Discuss
Jenn-Air Downdraft Range
 in
Hi, I have a Jenn-Air downdraft range, it has the feature for a grill on the left side. We originally
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Downdraft Range
  #1 (permalink)
Old 11-01-2017, 06:50 AM
Junior Member
leprice86@gmail.com is on a distinguished road
Default Jenn-Air Downdraft Range
Brand: Jenn-Air   Age: 1 - 5 years
Hi, I have a Jenn-Air downdraft range, it has the feature for a grill on the left side. We originally had a white range and purchased a stainless steel one last year (used). I kept the flat top burner from my old range to use when I need more than 2 burners. Yesterday when cooking, I plugged in the 2nd cooktop and something blew in that cooktop. We turned the oven off and then back on again. The left units did work but not as intended. We would turn one knob on and both heating sources would turn on. I took the flat top off and plugged my grill back in and the unit worked as intended but the downdraft fan came on immediately and I could not turn it off unless i unplugged the grill.
Does any of this sound familiar? I am wondering if we blew a fuse or maybe something more serious. Any suggestions will be appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Dual Fuel Modular Downdraft Slide-in Range AZDaisy Oven Repair (including Ranges and Cooktops) 0 12-20-2014 09:29 AM
Jenn Air Downdraft Range Blower Problems -X- Oven Repair (including Ranges and Cooktops) 1 12-10-2014 03:19 AM
Jenn-Air Electric Downdraft Slide- In Range William H. Oven Repair (including Ranges and Cooktops) 3 02-26-2010 03:49 PM
Jenn-Air Electric Downdraft Slide in Range William H. Oven Repair (including Ranges and Cooktops) 1 02-19-2010 04:42 PM
Jenn-Aire Electric Downdraft Slide-In Range Judith Yeiser Oven Repair (including Ranges and Cooktops) 1 07-08-2009 11:02 AM
