Discuss
DCS Range Re-ignitor replaced, now burners keep sparking after lit
 in
My DCS range was not igniting the burners very well, even after cleaning the surface ignitors and the burners. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » DCS Range Re-ignitor replaced, now burners keep sparking after lit
  #1 (permalink)
Old 11-05-2017, 12:44 PM
Junior Member
mlazzaretto is on a distinguished road
Default DCS Range Re-ignitor replaced, now burners keep sparking after lit
Model Number: RGS 36 6 SS   Brand: -other-   Age: More than 10 years
My DCS range was not igniting the burners very well, even after cleaning the surface ignitors and the burners. I replaced the re-ignitor and now the burners all light very well and the spark is strong, but the burners keep sparking after the burners are lit. Before I replaced the re-ignitor, the burners would sometime do this, but it would always go away after a minute or two of sparking. With the new re-ignitor, the sparking hasn't stopped even after 20 minutes. This is consistent for all of the burners. Help!!! Thanks in advance!
Related Models
Frigidaire RGS35CH0 Frg(v4) / Electric Range
Frigidaire RGS35CH2 Frg(v3) / Electric Range
Frigidaire RGS35CL1 Frg(v7) / Free Standing Electric Range
Frigidaire RGS35CL2 Frg(v2) / Electric Range
Frigidaire RGS35CW0 Frg(v5) / Electric Range
Frigidaire RGS35CW1 Frg(v8) / Free Standing Electric Range
Frigidaire RGS35CW2 Frg(v1) / Electric Range
Frigidaire RGS36BNL1 Frg(v2) / Electric Range
Frigidaire RGS36BNW1 Frg(v1) / Electric Range
General Electric RGS525GEJ1 Gas range
General Electric RGS525GEJ2 Gas range
General Electric RGS525GEJ3 Gas range
General Electric RGS525GEN1 Gas range
General Electric RGS525GPJ1 Gas range
General Electric RGS525GPJ2 Gas range
General Electric RGS525GPJ3 Gas range
Roper RGS6745PQ0 29" GAS DRYER
Roper RGS7646JQ0 GAS DRYER
Roper RGS7646JQ1 RESIDENTIAL DRYER
Roper RGS7646KQ1 RESIDENTIAL DRYER
Roper RGS7646KQ2 DRYER
Roper RGS7646KQ3 29" GAS DRYER
Roper RGS7648EN0 GAS DRYER
Roper RGS7648EN2 GAS DRYER
Roper RGS7648EN3 GAS DRYER
Roper RGS7648EQ0 GAS DRYER
Roper RGS7648EQ2 GAS DRYER
Roper RGS7648EQ3 GAS DRYER
Roper RGS7648EW0 GAS DRYER
Roper RGS7648EW2 GAS DRYER
Roper RGS7648EW3 GAS DRYER
Roper RGS7648JQ0 GAS DRYER
Roper RGS7648JQ1 RESIDENTIAL DRYER
Roper RGS7648KQ1 RESIDENTIAL DRYER
Roper RGS7648KQ2 DRYER
Roper RGS7745PQ0 29" GAS DRYER
Roper RGS7745RQ0 29" GAS DRYER
Roper RGS7745RQ1 29" GAS DRYER
 RGSF3330DW RANGE- S/C F/S GAS
 RGSF5330DT RANGE- S/C F/S GAS
Amana RGT350UD SURFACE UNIT- GAS
Amana RGT350UWW SURFACE UNIT- GAS
Amana RGT650UD SURFACE UNIT- GAS
Amana RGT650UWW SURFACE UNIT- GAS
General Electric RGU32N01 Gas range
General Electric RGU32U01 Gas range
General Electric RGU32U02 Gas range
General Electric RGU3501A Gas range
General Electric RGU6501A Gas range
Roper RGX3514PQ0 29" GAS DRYER
Roper RGX3514RQ0 29" GAS DRYER
Roper RGX3514RQ1 29" GAS DRYER
Roper RGX3519PQ0 29" GAS DRYER
Roper RGX3615EW0 GAS DRYER
Roper RGX4624EN0 GAS DRYER
Roper RGX4625EN0 GAS DRYER
Roper RGX4625EW0 GAS DRYER
Roper RGX4625EW1 DRYERS
Roper RGX4625EW2 GAS DRYER
Roper RGX4625EW3 GAS DRYER
Roper RGX4634JQ0 DRYER
Roper RGX4634KQ1 DRYER
Roper RGX4634KQ2 DRYER
Roper RGX4634KQ3 29" GAS DRYER
Roper RGX4635EN0 GAS DRYER
Roper RGX4635EN1 DRYERS
Roper RGX4635EN2 GAS DRYER
Roper RGX4635EN3 GAS DRYER
Roper RGX4635EQ0 GAS DRYER
Roper RGX4635EQ1 DRYERS
Roper RGX4635EQ2 GAS DRYER
Roper RGX4635EQ3 GAS DRYER
Roper RGX4635EW0 GAS DRYER
Roper RGX4635EW1 DRYERS
Roper RGX4635EW2 GAS DRYER
Roper RGX4635EW3 GAS DRYER
Roper RGX5634JQ0 DRYER
Roper RGX5634JQ1 DRYER
Roper RGX5634KQ1 DRYER
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
  #2 (permalink)
Old 11-05-2017, 03:33 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
A switch on one of the burners is sticking. This can happen if it had water in or it might just be bad.
  #3 (permalink)
Old 02-05-2018, 01:54 PM
Junior Member
GaFord is on a distinguished road
Default
If you have a spark module that automatically sparks regardless of the position of the switch until the flame is detected and then stops sparking (like the RI-302, RI-324 or RI-326), but your spark module keeps sparking after the flame is lit, this could be a ground issue. The switch controls the amount of gas (how high or low the flame is) and sends a signal to the spark module that a specific burner is turned on. From an electrical standpoint, the switch is either on or off (there is no position on the switch that says “lite”). Once the switch is on, regardless of the switch position, the spark module controls the spark. The spark module will spark until a flame is sensed at the burner that is turned on. The switches are individually wired to the spark module so the spark module knows which burner to sense. Once the flame is sensed, the spark module will stop sparking. If you turn on the switch, gas is released and if the igniter starts to spark, you know the switch is good. The spark module then sparks all burners (safety feature) and continues sparking until a flame is sensed at the specific burner that was turned on. The flame is sensed using flame rectification (a process where the spark module senses the resistance of the wire in the igniter that sits in the flame, and the resistance of the wire changes when the wire is hot from the flame). The burner needs to be grounded to the chassis (the chassis is grounded to earth through the green wire) for the spark module to properly sense the flame and stop sparking after the flame is lit. If your burners screw into the cooktop, the burner is grounded through the screw which connects to the chassis of the cooktop. If the screw rusted (the screw may look fine from the top but could be rusted or corroded down below the burner where it attaches to the chassis), the ground connection can be interrupted. So if you turn on the switch and the igniter starts parking, the switch is good, and if the spark module lights the flame, the spark module is probably good. But if the spark module keeps sending sparks even after the flame is lit, you probably have a faulty ground. Make sure cooktop is unplugged. You need to remove or drill out the old screws holding down the burner (the screws frequently break when removing and have to be drilled out, you might need a slightly larger screw after drilling), sand out the screw hole, clean the burner, and put in new screws to re-establish the ground. If your module sparks with the switch in the off position, you have a different issue (probably water got into the switch and is completing the circuit so the spark module thinks the switch is on). In that case, you need to wait for the switch to dry (or gently use a hair dryer).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air gas range ignitor won't stop clicking noise even after burners ignite DESPERATE_DANA Oven Repair (including Ranges and Cooktops) 1 02-05-2018 01:49 PM
Six burner Thermador range, all burners sparking after any or all are lit Damnnice12 Oven Repair (including Ranges and Cooktops) 2 10-07-2016 06:42 PM
Maytag gas range ignitor on all four top burners won't spark wltdan05 Oven Repair (including Ranges and Cooktops) 3 06-22-2011 12:09 PM
Over Ignitor Sparking timwiseman Oven Repair (including Ranges and Cooktops) 1 06-10-2011 02:34 PM
New ignitor keeps sparking AMG Oven Repair (including Ranges and Cooktops) 0 04-15-2011 03:07 PM
