Discuss
Meat Probe Issues - Electrolux Double Oven
 in
Having issue with the meat probe in that the probe temperature is inaccurate when oven is turned on. When using
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Meat Probe Issues - Electrolux Double Oven
  #1 (permalink)
Old 11-12-2017, 01:41 PM
Junior Member
abjr is on a distinguished road
Default Meat Probe Issues - Electrolux Double Oven
Model Number: ew30ew65gs   Brand: Electrolux   Age: 1 - 5 years
When using the meat probe (in either the top or bottom oven) the oven turns off too soon because the probe temperature is reporting back that the desired temperature has been reached.
Ran this test... put a pot of hot water in oven and was able to get probe into water but not touching the pot at all. Initially when oven is turn on and probe start the temperature of the water is accurate (started at 98. Set the oven to 350 and the probe temp to 150, closed oven. Oven started pre heat and temp was increasing, also checking probe temp and saw that is was also steadily increasing, not as fast as the oven but was increasing a degree a sec or two... In under 3 minutes the probe reported back a temp of 150 and the oven shut off as expected, opened oven and put a candy thermometer in the water, water was 120 degrees. Once oven turned off the probe temp decreased back down to 120. So my theory is that only when the oven is on does the incorrect temperature get sent/reported.
Ever seen?
Any way to test the meat probe like the oven temperature sensor? Is there an ohms chart based on temp?
Would this be the meat probe or the control board?
Is there any diagnostics to check the meat probe/board?
Related Models
 EW30EW65GS1 WALL OVEN
 EW30EW65GS2 WALL OVEN
 EW30EW65GS3 WALL OVEN
 EW30EW65GS4 WALL OVEN
 EW30EW65GS5 WALL OVEN
 EW30EW65GS6 WALL OVEN
 EW30EW65GS7 WALL OVEN
 EW30EW65GS8 ELECTROLUX/WALL OVEN
 EW30EW65GW1 WALL OVEN
 EW30EW65GW2 WALL OVEN
 EW30EW65GW3 WALL OVEN
 EW30EW65GW4 WALL OVEN
 EW30EW65GW5 WALL OVEN
 EW30EW65GW6 WALL OVEN
 EW30EW65GW7 WALL OVEN
 EW30EW6CGB1 WALL OVEN
 EW30EW6CGB3 WALL OVEN
 EW30EW6CGS3 WALL OVEN
 EW30EW6CGS4 WALL OVEN
 EW30EW6CGS5 WALL OVEN
 EW30EW6CGS6 WALL OVEN
 EW30EW6CGS7 WALL OVEN
 EW30EW6CGS8 WALL OVEN
 EW30EW6CGW1 WALL OVEN
 EW30EW6CGW3 WALL OVEN
 EW30GC55GB1 COOKTOP
 EW30GC55GB2 COOKTOP
 EW30GC55GS1 COOKTOP
 EW30GC55GS2 COOKTOP
 EW30GC55GW1 COOKTOP
 EW30GC55GW2 COOKTOP
 EW30GC60IS1 COOKTOP
 EW30GC60IS2 COOKTOP
 EW30GF65GBA GAS RANGE
 EW30GF65GBB GAS RANGE
 EW30GF65GBC GAS RANGE
 EW30GF65GBD GAS RANGE
 EW30GF65GBE GAS RANGE
 EW30GF65GSA GAS RANGE
 EW30GF65GSB GAS RANGE
 EW30GF65GSC GAS RANGE
 EW30GF65GSD GAS RANGE
 EW30GF65GSE GAS RANGE
 EW30GF65GSF GAS RANGE
 EW30GF65GSG GAS RANGE
 EW30GF65GSH GAS RANGE
 EW30GF65GSJ GAS RANGE
 EW30GF65GSK GAS RANGE
 EW30GF65GWA GAS RANGE
 EW30GF65GWB GAS RANGE
 EW30GF65GWC GAS RANGE
 EW30GF65GWD GAS RANGE
 EW30GF65GWE GAS RANGE
 EW30GS65GB1 GAS RANGE
 EW30GS65GB2 GAS RANGE
 EW30GS65GB5 GAS RANGE
 EW30GS65GB6 GAS RANGE
 EW30GS65GB7 GAS RANGE
 EW30GS65GB8 GAS RANGE
 EW30GS65GB9 GAS RANGE
 EW30GS65GS1 GAS RANGE
 EW30GS65GS2 GAS RANGE
 EW30GS65GS3 GAS RANGE
 EW30GS65GS6 GAS RANGE
 EW30GS65GS7 GAS RANGE
 EW30GS65GS8 GAS RANGE
 EW30GS65GS9 GAS RANGE
 EW30GS65GSA GAS RANGE
 EW30GS65GSB GAS RANGE
 EW30GS65GW1 GAS RANGE
 EW30GS65GW2 GAS RANGE
 EW30GS65GW5 GAS RANGE
 EW30GS65GW6 GAS RANGE
 EW30GS65GW7 GAS RANGE
 EW30GS65GW8 GAS RANGE
 EW30GS65GW9 GAS RANGE
 EW30GS6CGS1 GAS RANGE
 EW30GS6CGS6 GAS RANGE
 EW30GS6CGS7 GAS RANGE
 EW30GS6CGS8 GAS RANGE
 EW30GS6CGS9 GAS RANGE
 EW30GS6CGSA GAS RANGE
 EW30GS6CGSB GAS RANGE
 EW30GS75KSA GAS RANGE
 EW30IC60IB1 COOKTOP
 EW30IC60IS1 COOKTOP
 EW30IF60ISA ELECTRIC RANGE
 EW30IS65JSA ELECTRIC RANGE
 EW30IS65JSB ELECTRIC RANGE
 EW30IS6CJSA ELECTRIC RANGE
 EW30IS6CJSB ELECTRIC RANGE
 EW30MC65JB1 WALLOVEN-MICROWAVE COMBO
 EW30MC65JB2 WALLOVEN-MICROWAVE COMBO
 EW30MC65JS1 WALLOVEN-MICROWAVE COMBO
 EW30MC65JS2 WALLOVEN-MICROWAVE COMBO
 EW30MC65JW1 WALLOVEN-MICROWAVE COMBO
 EW30MC65JW2 WALLOVEN-MICROWAVE COMBO
 EW30MO55HSA BUILT-IN MICROWAVE
 EW30WD55GS1 WARMER DRAWER
 EW30WD55GS2 WARMER DRAWER
 EW30WD55GS3 WARMER DRAWER
 EW36CC55GB1 COOKTOP
 EW36CC55GB2 COOKTOP
 EW36CC55GB3 COOKTOP
 EW36CC55GS1 COOKTOP
 EW36CC55GS2 COOKTOP
 EW36CC55GS3 COOKTOP
 EW36CC55GS4 COOKTOP
 EW36CC55GW1 COOKTOP
 EW36CC55GW2 COOKTOP
 EW36CC55GW3 COOKTOP
 EW36EC55GB1 COOKTOP
 EW36EC55GB2 COOKTOP
 EW36EC55GS1 COOKTOP
 EW36EC55GS2 COOKTOP
 EW36EC55GW1 COOKTOP
 EW36EC55GW2 COOKTOP
 EW36GC55GB1 COOKTOP
 EW36GC55GB2 COOKTOP
 EW36GC55GS1 COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Meat Probe Receptacle error Bill Berman Oven Repair (including Ranges and Cooktops) 1 10-04-2015 06:02 AM
Double Oven Issues asbeyer Oven Repair (including Ranges and Cooktops) 1 12-01-2010 03:03 PM
Bosch Dual Fuel range Meat Probe problem jayhawk2685 Oven Repair (including Ranges and Cooktops) 0 08-22-2009 08:16 AM
frigidaire electrolux double oven hobitdor Oven Repair (including Ranges and Cooktops) 1 03-17-2009 07:40 PM
Double Oven Control Issues hlaplant Oven Repair (including Ranges and Cooktops) 3 12-21-2007 10:11 AM
