Discuss
Bosch Double Gas Oven heating issues
 in
bought a used house 1 yr ago. home inspection report indicated upper oven temp was 347 degrees when set to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bosch Double Gas Oven heating issues
  #1 (permalink)
Old 11-21-2017, 07:51 AM
Junior Member
tlwright2 is on a distinguished road
Default Bosch Double Gas Oven heating issues
Model Number: HBN56   Brand: Bosch   Age: 5 - 10 years
bought a used house 1 yr ago. home inspection report indicated upper oven temp was 347 degrees when set to 350 degrees.
We don't use it much but each time I do the upper oven is never as hot as the setting. I bought a oven thermometer and measured it and it's as much as 50 degrees lower than oven setting. It also seems to take forever to heat up to the setting. Whenever the oven beeps and says it is heated up (say 350) it actually is still way under that setting (maybe 260 according to the thermometer).
I adjusted the temperature offsett by adding 35 degrees but still doesn't quite get up to oven setting. I have had to add 10 degrees to the oven temp to get to the desired temps even after adding 35 degrees with the oven offsett. With all of this you have to wait at least 15-20 mins to get the oven up to the desired temp AFTER the oven says it is already there.
don't understand what is going on. Any advise? Can't figure out how home inspector got acceptable readings and I can not. It obviously had some kind of problem but don't know where to start.
Related Models
Bosch HBN642
Bosch HBN645
Bosch HBN646
Bosch HBN652
Bosch HBN655
Bosch HBN656
Bosch HBN662
Bosch HBN665
Bosch HBN666
Bosch HBN742 AUC (FD 8207-)
Bosch HBN745 AUC (FD 8207-)
Bosch HBN746 AUC (FD 8207-)
Bosch HBN752 AUC (FD 8207-)
Bosch HBN755 AUC (FD 8207-)
Bosch HBN756 AUC (FD 8207-)
Bosch HBN765 AUC (FD 8207-)
Magic Chef HC309B-2 HOOD
Magic Chef HC30AB-2 HOOD
Frigidaire HC30C Frg(v1) / Range Vent Hood
Frigidaire HC30CL Frg(v2) / Range Vent Hood
Frigidaire HC8830S Frigidaire / Range Hood
Frigidaire HC8830W Frigidaire / Range Hood
Frigidaire HC8836S Frigidaire / Range Hood
Frigidaire HC8836W Frigidaire / Range Hood
Hardwick HCF120 FREEZER- VERTICAL
Hardwick HCF170 FREEZER- VERTICAL
Hardwick HCF200 FREEZER- VERTICAL
General Electric HCK23LCMAFCC Refrigerator
Amana HCL305 RANGE- S/C S/I DDRAFT GAS
Amana HCL605 RANGE- S/C S/I DDRAFT GAS
Amana HCR305 RANGE- S/C S/I DDRAFT GAS
Amana HCR306 RANGE- S/C S/I DDRAFT GAS
Amana HCR3061L HOOD
Amana HCR3061L HOOD
Amana HCR3061W HOOD
Amana HCR3061W HOOD
Amana HCR307E HOOD
Thermador HCSW36TB
Thermador HCSW36TS
Thermador HCSW36TW
Thermador HCSW42TB
Thermador HCSW42TS
Thermador HCSW42TW
Thermador HCSW48TB
Thermador HCSW48TS
Thermador HCSW48TW
Amana HCU-514 RANGE- S/C S/I DDRAFT GAS
Amana HCU-516 RANGE- S/C S/I DDRAFT GAS
Amana HD-332 MWAVE- MOUNTED OVER RANGE/WO
Amana HD-336 MWAVE- MOUNTED OVER RANGE/WO
Amana HD-342 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool HD1000JSC4 HOT WATER DISPENSER
Whirlpool HD1000JSN4 HOT WATER DISPENSER
Whirlpool HD1000JSW0 WATER DISPENSER
Whirlpool HD1000JSW1 W - White C - Chrome N - Almond
Whirlpool HD1000JSW3 HOT WATER DISPENSER
Whirlpool HD1000JSW4 HOT WATER DISPENSER
Whirlpool HD1000XS0 WATER DISPENSER
Whirlpool HD1000XS2 WATER DISPENSER
Whirlpool HD1000XS3 WATER DISPENSER
Whirlpool HD1000XSC7 WATER DISPENSER
Whirlpool HD1000XSW4 WATER DISPENSER
Whirlpool HD1000XSW5 WATER DISPENSER
Whirlpool HD1000XSW6 WATER DISPENSER
Whirlpool HD1000XSW7 WATER DISPENSER
Whirlpool HD1000XSW8 WATER DISPENSER
General Electric HDA1000G00WH Dishwasher
General Electric HDA1000G02WH Dishwasher
General Electric HDA1000G20WH Dishwasher
General Electric HDA1000K01 Dishwasher
General Electric HDA1000K02 Dishwasher
General Electric HDA1000K03 Dishwasher
General Electric HDA1000Z00WH Dishwasher
General Electric HDA1000Z01WH Dishwasher
General Electric HDA1000Z02WH Dishwasher
General Electric HDA1000Z04WH Dishwasher
General Electric HDA1000Z05WH Dishwasher
General Electric HDA1000Z06WH Dishwasher
General Electric HDA1000Z07WH Dishwasher
General Electric HDA1000Z08WH Dishwasher
General Electric HDA1000Z09WH Dishwasher
General Electric HDA1000Z10WH Dishwasher
General Electric HDA1000Z11WH Dishwasher
General Electric HDA1000Z12WH Dishwasher
General Electric HDA100S-45AW 1992 HOTPOINT MODEL
General Electric HDA100S-45BA 1992 HOTPOINT MODEL
General Electric HDA100S-45BW 1992 H/P W/BL-WH PANEL
General Electric HDA100S-45WA 1992 HOTPOINT MODEL
General Electric HDA100S-48BA 1993 PRODUCTIVITY MODEL
General Electric HDA100S-48BW 1993 PRODUCTIVITY MODEL
General Electric HDA100S-48WA 1993 PRODUCTIVITY MODEL
General Electric HDA100S-55BA DISHWASHER
General Electric HDA100S-55BW DISHWASHER
General Electric HDA100S-55WA DISHWASHER
General Electric HDA100V-60WH DISHWASHER
General Electric HDA100V-61WH 1994 MODEL
General Electric HDA100V-64WH
General Electric HDA100X-66WH 95 APRIL MODEL
General Electric HDA100X-72WH DISHWASHER
General Electric HDA100X-73WH DISHWASHER
General Electric HDA101Y-66WH DISHWASHER
General Electric HDA1030M01 Dishwasher
General Electric HDA1030M20 Dishwasher
General Electric HDA1030M25WA Dishwasher
General Electric HDA105Y-70WH DISHWASHER
General Electric HDA105Y-72WH DISHWASHER
General Electric HDA105Y-73WH DISHWASHER
General Electric HDA1100Z00WH Dishwasher
General Electric HDA1100Z01WH Dishwasher
General Electric HDA1100Z02WH Dishwasher
General Electric HDA1100Z04WH Dishwasher
General Electric HDA1100Z05WH Dishwasher
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Double Oven issues daytoantunnel Oven Repair (including Ranges and Cooktops) 0 05-21-2016 10:02 AM
Frigidaire double oven sporadic issues Phil45 Oven Repair (including Ranges and Cooktops) 4 11-26-2015 03:41 AM
How to remove the glass on double oven Bosch double oven and reinstall a new one? pdhuber Oven Repair (including Ranges and Cooktops) 0 12-16-2010 12:14 PM
Double Oven Issues asbeyer Oven Repair (including Ranges and Cooktops) 1 12-01-2010 03:03 PM
Double Oven Control Issues hlaplant Oven Repair (including Ranges and Cooktops) 3 12-21-2007 10:11 AM
