1 Dryer - Frig/best Buy
Frigidaire CRER442AS2 Dryer - Frig/best Buy
Frigidaire CRER5700AS0 Dryer - Frig/best Buy
Frigidaire CRER5700AS1 Frigidaire/electric Dryer
Frigidaire CRER7900AS0 Dryer - Frig/best Buy
Frigidaire CRER7900AS1 Frigidaire/electric Dryer
Maytag CRG0560AAW Range - F/s Std Gas
Maytag CRG0760AAL RANGE- S/C F/S GAS
Maytag CRG0760AAW RANGE- S/C F/S GAS
Maytag CRG0860AAL RANGE- S/C F/S GAS
Maytag CRG0860AAW RANGE- S/C F/S GAS
Maytag CRG200 RANGE- F/S STD GAS
Maytag CRG200B RANGE- F/S STD GAS
Maytag CRG300 RANGE- F/S STD GAS
Maytag CRG300B RANGE- F/S STD GAS
Maytag CRG305 RANGE- F/S STD GAS
Maytag CRG350 RANGE- F/S STD GAS
Maytag CRG350B RANGE- F/S STD GAS
Maytag CRG355 RANGE- F/S STD GAS
Maytag CRG382 RANGE- F/S STD GAS
Maytag CRG383 RANGE- F/S STD GAS
Maytag CRG400 RANGE- F/S STD GAS
Maytag CRG400B RANGE- F/S STD GAS
Maytag CRG405 RANGE-F/S CONT CLEAN GAS
Maytag CRG500 RANGE- F/S STD GAS
Maytag CRG501 RANGE- F/S STD GAS
Maytag CRG502 RANGE- F/S STD GAS
Maytag CRG505 RANGE- F/S STD GAS
Maytag CRG560 RANGE- F/S STD GAS
Maytag CRG560A RANGE- F/S STD GAS
Maytag CRG583 RANGE-F/S CONT CLEAN GAS
Maytag CRG600 RANGE- F/S STD GAS
Maytag CRG601 RANGE- F/S STD GAS
Maytag CRG602 RANGE-F/S CONT CLEAN GAS
Maytag CRG700 RANGE- S/C F/S GAS
Maytag CRG705 RANGE- S/C F/S GAS
Maytag CRG7400AAL RANGE- F/S STD GAS
Maytag CRG7400AAW RANGE- F/S STD GAS
Maytag CRG7400BAL RANGE- F/S STD GAS
Maytag CRG7400BAW RANGE- F/S STD GAS
Maytag CRG7400CAE RANGE- F/S STD GAS
Maytag CRG7400CAL RANGE- F/S STD GAS
Maytag CRG7400CAW RANGE- F/S STD GAS
Maytag CRG750 RANGE- S/C F/S GAS
Maytag CRG7500AAE RANGE- F/S STD GAS
Maytag CRG7500AAL RANGE- F/S STD GAS
Maytag CRG7500AAW RANGE- F/S STD GAS
Maytag CRG7500CAE RANGE- F/S STD GAS
Maytag CRG7500CAL RANGE- F/S STD GAS
Maytag CRG7500CAW RANGE- F/S STD GAS
Admiral CRG7500CGE RANGE- F/S STD GAS
Admiral CRG7500CGW RANGE- F/S STD GAS
Maytag CRG755 RANGE- S/C F/S GAS
Maytag CRG760 RANGE- S/C F/S GAS
Maytag CRG7600AAL RANGE-F/S CONT CLEAN GAS
Maytag CRG7600AAW RANGE-F/S CONT CLEAN GAS
Maytag CRG760A RANGE- S/C F/S GAS
Maytag CRG7700AAL RANGE- F/S STD GAS
Maytag CRG7700AAW RANGE- F/S STD GAS
Maytag CRG7700BAL RANGE- F/S STD GAS
Maytag CRG7700BAW RANGE- F/S STD GAS
Maytag CRG7700CAL RANGE- F/S STD GAS
Maytag CRG7700CAW RANGE- F/S STD GAS
Maytag CRG783 RANGE- S/C F/S GAS
Maytag CRG800 RANGE- S/C F/S GAS
Maytag CRG805 RANGE- S/C F/S GAS
Maytag CRG8200AAL RANGE- F/S STD GAS
Maytag CRG8200AAW RANGE- F/S STD GAS
Maytag CRG8200BAL RANGE- F/S STD GAS
Maytag CRG8200BAW RANGE- F/S STD GAS
Maytag CRG8200CAL RANGE- F/S STD GAS
Maytag CRG8200CAW RANGE- F/S STD GAS
Maytag CRG8400AAL RANGE- F/S STD GAS
Maytag CRG8400AAW RANGE- F/S STD GAS
Maytag CRG860 RANGE- S/C F/S GAS
Maytag CRG8600AAB RANGE- S/C F/S GAS
Maytag CRG8600AAL RANGE- S/C F/S GAS
Maytag CRG8600AAW RANGE- S/C F/S GAS
Maytag CRG8600BAB RANGE- S/C F/S GAS
Maytag CRG8600BAL RANGE- S/C F/S GAS
Maytag CRG8600BAW RANGE- S/C F/S GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gemini burner issue Krabby Oven Repair (including Ranges and Cooktops) 2 11-26-2015 03:55 AM
Maytag Gemini burner issue Krabby Oven Repair (including Ranges and Cooktops) 0 11-18-2015 11:54 AM
Dual burner has only small burner working bobmorris13@comcast.net Oven Repair (including Ranges and Cooktops) 3 06-03-2010 11:45 PM
My cooktop leaks gas from small burner vpalkonda Oven Repair (including Ranges and Cooktops) 0 08-27-2009 01:02 PM
replacing small burner element of smooth top stove CERushing Oven Repair (including Ranges and Cooktops) 0 05-09-2009 09:15 AM
