Discuss
Thermador Cook n Vent Downdraft Up/Down problem
 in
I am having an operational problem with the Thermador downdraft unit. The unit was locked in the up position and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Cook n Vent Downdraft Up/Down problem
  #1 (permalink)
Old 10-30-2017, 08:15 AM
Junior Member
armor99 is on a distinguished road
Default Thermador Cook n Vent Downdraft Up/Down problem
Model Number: CVS36R   Brand: Thermador   Age: More than 10 years
I am having an operational problem with the Thermador downdraft unit. The unit was locked in the up position and I thought an easy fix would be to replace the switch, so I did, and it didn't fix the problem. I then moved the fan out of the way and checked the gear motor and it showed continuity. I then discovered that if I moved the cam (attached to the gear motor shaft) slightly off vertical that the unit worked fine. The exact same thing happened in the down position and required the cam/shaft to be moved an inch or so off vertical and then it worked again. It's weird, the unit works great so long as the cam and arm are not in a vertical position. Any ideas? Thanks for your input.
Related Models
Thermador CVS36RB COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS36RS COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS36RW COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS45RB COOK "N" VENT
Thermador CVS45RS COOK "N" VENT
Thermador CVS45RW COOK "N" VENT
Thermador CVSE36B COOKTOP
Crosley CW18C1 WASHER-TOP LOADING
Crosley CW18C1A WASHER-TOP LOADING
Crosley CW18C1H WASHER-TOP LOADING
Crosley CW18C3A WASHER-TOP LOADING
Crosley CW18C3W WASHER-TOP LOADING
Crosley CW18M4 WASHER-TOP LOADING
Crosley CW18M4A WASHER-TOP LOADING
Crosley CW18M4H WASHER-TOP LOADING
Crosley CW18P2A WASHER-TOP LOADING
Crosley CW18P2AC WASHER-TOP LOADING
Crosley CW18P2H WASHER-TOP LOADING
Crosley CW18P2W WASHER-TOP LOADING
Crosley CW18P2WC WASHER-TOP LOADING
Crosley CW18P6A WASHER-TOP LOADING
Crosley CW18P6H WASHER-TOP LOADING
Crosley CW18P6W WASHER-TOP LOADING
Crosley CW18T2A WASHER-TOP LOADING
Crosley CW18T2W WASHER-TOP LOADING
 CW2079CWD Washer
 CW2079CWD Washer
 CW2079CWN Washer
 CW2079CWN Washer
Crosley CW20C5A WASHER-TOP LOADING
Crosley CW20C5W WASHER-TOP LOADING
Crosley CW20C7A WASHER-TOP LOADING
Crosley CW20C7W WASHER-TOP LOADING
Crosley CW20M4A WASHER-TOP LOADING
Crosley CW20M6 WASHER-TOP LOADING
Crosley CW20M6A WASHER-TOP LOADING
Crosley CW20M8 WASHER-TOP LOADING
Crosley CW20M8A WASHER-TOP LOADING
Crosley CW20M8H WASHER-TOP LOADING
Crosley CW20M9A WASHER-TOP LOADING
Crosley CW20M9N WASHER-TOP LOADING
Crosley CW20P4A WASHER-TOP LOADING
Crosley CW20P4W WASHER-TOP LOADING
Crosley CW20P5A WASHER-TOP LOADING
Crosley CW20P5AC WASHER-TOP LOADING
Crosley CW20P5H WASHER-TOP LOADING
Crosley CW20P5HC WASHER-TOP LOADING
Crosley CW20P5W WASHER-TOP LOADING
Crosley CW20P5WC WASHER-TOP LOADING
Crosley CW20P6 WASHER-TOP LOADING
Crosley CW20P6A WASHER-TOP LOADING
Crosley CW20P6AC WASHER-TOP LOADING
Crosley CW20P6H WASHER-TOP LOADING
Crosley CW20P6W WASHER-TOP LOADING
Crosley CW20P6WC WASHER-TOP LOADING
Crosley CW20P8A WASHER-TOP LOADING
Crosley CW20P8AC WASHER-TOP LOADING
Crosley CW20P8AS WASHER-TOP LOADING
Crosley CW20P8ASC WASHER-TOP LOADING
Crosley CW20P8D WASHER-TOP LOADING
Crosley CW20P8DS WASHER-TOP LOADING
Crosley CW20P8DSC WASHER-TOP LOADING
Crosley CW20P8H WASHER-TOP LOADING
Crosley CW20P8HS WASHER-TOP LOADING
Crosley CW20P8HSC WASHER-TOP LOADING
Crosley CW20P8W WASHER-TOP LOADING
Crosley CW20P8WC WASHER-TOP LOADING
Crosley CW20P8WS WASHER-TOP LOADING
Crosley CW20P8WSC WASHER-TOP LOADING
Crosley CW20T5A WASHER-TOP LOADING
Crosley CW20T5W WASHER-TOP LOADING
Crosley CW20T5WC WASHER-TOP LOADING
Crosley CW20T6A WASHER-TOP LOADING
Crosley CW20T6AC WASHER-TOP LOADING
Crosley CW20T6W WASHER-TOP LOADING
Crosley CW20T6WC WASHER-TOP LOADING
Crosley CW20T7A WASHER-TOP LOADING
Crosley CW20T7W WASHER-TOP LOADING
Crosley CW20T8A WASHER-TOP LOADING
Crosley CW20T8V WASHER-TOP LOADING
Crosley CW20T8VC WASHER-TOP LOADING
Crosley CW20T8W WASHER-TOP LOADING
Crosley CW22B5M WASHER-TOP LOADING
Crosley CW22B5V WASHER-TOP LOADING
Crosley CW22B6M WASHER-TOP LOADING
Crosley CW22B6V WASHER-TOP LOADING
Crosley CW22B7M WASHER-TOP LOADING
Crosley CW22B7V WASHER-TOP LOADING
Crosley CW22B8M WASHER-TOP LOADING
Crosley CW22B8V WASHER-TOP LOADING
Amana CW2303 WASHER-TOP LOADING
Amana CW2303G WASHER-TOP LOADING
Amana CW2303L WASHER-TOP LOADING
Amana CW2303W WASHER-TOP LOADING
Amana CW2502L WASHER-TOP LOADING
Amana CW2502W WASHER-TOP LOADING
Crosley CW25P6A WASHER-TOP LOADING
Crosley CW25P6H WASHER-TOP LOADING
Crosley CW25P6W WASHER-TOP LOADING
Crosley CW26P6KA WASHER-TOP LOADING
Crosley CW26P6KW WASHER-TOP LOADING
Amana CW3303L WASHER-TOP LOADING
Amana CW3303W WASHER-TOP LOADING
Amana CW3502L WASHER-TOP LOADING
Amana CW3502W WASHER-TOP LOADING
Amana CW4202L WASHER-TOP LOADING
Amana CW4202W WASHER-TOP LOADING
Amana CW4202W2 WASHER-TOP LOADING
Crosley CW5000A WASHER-TOP LOADING
Crosley CW5000W WASHER-TOP LOADING
Crosley CW5500W WASHER-TOP LOADING
Crosley CW6000A WASHER-TOP LOADING
Crosley CW6000Q WASHER-TOP LOADING
Crosley CW6000W WASHER-TOP LOADING
Crosley CW6500Q WASHER-TOP LOADING
Crosley CW6500W WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermador downdraft vent Steve Y Oven Repair (including Ranges and Cooktops) 0 03-26-2017 09:06 AM
Noisy thermador cook n vent downdraft Larry007 Oven Repair (including Ranges and Cooktops) 0 03-23-2015 10:42 AM
Thermador Cook n Vent Downdraft Blower Terribletwos Oven Repair (including Ranges and Cooktops) 0 07-26-2014 11:58 AM
thermador downdraft vent Steve Y Oven Repair (including Ranges and Cooktops) 3 08-02-2012 11:26 AM
Cook 'n Vent Downdraft Up/Down Switch park1750 Oven Repair (including Ranges and Cooktops) 2 11-20-2008 06:54 PM
