Discuss
Oven Overheated now gas oven will not heat up in bake
 in
Our KitchenAid KGRA806PS00 gas range/oven recently overheated during a self clean cycle. This is common problem on these ovens and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Overheated now gas oven will not heat up in bake
  #1 (permalink)
Old 10-02-2017, 07:43 PM
Junior Member
hsilived is on a distinguished road
Default Oven Overheated now gas oven will not heat up in bake
Model Number: KGRA806PS00   Brand: Kitchen Aid   Age: 5 - 10 years
Our KitchenAid KGRA806PS00 gas range/oven recently overheated during a self clean cycle. This is common problem on these ovens and we've been through this several times in the past. In order to combat having to replace the thermostat in the back of the oven every time it overheats we have bypassed the thermostat. The oven overheated the other day and now the gas oven does not ignite. the electric broiler does work but not the gas portion.
I can see the bottom igniter spark when we turn on bake.
I have tested the gas valve for Ohms and got 216 on the bake solenoid and 213 on the broil solenoid.
I tested the Spark Module board for 120 VAC with no issues, based on suggestions from another forum.
Quote:
when you press the BAKE key you should have 120 VAC between the white wire and the red/white wire on the spark module board
when you press the BROIL key you should have 120 VAC between the white wire and the blue/white wire on the spark module board.
Any ideas?
Related Models
Whirlpool KGRA806PSS00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRA806PSS01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRA806PSS02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRA806PWH00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRA806PWH01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRA806PWH02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRC608LSS0 30" Freestanding Gas Range DESIGNER STYLE Convect
Whirlpool KGRC707LBL0 30" Freestanding Gas Range DESIGNER STYLE Convect
Whirlpool KGRC707LBS0 30" Freestanding Gas Range DESIGNER STYLE Convect
Whirlpool KGRC707LBT0 30" Freestanding Gas Range DESIGNER STYLE Convect
Whirlpool KGRC707LWH0 30" Freestanding Gas Range DESIGNER STYLE Convect
Whirlpool KGRI801PBL00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRI801PBL01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRI801PBS00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRI801PBS01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRI801PWH00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRI801PWH01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK201TBL0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Whirlpool KGRK201TSS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Whirlpool KGRK201TWH0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Whirlpool KGRK806PBL00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PBL01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PBL02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PBT00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PBT01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PBT02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PSS00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PSS01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PSS02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PWH00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PWH01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRK806PWH02 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS205TBL0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TBL2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TBL4 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TBL5 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TBT0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TSS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TSS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TSS4 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TSS5 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TWH0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TWH2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TWH4 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Whirlpool KGRS205TWH5 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
KitchenAid KGRS206XBL0 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XBL1 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XBL2 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XSS0 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XSS1 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XSS2 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XWH0 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XWH1 30" GAS FREESTANDING RANGE
KitchenAid KGRS206XWH2 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XBL0 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XBL1 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XBL2 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XSS0 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XSS1 30" GAS FREESTANDING RANGE
KitchenAid KGRS208XSS2 30" GAS FREESTANDING RANGE
KitchenAid KGRS308XSS0 30" GAS FREESTANDING RANGE
KitchenAid KGRS308XSS1 30" GAS FREESTANDING RANGE
KitchenAid KGRS308XSS2 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XBL00 GAS RANGE
KitchenAid KGRS505XBL01 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XBL02 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XSS00 GAS RANGE
KitchenAid KGRS505XSS01 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XSS02 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XWH00 GAS RANGE
KitchenAid KGRS505XWH01 30" GAS FREESTANDING RANGE
KitchenAid KGRS505XWH02 30" GAS FREESTANDING RANGE
Whirlpool KGRS807SBL00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SBL01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SBL02 30" FREESTANDING GAS OVEN CONVECTION
Whirlpool KGRS807SBT00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SBT01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SSS00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SSS01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SSS02 30" FREESTANDING GAS OVEN CONVECTION
Whirlpool KGRS807SWH00 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SWH01 30" Freestanding GAS OVEN CONVECTION
Whirlpool KGRS807SWH02 30" FREESTANDING GAS OVEN CONVECTION
KitchenAid KGRS807XSP00 30" FREESTANDING GAS OVEN
Whirlpool KGRT500BAL1 30" GAS RANGE
Whirlpool KGRT500BAL2 30" GAS RANGE
Whirlpool KGRT500BAL3 30" GAS RANGE
Whirlpool KGRT500BWH1 30" GAS RANGE
Whirlpool KGRT500BWH2 30" GAS RANGE
Whirlpool KGRT500BWH3 30" GAS RANGE
Whirlpool KGRT500FAL0 30" GAS RANGE
Whirlpool KGRT500FAL1 30" GAS RANGE
Whirlpool KGRT500FAL2 GAS FREESTANDING RANGE
Whirlpool KGRT500FWH0 30" GAS RANGE
Whirlpool KGRT500FWH1 30" GAS RANGE
Whirlpool KGRT500FWH2 GAS FREESTANDING RANGE
Whirlpool KGRT507BAL1 30" GAS SLIDE-IN RANGE
Whirlpool KGRT507BAL2 30" GAS RANGE
Whirlpool KGRT507BAL3 30" GAS RANGE W/CONVECTION OVEN
Whirlpool KGRT507BBL1 30" GAS SLIDE-IN RANGE
Whirlpool KGRT507BBL2 30" GAS RANGE
Whirlpool KGRT507BBL3 30" GAS RANGE W/CONVECTION OVEN
Whirlpool KGRT507BWH1 30" GAS SLIDE-IN RANGE
Whirlpool KGRT507BWH2 30" GAS RANGE
Whirlpool KGRT507BWH3 30" GAS RANGE W/CONVECTION OVEN
Whirlpool KGRT507FAL0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507FAL1 30" GAS RANGE
Whirlpool KGRT507FBL0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507FBL1 30" GAS RANGE
Whirlpool KGRT507FWH0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507FWH1 30" GAS RANGE
Whirlpool KGRT507GAL0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507GBL0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507GBS0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507GBT0 30" FREESTANDING GAS RANGE
Whirlpool KGRT507GWH0 30" FREESTANDING GAS RANGE
Whirlpool KGRT600HAL0 GAS RANGE
Whirlpool KGRT600HAL3 GAS RANGE
Whirlpool KGRT600HAL4 GAS RANGE
Whirlpool KGRT600HBL5 GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Oven Overheated Ann818 Oven Repair (including Ranges and Cooktops) 1 12-12-2016 10:20 AM
overheated digital display for oven alaskawells Oven Repair (including Ranges and Cooktops) 0 02-27-2012 03:16 PM
Oven won't heat up on Conv Bake and doesn't reach temp on regular bake hargie Oven Repair (including Ranges and Cooktops) 0 01-17-2011 06:22 AM
Gas Oven Broiler Works but oven to bake will not heat Lisa Cline Oven Repair (including Ranges and Cooktops) 1 11-11-2010 12:07 PM
Whirlpool gas oven broiler works, but oven does not bake or heat up smolesen Oven Repair (including Ranges and Cooktops) 0 03-13-2010 10:02 AM
