Discuss
GE wall oven LOCKED flashing
 in
The upper (self-cleaning) oven is locked. Tried all the "reset" ideas I found online but no help though I did
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE wall oven LOCKED flashing
  #1 (permalink)
Old 07-08-2017, 12:27 PM
Junior Member
highschoolhank is on a distinguished road
Default GE wall oven LOCKED flashing
Model Number: JRP24BD1BB   Brand: GE   Age: 5 - 10 years
The upper (self-cleaning) oven is locked. Tried all the "reset" ideas I found online but no help though I did hear some ticking after resetting the breaker to the oven. Was able to push latch aside to get door open and want to check locking mechanism but cannot tell from exploded views I have found if I will have access to the lock motor, wiring, and switch assembly by removing the control panel, though it seems that would be the only way to get it. Also it's not clear if I must remove all the screws on both the top and bottom of the control panel in order to remove it.
Related Models
General Electric JRP24BD1BB Electric range
General Electric JRP24BD2BB Electric range
General Electric JRP24BW1BB Electric range
General Electric JRP24BW2BB Electric range
General Electric JRP24BW3BB ELECTRIC WALL OVEN
General Electric JRP24BW5BB Electric range
General Electric JRP24GP1 Electric range
General Electric JRP24GP2BG Electric range
General Electric JRP24GP3BG Electric range
General Electric JRP24GP4BG Electric range
General Electric JRP24GT1BB Electric range
General Electric JRP24GV1BB Electric range
General Electric JRP28BJ1BB Electric range
General Electric JRP28SK1SS Electric range
General Electric JRS04BW1BB Electric range
General Electric JRS04BW2BB Electric range
General Electric JRS04BW3BB Electric range
General Electric JRS04BW4BB Electric range
General Electric JRS04BW5BB Electric range
General Electric JRS04BW6BB Electric range
General Electric JRS04GP1 Electric range
General Electric JRS04GP2BG Electric range
General Electric JRS04GT1BB Electric range
General Electric JRS04GV1BB Electric range
General Electric JRS06BJ1BB Electric range
General Electric JRS06SK1SS Electric range
Jenn-Air JRS1202W REF - SXS
Jenn-Air JRS202 REF - SXS
Jenn-Air JRS202B REF - SXS
Jenn-Air JRS202H REF - SXS
Jenn-Air JRS202L REF - SXS
Jenn-Air JRS202N REF - SXS
Jenn-Air JRS202W REF - SXS
Jenn-Air JRS203 REF - SXS
Jenn-Air JRS203-AQ01B JENN-AIR REFRIGERATION
Jenn-Air JRS203-BQ01A JENN-AIR REFRIGERATION
Jenn-Air JRS203B Ref - Sxs
Jenn-Air JRS205L REF - SXS
Jenn-Air JRS205W REF - SXS
Jenn-Air JRS206A REF - SXS
Jenn-Air JRS206W REF - SXS
Jenn-Air JRS221 REF - SXS
Jenn-Air JRS223 REF - SXS
Jenn-Air JRS223B REF - SXS
Jenn-Air JRS223L REF - SXS
Jenn-Air JRS223N REF - SXS
Jenn-Air JRS223W REF - SXS
Jenn-Air JRS226 REF - SXS
Jenn-Air JRS226B REF - SXS
Jenn-Air JRS226L REF - SXS
Jenn-Air JRS226N REF - SXS
Jenn-Air JRS226W REF - SXS
Jenn-Air JRS227B REF - SXS
Jenn-Air JRS227W REF - SXS
Jenn-Air JRS228B REF - SXS
Jenn-Air JRS228W REF - SXS
Jenn-Air JRS229A REF - SXS
Jenn-Air JRS229B REF - SXS
Jenn-Air JRS229W REF - SXS
Jenn-Air JRSD209A REF - SXS/I&W
Jenn-Air JRSD209B REF - SXS/I&W
Jenn-Air JRSD209TA REF - SXS/I&W
Jenn-Air JRSD209TB REF - SXS/I&W
Jenn-Air JRSD209TW REF - SXS/I&W
Jenn-Air JRSD209W REF - SXS/I&W
Jenn-Air JRSD224 REF - SXS/I&W
Jenn-Air JRSD224B REF - SXS/I&W
Jenn-Air JRSD224L REF - SXS/I&W
Jenn-Air JRSD224N REF - SXS/I&W
Jenn-Air JRSD224W REF - SXS/I&W
Jenn-Air JRSD225 REF - SXS/I&W
Jenn-Air JRSD2250A REF - SXS/I&W
Jenn-Air JRSD2250W REF - SXS/I&W
Jenn-Air JRSD225B Ref - SXS/I&W
Jenn-Air JRSD225L REF - SXS/I&W
Jenn-Air JRSD226 REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven flashing Locked Door & won't heat Doreen in FL Oven Repair (including Ranges and Cooktops) 5 09-28-2016 02:16 PM
GE Wall Oven Locked and Dead vqamarty Oven Repair (including Ranges and Cooktops) 1 02-07-2011 07:47 PM
GE Wall Oven - Locked Door troche Oven Repair (including Ranges and Cooktops) 0 02-23-2010 09:48 AM
oven thinks its locked flashing codes emsdoc Oven Repair (including Ranges and Cooktops) 1 12-25-2007 01:23 PM
