Discuss
Jenn-Air dual wall oven temp sensor replacement
 in
Wall-mount dual oven is behaving like temperature sensor on lower oven requires replacement. I removed the two screws holding the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air dual wall oven temp sensor replacement
  #1 (permalink)
Old 08-08-2017, 02:20 AM
Junior Member
jgmtfia is on a distinguished road
Default Jenn-Air dual wall oven temp sensor replacement
Model Number: ww2780w   Brand: Jenn-Air   Age: More than 10 years
Wall-mount dual oven is behaving like temperature sensor on lower oven requires replacement. I removed the two screws holding the temperature sensor but it does not appear that the sensor is removable from the front of the oven (sensor does not come out enough to access wiring)
Does the oven need to be removed from the wall to access the sensor from the rear of the appliance? Or, do I need to disassemble more of the inside of the lower oven to access the sensor?
Related Models
Jenn-Air WW2780W WALLOVEN- S/C ELE
Jenn-Air WW2780W-C WALLOVEN- S/C ELE
Whirlpool WW29000SU0 LAUNDRY WORKSURFACE
Whirlpool WW29000SW0 LAUNDRY WORKSURFACE
Jenn-Air WW30110B WALLOVEN- S/C ELE
Jenn-Air WW30110W WALLOVEN- S/C ELE
Jenn-Air WW30430B WALLOVEN- S/C ELE
Jenn-Air WW30430P WALLOVEN- S/C ELE
Jenn-Air WW30430PC WALLOVEN- S/C ELE
Jenn-Air WW30430PF WALLOVEN- S/C ELE
Jenn-Air WW30430PG WALLOVEN- S/C ELE
Jenn-Air WW30430PK WALLOVEN- S/C ELE
Jenn-Air WW30430PR WALLOVEN- S/C ELE
Jenn-Air WW30430PU WALLOVEN- S/C ELE
Jenn-Air WW30430W WALLOVEN- S/C ELE
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
 WW600 MWAVE- CNTRTP / STAND ALONE
General Electric WW8318LAL AUTOMATIC WASHER
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
General Electric WWA7640SALAA Washer
General Electric WWA7640SALWW Washer
General Electric WWA7640SBLAA Washer
General Electric WWA7640SBLWW Washer
General Electric WWA7646MAL Washer
General Electric WWA7650SALAA Washer
General Electric WWA7650SALWW Washer
General Electric WWA7650SBLAA Washer
General Electric WWA7650SBLWW Washer
General Electric WWA7678MAL Washer
General Electric WWA7680SALAA Washer
General Electric WWA7680SALWW Washer
General Electric WWA7680SBLAA Washer
General Electric WWA7680SBLWW Washer
  #2 (permalink)
Old 08-15-2017, 08:04 PM
Junior Member
Default
Quote:
Model was ww2780w-c. For what it's worth, on mine, the wires leading to the connector the sensor is attached to are too short to pull through the front of the oven for testing/replacement. I needed to remove the oven from the wall cabinet to check/test the sensor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Aire WG30100 oven sensor replacement szyglowicz Oven Repair (including Ranges and Cooktops) 1 07-10-2015 12:37 AM
GE Oven F3 After Temp Sensor Replacement CaboWaboTexas Oven Repair (including Ranges and Cooktops) 0 12-31-2014 10:49 AM
GE Oven Temp sensor replacement CK_GE_Temp Oven Repair (including Ranges and Cooktops) 1 12-12-2012 06:17 PM
jenn air wall oven won't get up to temp. lespelin Oven Repair (including Ranges and Cooktops) 0 01-09-2011 05:27 AM
Dacor Epicure wall oven error code L-34 Temp sensor HDK Oven Repair (including Ranges and Cooktops) 8 12-21-2009 05:45 PM
