Discuss
Kenmore Elite Wall Oven Fault F30 and F10
 in
Our Kenmore wall oven has been working great for ten years but recently (on a couple of occasions) has given
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Elite Wall Oven Fault F30 and F10
  #1 (permalink)
Old 09-11-2017, 10:35 AM
Junior Member
psa928 is on a distinguished road
Default Kenmore Elite Wall Oven Fault F30 and F10
Model Number: 790.4790   Brand: Kenmore   Age: More than 10 years
Our Kenmore wall oven has been working great for ten years but recently (on a couple of occasions) has given us a fault code F30 (open resistance on temperature probe) and F10 (runaway temperature) when using the lower oven.
I assume the F10 fault is bogus and happens only because the faulty temperature probe resistance is making the oven think that the temp is too high.
From these symptoms, is it safe to assume that the problem here is the oven temperature probe? I understand that it's also possibly the wiring or connection to the control board, or even the board itself, but I would guess that a wiring issue is much less likely than the probe itself going bad. I noticed there is also a Range High Limit thermostat part, if that failed (or was flaky) would it manifest as a different fault?
Any advice? Anyone BTDT? From the replacement part picture on the sears website, it looks like a connectorized temp probe and (hopefully) a straightforward replacement from the inside of the oven.
Thanks for any help or advice!
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Wall Oven fAULT CODE F4, need help to test harness connections Ray Waldorf Oven Repair (including Ranges and Cooktops) 0 03-31-2012 01:51 PM
kenmore elite front loader fault code F35 misterfixall Washer Repair 2 11-22-2009 02:34 PM
kenmore elite microwave F9 fault penguins66 Microwave Repair 1 09-01-2009 12:48 PM
Kenmore Elite HE3 Fault Code F02 oran.true Washer Repair 1 07-05-2009 01:34 PM
Kenmore Wall Oven F 10 Fault Bigben Oven Repair (including Ranges and Cooktops) 3 01-20-2009 02:00 PM
