Discuss
Venturi Tubes spinning, not loose from base
 in
I have a six burner Thermador and the Venturi tubes are turning, but I believe whatever they are screwed into
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Venturi Tubes spinning, not loose from base
  #1 (permalink)
Old 09-22-2017, 10:25 AM
Junior Member
heinsite is on a distinguished road
Default Venturi Tubes spinning, not loose from base
Brand: Thermador   Age: Less than 1 year
I have a six burner Thermador and the Venturi tubes are turning, but I believe whatever they are screwed into is also spinning. How do I access underneath to hold the spinning part? Tried on three dif. tubes. Now two of the burners won't work. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer- Tub is loose- Very loud when spinning modestmark Washer Repair 2 11-27-2012 07:17 PM
Jumps when spinning, drum is loose cvonasek Washer Repair 1 06-21-2012 03:58 PM
venturi tubes gravure Oven Repair (including Ranges and Cooktops) 0 03-06-2012 06:21 AM
Agitator has come loose from base cdotson Washer Repair 0 08-25-2010 11:12 AM
R/r Venturi Tubes BOTRI7 Oven Repair (including Ranges and Cooktops) 1 04-22-2009 10:22 PM
