Discuss
Fan runs when Temperature Sensor is disconnected
 in
I have a Maytag double wall oven that once it reaches temperature will not maintain the temperature at all in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Fan runs when Temperature Sensor is disconnected
  #1 (permalink)
Old 07-07-2017, 10:45 PM
Junior Member
wallstreet847 is on a distinguished road
Default Fan runs when Temperature Sensor is disconnected
Model Number: MEW5630DDB   Brand: Maytag   Age: 5 - 10 years
I have a Maytag double wall oven that once it reaches temperature will not maintain the temperature at all in either oven. However, no error codes have been displayed. Checking the temperature sensors on both sensors provided Ohm readings of 1085. I assumed this was a sign they are probably good. However, when the sensors are disconnected (Cold oven) for testing the fan comes on. I have read a lot of posts and not heard anyone mention this (probably because they had power off). But is it normal for the fan to come on if a sensor is not connected or does this indicate some other issue?
Other comments- I unplugged the connector for the sensor from the control board and the fan comes on then as well.
I replaced the control board and the fan still comes on when the sensor is disconnected (replacing the board did not resolve the oven temperature issue either).
I also replaced the Hi-limit Thermostat and it did not resolve the fan coming on or the oven temperature issue.
Not sure what else to do except replace the temperature sensors but find it hard to believe they are both bad. Any suggestions or guidance is appreciated?
Related Models
Maytag MEW5630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDB17 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDS10 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDW18 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6527BAB WALLOVEN- S/C ELE
Maytag MEW6527BAC WALLOVEN- S/C ELE
Maytag MEW6527BAQ WALLOVEN- S/C ELE
Maytag MEW6527BAS WALLOVEN- S/C ELE
Maytag MEW6527BAW WALLOVEN- S/C ELE
Maytag MEW6527CAS WALLOVEN- S/C ELE
Maytag MEW6527DDB WALLOVEN- S/C ELE
Maytag MEW6527DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDQ WALLOVEN- S/C ELE
Maytag MEW6527DDS WALLOVEN- S/C ELE
Maytag MEW6527DDS18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDW WALLOVEN- S/C ELE
Maytag MEW6527DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6530AAB WALLOVEN- S/C ELE
Maytag MEW6530AAW WALLOVEN- S/C ELE
Maytag MEW6530ACB WALLOVEN- S/C ELE
Maytag MEW6530ACW WALLOVEN- S/C ELE
Maytag MEW6530BAB WALLOVEN- S/C ELE
Maytag MEW6530BAC WALLOVEN- S/C ELE
Maytag MEW6530BAQ WALLOVEN- S/C ELE
Maytag MEW6530BAS WALLOVEN- S/C ELE
Maytag MEW6530BAW WALLOVEN- S/C ELE
Maytag MEW6530BCB WALLOVEN- S/C ELE
Maytag MEW6530BCW WALLOVEN- S/C ELE
Maytag MEW6530CAS WALLOVEN- S/C ELE
Maytag MEW6530DDB WALLOVEN- S/C ELE
Maytag MEW6530DDB19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDQ WALLOVEN- S/C ELE
Maytag MEW6530DDS WALLOVEN- S/C ELE
Maytag MEW6530DDS19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDW WALLOVEN- S/C ELE
Maytag MEW6530DDW20 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6627BAB WALLOVEN- S/C ELE
Maytag MEW6627BAC WALLOVEN- S/C ELE
Maytag MEW6627BAQ WALLOVEN- S/C ELE
Maytag MEW6627BAS WALLOVEN- S/C ELE
Maytag MEW6627BAW WALLOVEN- S/C ELE
Maytag MEW6627CAS WALLOVEN- S/C ELE
Maytag MEW6627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDB18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDW18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630BAB WALLOVEN- S/C ELE
Maytag MEW6630BAC WALLOVEN- S/C ELE
Maytag MEW6630BAQ WALLOVEN- S/C ELE
Maytag MEW6630BAS WALLOVEN- S/C ELE
Maytag MEW6630BAW WALLOVEN- S/C ELE
Maytag MEW6630CAS WALLOVEN- S/C ELE
Maytag MEW6630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDB19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDW20 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW7530WDB01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7530WDS01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7530WDW01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7630WDB01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Maytag MEW7630WDS01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Maytag MEW7630WDW01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Frigidaire MEX731CFS0 Universal/laundry Center
Frigidaire MEX731CFS1 LAUNDRY CENTER
Frigidaire MEX731CFS2 LAUNDRY CENTER
Frigidaire MEX731CFS4 LAUNDRY CENTER
Frigidaire MF18P2 Frg(v1) / 18 " Dishwasher
Frigidaire MF18PA2 Frg(v4) / 18 " Dishwasher
Frigidaire MF18PF2 Frg(v3) / 18 " Dishwasher
Frigidaire MF18PH2 Frg(v2) / 18 " Dishwasher
Frigidaire MF18PW2 Frg(v5) / 18 " Dishwasher
Frigidaire MFC05M0AW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M0BW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M0BW1 Wwh(v1) / Freezer
Frigidaire MFC05M0BW2 Wwh(v2) / Freezer
Frigidaire MFC05M0BW3 Frg(v0) / Freezer
Frigidaire MFC05M0BW4 Frg(v0) / Freezer
Frigidaire MFC05M0BW5 Frg(v0) / Freezer
Frigidaire MFC05M0BW6 Frigidaire/freezer
Frigidaire MFC05M1AW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M1BW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M1BW1 Kel(v1) / Chest Freezer
Frigidaire MFC05M1BW2 Wwh(v1) / Freezer
Frigidaire MFC05M1FW0 Frg(v0) / Freezer
Frigidaire MFC05M1FW1 Frg(v0) / Freezer
Frigidaire MFC05M3B Wwh(v0) / Chest Freezer
Frigidaire MFC05M3BW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M3BW1 Frg(v0) / Chest Freezer
Frigidaire MFC05M3BW2 Tap(v0) / Freezer
Frigidaire MFC05M3BW3 Frg(v0)
Frigidaire MFC05M3BW4 Frg(v0) / Freezer
Frigidaire MFC05M3BW5 Frg(v0) / Freezer
Frigidaire MFC05M3BW6 Frigidaire/freezer
Frigidaire MFC07M1BW0 Frg(v1) / Chest Freezer
Frigidaire MFC07M1BW1 Kel(v2) / Chest Freezer
Frigidaire MFC07M1BW2 Wwh(v2) / Freezer
Frigidaire MFC07M1BW3 Frg(v1) / Chest Freezer
Frigidaire MFC07M1BW4 Frg(v1) / Freezer
Frigidaire MFC07M1BW5 Frigidaire/freezer
Frigidaire MFC07M2AW0 Frg(v1) / Chest Freezer
Frigidaire MFC07M3BW0 Frg(v1) / Chest Freezer
Frigidaire MFC07M3BW1 Tap(v0) / Chest Freezer
Frigidaire MFC07M3BW2 Wwh(v0) / Chest Freezer
Frigidaire MFC07M3BW3 Frg(v1) / Chest Freezer
Frigidaire MFC07M3BW4 Frg(v1) / Freezer
Frigidaire MFC07M3FW0 Frg(v1) / Freezer
Frigidaire MFC07M3FW1 Frg(v1) / Freezer
Frigidaire MFC07M3FW3 Frigidaire/freezer
Frigidaire MFC07M3FW4 Frigidaire/freezer
Frigidaire MFC09M1BW0 Frg(v1) / Chest Freezer
Frigidaire MFC09M1BW1 Kel(v3) / Chest Freezer
Frigidaire MFC09M1BW2 Wwh(v3) / Freezer
Frigidaire MFC09M1BW3 Frg(v2) / Chest Freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to install temperature sensor and defrost sensor mhart Refrigerator & Freezer Repair 1 04-23-2013 07:57 AM
Temperature Sensor memphisyinzer Oven Repair (including Ranges and Cooktops) 1 03-25-2011 05:07 PM
Temperature sensor nobigdeal Oven Repair (including Ranges and Cooktops) 0 03-04-2011 04:22 PM
Temperature Sensor mrob Oven Repair (including Ranges and Cooktops) 1 09-07-2010 03:27 AM
Temperature Sensor ARTYSMARTY2 Refrigerator & Freezer Repair 0 12-14-2009 11:56 AM
