Hello everyone, first post. The broil is not working on our Kenmore Ultra Bake Triple Task gas oven.
Was working intermittently, now won't light at all. Back when it sort-of worked, it would run well for 5 to 10 minutes, then shut off for no reason. So broiling anything meant someone had to sit by the oven and constantly turn the broil back on. Lately, it won't light at all. The screen displays "Broil", yet it is not lit.
More details, in case it matters: When it did work, you'd hear the usual sound of the gas turning on, followed by the multiple "clicks" of an ignition/spark device. Currently, there is no sound at all. It simply doesn't go through the process of turning on the gas and igniting it.
Any suggestions?
Thanks!
