Discuss
Confused about replacing oven igniter Frigidaire
 in
I'm a little confused because what I'm looking at doesn't match up with what I've seen in online guides. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Confused about replacing oven igniter Frigidaire
  #1 (permalink)
Old 12-04-2017, 10:24 AM
Junior Member
artemis is on a distinguished road
Default Confused about replacing oven igniter Frigidaire
Model Number: FGF337ECD   Brand: Frigidaire   Age: More than 10 years
I'm a little confused because what I'm looking at doesn't match up with what I've seen in online guides. I bought a replacement igniter. I thought it would lead to the back where there is a plastic connector. However, I've got multiple wires running back there. Do I just cut the two coming from the existing igniter and splice them with the nuts? Does it matter which is which?
Related Models
Frigidaire FGF337ECD Frigidaire/range
Frigidaire FGF337ESA Frigidaire/gas Range
Frigidaire FGF337ESC Frigidaire/gas Range
Frigidaire FGF337ESD Frigidaire/range
Frigidaire FGF337EUA Frigidaire/gas Range
Frigidaire FGF337EUC Frigidaire/gas Range
Frigidaire FGF337EUD Frigidaire/range
Frigidaire FGF337EWA Frigidaire/gas Range
Frigidaire FGF337EWC Frigidaire/gas Range
Frigidaire FGF337EWD Frigidaire/range
Frigidaire FGF337GBA Frigidaire/range
Frigidaire FGF337GBB GAS RANGE
Frigidaire FGF337GBC GAS RANGE
Frigidaire FGF337GBD GAS RANGE
Frigidaire FGF337GBE GAS RANGE
Frigidaire FGF337GBF GAS RANGE
Frigidaire FGF337GBG GAS RANGE
Frigidaire FGF337GCA Frigidaire/range
Frigidaire FGF337GCB GAS RANGE
Frigidaire FGF337GCC GAS RANGE
Frigidaire FGF337GCD GAS RANGE
Frigidaire FGF337GCE GAS RANGE
Frigidaire FGF337GCF GAS RANGE
Frigidaire FGF337GCG GAS RANGE
Frigidaire FGF337GCH GAS RANGE
Frigidaire FGF337GCJ GAS RANGE
Frigidaire FGF337GCK GAS RANGE
Frigidaire FGF337GSA Frigidaire/range
Frigidaire FGF337GSB GAS RANGE
Frigidaire FGF337GSC GAS RANGE
Frigidaire FGF337GSD GAS RANGE
Frigidaire FGF337GSE GAS RANGE
Frigidaire FGF337GSF GAS RANGE
Frigidaire FGF337GSG GAS RANGE
Frigidaire FGF337GUA Frigidaire/range
Frigidaire FGF337GUB GAS RANGE
Frigidaire FGF337GUC GAS RANGE
Frigidaire FGF337GUD GAS RANGE
Frigidaire FGF337GUE GAS RANGE
Frigidaire FGF337GUF GAS RANGE
Frigidaire FGF337GWA Frigidaire/range
Frigidaire FGF337GWB GAS RANGE
Frigidaire FGF337GWC GAS RANGE
Frigidaire FGF337GWD GAS RANGE
Frigidaire FGF337GWE GAS RANGE
Frigidaire FGF337GWF GAS RANGE
Frigidaire FGF343BADA Frg(v2) / Gas Range
Frigidaire FGF343BADB Frg(v3) / Gas Range
Frigidaire FGF343BAWA Frg(v1) / Gas Range
Frigidaire FGF343BAWB Frg(v4) / Gas Range
Frigidaire FGF345BHWA Frg(v4) / Gas Range
Frigidaire FGF345BHWB Frigidaire/gas Range
Frigidaire FGF345BHWC Frigidaire/gas Range
Frigidaire FGF345GSA GAS RANGE
Frigidaire FGF345GSB GAS RANGE
Frigidaire FGF345GSC GAS RANGE
Frigidaire FGF345GSD GAS RANGE
Frigidaire FGF348KBA GAS RANGE
Frigidaire FGF348KBB GAS RANGE
Frigidaire FGF348KCA GAS RANGE
Frigidaire FGF348KCB GAS RANGE
Frigidaire FGF348KCC GAS RANGE
Frigidaire FGF348KCD GAS RANGE
Frigidaire FGF348KCE GAS RANGE
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
Frigidaire FGF348KSB GAS RANGE
Frigidaire FGF348KSC GAS RANGE
Frigidaire FGF348KSD GAS RANGE
Frigidaire FGF348KSE GAS RANGE
Frigidaire FGF348KSF GAS RANGE
Frigidaire FGF348KSG GAS RANGE
Frigidaire FGF348KSH GAS RANGE
Frigidaire FGF348KSJ GAS RANGE
Frigidaire FGF350BBDA Frg(v1) / Gas Range
Frigidaire FGF350BBDB Frg(v1) / Gas Range
Frigidaire FGF350BBDC Frg(v1) / Gas Range
Frigidaire FGF350BBDD Frg(v2) / Gas Range
Frigidaire FGF350BBDE Frg(v1) / Gas Range
Frigidaire FGF350BBWA Frg(v2) / Gas Range
Frigidaire FGF350BBWB Frg(v2) / Gas Range
Frigidaire FGF350BBWC Frg(v3) / Gas Range
Frigidaire FGF350BBWD Frg(v4) / Gas Range
Frigidaire FGF350BBWE Frg(v2) / Gas Range
Frigidaire FGF350BFDA Frg(v1) / Gas Range
Frigidaire FGF350BFWA Frg(v2) / Gas Range
Frigidaire FGF350MXASA Frigidaire/gas Range
Frigidaire FGF350MXASB Frigidaire/gas Range
Frigidaire FGF351SGWA Frg(v0) / Gas Range
Frigidaire FGF351SGWB Frg(v0) / Gas Range
Frigidaire FGF351SGWC Frg(v0) / Gas Range
Frigidaire FGF352SBDA Frg(v1) / Gas Range
Frigidaire FGF352SBDB Frg(v1) / Gas Range
Frigidaire FGF352SBDC Frg(v1) / Gas Range
Frigidaire FGF352SBDD Frg(v2) / Gas Range
Frigidaire FGF352SBDE Frg(v1) / Gas Range
Frigidaire FGF352SBWA Frg(v2) / Gas Range
Frigidaire FGF352SBWB Frg(v2) / Gas Range
Frigidaire FGF352SBWC Frg(v3) / Gas Range
Frigidaire FGF352SBWD Frg(v4) / Gas Range
Frigidaire FGF352SBWE Frg(v2) / Gas Range
Frigidaire FGF353BADA Frg(v2) / Gas Range
Frigidaire FGF353BADB Frg(v1) / Gas Range
Frigidaire FGF353BADC Frg(v1) / Gas Range
Frigidaire FGF353BADD Frg(v2) / Gas Range
Frigidaire FGF353BADE Frg(v1) / Gas Range
Frigidaire FGF353BADF Frg(v1) / Gas Range
Frigidaire FGF353BADG Frg(v1) / Gas Range
Frigidaire FGF353BADH Frg(v1) / Gas Range
Frigidaire FGF353BADJ Frg(v1) / Gas Range
Frigidaire FGF353BAWA Frg(v1) / Gas Range
Frigidaire FGF353BAWB Frg(v2) / Gas Range
Frigidaire FGF353BAWC Frg(v3) / Gas Range
Frigidaire FGF353BAWD Frg(v4) / Gas Range
  #2 (permalink)
Old 12-04-2017, 01:52 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
That's pretty much it.
Unplug the range, cut the wires near the old igniter and remove it.
Install the new one and then trim the old wires, strip the ends and wire nut them to the new igniter. Its 120 volts AC so the polarity doesn't matter. Make sure the wires aren't near anything that get too hot.
Sometimes it helps to take a few pics before you start.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing oven igniter violaine Oven Repair (including Ranges and Cooktops) 0 04-15-2011 02:20 PM
GE Gas Oven will not work even after replacing the Igniter revbobmartin Oven Repair (including Ranges and Cooktops) 0 01-21-2010 01:15 PM
GE Gas Oven will not work even after replacing the Igniter revbobmartin Oven Repair (including Ranges and Cooktops) 0 01-21-2010 01:07 PM
Replacing Oven Igniter Chowder Oven Repair (including Ranges and Cooktops) 0 11-21-2009 04:29 PM
Replacing oven igniter Don Cohee Oven Repair (including Ranges and Cooktops) 0 01-30-2008 11:20 AM
