| » Electric Cooktop burner doesn't cycle on & off |
Model Number: RF368LXKW0 Brand: Whirlpool Age: 5 - 10 years
Left front burner stays on when temp setting is 3 or higher. it doesn't cycle on & off like it used to. What is the most likely part failure the control switch or the burner assembly with temp sensor?
The switch has some black around the case and the original switch part # has been replaced by a new one. I am leaning toward just replacing the switch since it is 1/3 cost of burner assy and part # discontinued. I visually inspected the switch and the burner assy, but can't see any problems other than blackening on switch. Can't decide which part is failing without knowing what to test with ohmmeter. Related Models |
Replacement parts for WHIRLPOOL RF368LXKW0 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208053296.pdf You can probably check the element from the control panel. Be sure to mark the wires before removing them from the control. Unplug the unit Remove the wires that go to the element at the control, Measure across these should be about 24 ohms. Then measure each side to the units frame, both should be open (infinite ohms) If OK order an infinite switch Item 4 Section 2. Be sure to get the correct one which I believe is AP3095444.
__________________
| Display Modes | |
| Jenn Air Electric Cooktop duel burner | Gumphrey Smith | Oven Repair (including Ranges and Cooktops) | 1 | 07-07-2009 01:59 PM |
| Replace burner switch on GE electric cooktop | mr2bob | Oven Repair (including Ranges and Cooktops) | 1 | 01-28-2009 07:39 PM |
| Cooktop Burner Control Light ON when Burner if OFF | isimek@remedymd.com | Oven Repair (including Ranges and Cooktops) | 1 | 11-06-2008 01:34 PM |
| whirlpool electric cooktop range inner burner not hot | posterboy42 | Oven Repair (including Ranges and Cooktops) | 3 | 10-03-2008 07:30 PM |
| GE Electric Cooktop Surface Burner Replacement | praskrish | Oven Repair (including Ranges and Cooktops) | 9 | 09-13-2008 12:58 PM |
