Discuss
Maytag Range
 in
I have a Maytag range oven problem. I replaced the bake element (which was cracked in two) but the element
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Range
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-22-2008, 08:13 AM
afergus afergus is offline
Junior Member
afergus is on a distinguished road
Default Maytag Range
Model Number: MER5875QCW   Brand: Maytag   Age: 1 - 5 years
I have a Maytag range oven problem. I replaced the bake element (which was cracked in two) but the element will still not heat up. The broiler works fine.I don't know where to go from here. Please help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-22-2008, 07:57 PM
roycreamer roycreamer is offline
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
do the rest of the burners work ok? if not, reset your circuit breaker. the element can sometimes blow 1 side of a 220 line and it will light up like it's working, but will only get slightly warm.
roy
  #3 (permalink)
Old 02-22-2008, 08:31 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if your broil is working normally ,the bake relay on the electronic clock probably shorted, which mean a new clock is needed
__________________
  #4 (permalink)
Old 02-23-2008, 09:16 AM
Junior Member
Default Maytag Range MER5875QCW - oven not heating
Reply to Misterfixall:
On the circuit board behind the clock, there is a melted area and the yellow wire going into the green plug does not show any power. Your suggestion was very helpful. We live in Alberta, Canada so if you have any suggestions for suppliers who ship internationally (parts appear to be cheaper in the US), we would appreciate it. The part cost here is quite expensive so it is not worth fixing unless we find a cheaper supplier. Thanks for your time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Range COntrol Panel Frozen ewoevo Oven Repair (including Ranges and Cooktops) 6 05-10-2008 10:18 AM
Door lock Maytag elect. range jilsan Oven Repair (including Ranges and Cooktops) 0 01-26-2008 06:07 AM
Removing Maytag Electric Range Cooktop Chryslerpetz Oven Repair (including Ranges and Cooktops) 3 01-03-2008 05:50 PM
Maytag Gas Range Oven wont lite Rick2462 Oven Repair (including Ranges and Cooktops) 1 10-10-2007 10:30 AM
Range / Maytag jonathan831 Oven Repair (including Ranges and Cooktops) 0 09-06-2007 05:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
