Discuss
Thermador oven won't fire up
 in
Iíve got a problem with the oven on a Thermador range. Just in time for Thanksgiving. First I canít find
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador oven won't fire up
  #1 (permalink)
Old 11-18-2017, 08:24 PM
Junior Member
cattleclass is on a distinguished road
Default Thermador oven won't fire up
Model Number: P366CS/03   Brand: Thermador   Age: 5 - 10 years
First I canít find the range on the Thermador web site.
The label says:
Thermador
Customer Service 1-800-735-4328
Model P366CS/03
ID 860500001
Serial 39605008371
Oven appears to turn on but then turns off with lights flashing a code:
Preheating Ė 4 blinks
Heating Ė 3 blinks
I can see the igniter glowing red hot.
As the igniter is glowing, the voltage on the terminals to the gas safety valve rise up to 3VAC. But then everything clicks off and the error code blinks as described earlier.
Is it the safety valve or is it the control board?
Or both?
The control board relays seem to be clicking strongly.
Thermador Range/Stove/Oven Safety Valve - Bosch OEM Part #00605061
Is there a way to check the safety valve on a bench?
It says operating voltage 3.3VAC.
Any suggestions appreciated.
This range is a bear to work on.
Iíve never seen so many screws.
And the stove top burner heads are seized up.
Does anyone know of a way to get the burner heads removed without too much destruction?
I am prepared to buy replacement parts for 4 out of 6 of the burner heads.
What a mess!
Thank you in advance for taking the time to read this.
Best wishes for the holidays.
Related Models
Whirlpool PAP25002LM0 AIR PURIFIER
Amana PARB1905CB0 REF - BOTTOM MOUNTS
Amana PARB1905CC0 REF - BOTTOM MOUNTS
Amana PARB1905CS0 REF - BOTTOM MOUNTS
Amana PARB1905CW0 REF - BOTTOM MOUNTS
Admiral PAV1000AKE WASHER-TOP LOADING
Maytag PAV1000AWW WASHER-TOP LOADING
Admiral PAV1000GGE WASHER-TOP LOADING
Maytag PAV1100AWW WASHER-TOP LOADING
Maytag PAV1200AWW WASHER-TOP LOADING
Admiral PAV2000AAW WASHER-TOP LOADING
Maytag PAV2000AWA WASHER-TOP LOADING
Maytag PAV2000AWW WASHER-TOP LOADING
Admiral PAV2000GGE WASHER-TOP LOADING
Admiral PAV2200AAW WASHER-TOP LOADING
Admiral PAV2200AGW WASHER-TOP LOADING
Admiral PAV2200AKW WASHER-TOP LOADING
Admiral PAV2200ARW WASHER-TOP LOADING
Maytag PAV2200AWW WASHER-TOP LOADING
Maytag PAV2250AWA WASHER-TOP LOADING
Maytag PAV2250AWW WASHER-TOP LOADING
Admiral PAV2300AGW WASHER-TOP LOADING
Maytag PAV2300AWA WASHER-TOP LOADING
Maytag PAV2300AWW WASHER-TOP LOADING
Maytag PAV2360AWW WASHER-TOP LOADING
Admiral PAV2755AAW WASHER-TOP LOADING
Maytag PAV3000AWW WASHER-TOP LOADING
Maytag PAV3100AWW WASHER-TOP LOADING
Admiral PAV3200AAW WASHER-TOP LOADING
Admiral PAV3200AGW WASHER-TOP LOADING
Maytag PAV3200AWW WASHER-TOP LOADING
Maytag PAV3240AWW WASHER-TOP LOADING
Maytag PAV3250AWW WASHER-TOP LOADING
Admiral PAV3300AGW WASHER-TOP LOADING
Admiral PAV3300AKW WASHER-TOP LOADING
Maytag PAV3300AWW WASHER-TOP LOADING
Maytag PAV3360AWW WASHER-TOP LOADING
Admiral PAV3855AAW WASHER-TOP LOADING
Maytag PAV4960AWW WASHER-TOP LOADING
Maytag PAV5000AWQ WASHER-TOP LOADING
Maytag PAV5000AWW WASHER-TOP LOADING
Maytag PAV5057AWW WASHER-TOP LOADING
Maytag PAV5058AWW WASHER-TOP LOADING
Maytag PAV5157AWW WASHER-TOP LOADING
Maytag PAV5158AWW WASHER-TOP LOADING
Admiral PAVS234AWW WASHER-TOP LOADING
Admiral PAVS244AWW WASHER-TOP LOADING
Maytag PAVT134AWW WASHER-TOP LOADING
Maytag PAVT144AWW WASHER-TOP LOADING
Maytag PAVT234AWQ WASHER-TOP LOADING
Maytag PAVT234AWW WASHER-TOP LOADING
Maytag PAVT244AWQ WASHER-TOP LOADING
Maytag PAVT244AWW WASHER-TOP LOADING
Maytag PAVT344AWW WASHER-TOP LOADING
Maytag PAVT444AWW WASHER-TOP LOADING
Maytag PAVT454EWW WASHER-TOP LOADING
Maytag PAVT910AWW WASHER-TOP LOADING
Maytag PAVT915AWW WASHER-TOP LOADING
Maytag PAVT920AWW WASHER-TOP LOADING
Thermador PB30YS
General Electric PB750DN1BB ELECTRIC RANGE
General Electric PB750TN1WW ELECTRIC RANGE
General Electric PB900DP1BB ELECTRIC RANGE
General Electric PB900DP2BB ELECTRIC RANGE
General Electric PB900DP3BB ELECTRIC RANGE
General Electric PB900DP4BB ELECTRIC RANGE
General Electric PB900SP1SS ELECTRIC RANGE
General Electric PB900SP2SS ELECTRIC RANGE
General Electric PB900SP3SS ELECTRIC RANGE
General Electric PB900SP4SS ELECTRIC RANGE
General Electric PB900TP1WW ELECTRIC RANGE
General Electric PB900TP2WW ELECTRIC RANGE
General Electric PB900TP3WW ELECTRIC RANGE
General Electric PB900TP4WW ELECTRIC RANGE
General Electric PB909DP1BB ELECTRIC RANGE
General Electric PB909DP2BB ELECTRIC RANGE
General Electric PB909DP3BB ELECTRIC RANGE
General Electric PB909DP4BB ELECTRIC RANGE
General Electric PB909DP5BB ELECTRIC RANGE
General Electric PB909SP1SS ELECTRIC RANGE
General Electric PB909SP2SS ELECTRIC RANGE
General Electric PB909SP3SS ELECTRIC RANGE
General Electric PB909SP4SS ELECTRIC RANGE
General Electric PB909SP5SS ELECTRIC RANGE
General Electric PB909TP1WW ELECTRIC RANGE
General Electric PB909TP2WW ELECTRIC RANGE
General Electric PB909TP3WW ELECTRIC RANGE
General Electric PB909TP4WW ELECTRIC RANGE
General Electric PB909TP5WW ELECTRIC RANGE
General Electric PB909TR1CC ELECTRIC RANGE
General Electric PB909TR2CC ELECTRIC RANGE
General Electric PB910DP1BB ELECTRIC RANGE
General Electric PB910DP2BB ELECTRIC RANGE
General Electric PB910DP3BB ELECTRIC RANGE
General Electric PB910DP4BB ELECTRIC RANGE
General Electric PB910SP1SS ELECTRIC RANGE
General Electric PB910SP2SS ELECTRIC RANGE
General Electric PB910SP3SS ELECTRIC RANGE
General Electric PB910SP4SS ELECTRIC RANGE
General Electric PB910TP1CC ELECTRIC RANGE
General Electric PB910TP1WW ELECTRIC RANGE
General Electric PB910TP2CC ELECTRIC RANGE
General Electric PB910TP2WW ELECTRIC RANGE
General Electric PB910TP3CC ELECTRIC RANGE
General Electric PB910TP3WW ELECTRIC RANGE
General Electric PB910TP4CC ELECTRIC RANGE
General Electric PB910TP4WW ELECTRIC RANGE
General Electric PB920DP1BB ELECTRIC RANGE
General Electric PB920DP2BB ELECTRIC RANGE
General Electric PB920DP3BB ELECTRIC RANGE
General Electric PB920DP4BB ELECTRIC RANGE
General Electric PB920DP5BB ELECTRIC RANGE
General Electric PB920SP1SS ELECTRIC RANGE
General Electric PB920SP2SS ELECTRIC RANGE
General Electric PB920SP3SS ELECTRIC RANGE
General Electric PB920SP4SS ELECTRIC RANGE
General Electric PB920SP5SS ELECTRIC RANGE
General Electric PB920TP1WW ELECTRIC RANGE
General Electric PB920TP2WW ELECTRIC RANGE
General Electric PB920TP3WW ELECTRIC RANGE
  #2 (permalink)
Old 11-26-2017, 08:16 PM
Junior Member
Default Worked for one day! Then error code 43 again!
Here's an update.
The oven worked for one day. Thanksgiving Day.
The turkey got cooked.
But the next day, error code 43 was back again.
It was neither the gas safety valve nor the control board.
After researching the web, I found that error code 43 is "No Cooling Fans."
I also learned that there's a small interlock switch just below the cook top. It's described as a sail switch.
The interlock switch was caked with grease.
I cleaned the grease off and the oven worked.
Now the next day, error code 43 is back again.
I checked the interlock switch. The heat from the cooking must have melted another load of grease into the switch.
So I bypassed the switch until I can get a replacement.
The oven ignites okay, starts to get warm, then clicks off and blinks error code 43.
Please, can someone help?
  #3 (permalink)
Old 12-03-2017, 07:21 AM
Junior Member
Peter D is on a distinguished road
Default Thermador oven cooling fan problem
I had the same problem. Thermador pg304 LP. Two fans not made any more. I tried to clean them in place as well as the sail switches. It didnt work. I removed them (horrible job) and thoroughly cleaned both the fan blades and the switches. You can get a spray electronics cleaner that will clean the switch without ruining it. Relube the fan bearing and reinstall. Mine has worked fine ever since
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Professional Gas Range PGR486GL main oven fails to fire up tanner14541 Oven Repair (including Ranges and Cooktops) 1 02-14-2012 09:23 AM
Thermador MTR 10 Belching Fire ! Sonny Day Out Microwave Repair 0 11-11-2011 08:24 AM
Heat & Glow Gas-Fire Place w/o Fire ●●●●●● Heating, Ventilation, and Air Conditioning (HVAC) 0 11-07-2010 11:06 AM
Recall of Thermador Built-In Ovens Due to Fire Hazard Gene Oven Repair (including Ranges and Cooktops) 1 01-22-2010 05:36 AM
Oven Won't Fire OttoZ Oven Repair (including Ranges and Cooktops) 0 11-11-2007 09:07 AM
