Discuss
Maytag oven not working
 in
Oven not heating and displaying F5 error code. Display works, fan comes on when temp is selected for operation but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag oven not working
  #1 (permalink)
Old 10-14-2017, 01:48 PM
Junior Member
dtmeyer is on a distinguished road
Default Maytag oven not working
Model Number: CWE4800ACB   Brand: Maytag   Age: More than 10 years
Oven not heating and displaying F5 error code. Display works, fan comes on when temp is selected for operation but oven never gets hot. Heating elements were both replaced a month ago and was working fine, now this. . . Manual says to replace clock/control board and I just want to make sure that's gonna be all that is needed to fix it. Don't mind paying the price just want it to work.
Related Models
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
White Westinghouse CWEF310GSE ELECTRIC RANGE
White Westinghouse CWEF310GSF ELECTRIC RANGE
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF312GSA ELECTRIC RANGE
White Westinghouse CWEF312GSB ELECTRIC RANGE
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 WALLOVEN- STD GAS
Maytag CWG301 WALLOVEN- STD GAS
Maytag CWG302 WALLOVEN- STD GAS
Maytag CWG3020AAB WALLOVEN- STD GAS
Maytag CWG3020AAE WALLOVEN- STD GAS
Maytag CWG3020BAB WALLOVEN- STD GAS
Maytag CWG3020BAE WALLOVEN- STD GAS
Maytag CWG3100AAB WALLOVEN- STD GAS
Maytag CWG3100AAB25 24" BUILT-IN GAS OVEN
Maytag CWG3100AAE WALLOVEN- STD GAS
Maytag CWG3100AAE29 24" BUILT-IN GAS OVEN
Maytag CWG3100AAS WALLOVEN- STD GAS
Maytag CWG3100AAS13 24" BUILT-IN GAS OVEN
Maytag CWG351 WALLOVEN- STD GAS
Maytag CWG3510AAB WALLOVEN- STD GAS
Maytag CWG3510BAB WALLOVEN- STD GAS
Maytag CWG3600AAB WALLOVEN- STD GAS
Maytag CWG3600AAB26 24" BUILT-IN GAS OVEN
Maytag CWG3600AAS WALLOVEN- STD GAS
Maytag CWG3600AAS13 24" BUILT-IN GAS OVEN
Maytag CWG400 WALLOVEN- STD GAS
Maytag CWG401 WALLOVEN- STD GAS
Maytag CWG402 WALLOVEN- CONT CLEAN GAS
Maytag CWG4020AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4020BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4100AAB WALLOVEN- STD GAS
Maytag CWG450 WALLOVEN- STD GAS
Maytag CWG451 WALLOVEN- CONT CLEAN GAS
Maytag CWG4510AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4510BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4600AAB WALLOVEN- STD GAS
  #2 (permalink)
Old 10-14-2017, 04:27 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Its probably the board. It probably has bad relays or a burnt trace.
The only way to be sure is to check for power at the board. (to the bake element)
Also (with the power off) check for continuity through the wiring from the board to the element and back.
Parts for Maytag CWE4800ACB: Wiring Information Parts - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Oven not working tmacky34 Oven Repair (including Ranges and Cooktops) 0 10-02-2011 09:26 AM
Maytag range oven not working dixiedarlin Oven Repair (including Ranges and Cooktops) 2 08-31-2010 09:11 AM
Maytag Oven Not Working kdwccw Oven Repair (including Ranges and Cooktops) 0 02-11-2010 05:29 PM
Maytag oven not working Maj Oven Repair (including Ranges and Cooktops) 0 12-01-2009 02:39 PM
Maytag Oven & Broiler not Working dahitiili Oven Repair (including Ranges and Cooktops) 0 01-31-2009 09:15 PM
