Discuss
Double Ovens bottom element shuts off when top oven turned on.
 in
Picture this. Double oven. Top with upper and lower elements. Bottom with upper and lower elements. Turn on the bottom
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Double Ovens bottom element shuts off when top oven turned on.
  #1 (permalink)
Old 06-27-2017, 01:30 PM
Junior Member
boxpin is on a distinguished road
Default Double Ovens bottom element shuts off when top oven turned on.
Model Number: RBD305PDB14   Brand: Whirlpool   Age: More than 10 years
Turn on the bottom oven. Both upper and lower elements heat up. Everything going well.
With the bottom oven heating, turn on the top oven. The top oven heats up, both elements BUT the bottom ovens lower element shuts off. The bottom ovens upper element continues to heat. Now three of the four elements are heating.
Turn off both ovens. Turn on the bottom oven and both elements heat. Everything is going well...again.
Turn on the top oven and change the default temperature to something other than 350deg. Both ovens work fine.
For some reason when both ovens are used and the temp is not changed the bottom ovens lower element shuts off. Change the temp and the oven works fine.
Related Models
Whirlpool RBD305PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB2 ELECTRIC OVEN
Whirlpool RBD305PDB3 ELECTRIC OVEN
Whirlpool RBD305PDB4 ELECTRIC OVEN
Whirlpool RBD305PDB6 ELECTRIC OVEN
Whirlpool RBD305PDB7 ELECTRIC OVEN
Whirlpool RBD305PDB8 ELECTRIC OVEN
Whirlpool RBD305PDB9 ELECTRIC OVEN
Whirlpool RBD305PDQ1 ELECTRIC OVEN
Whirlpool RBD305PDQ10 ELECTRIC OVEN
Whirlpool RBD305PDQ11 ELECTRIC OVEN
Whirlpool RBD305PDQ12 ELECTRIC OVEN
Whirlpool RBD305PDQ13 ELECTRIC OVEN
Whirlpool RBD305PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ2 ELECTRIC OVEN
Whirlpool RBD305PDQ3 ELECTRIC OVEN
Whirlpool RBD305PDQ4 ELECTRIC OVEN
Whirlpool RBD305PDQ6 ELECTRIC OVEN
Whirlpool RBD305PDQ7 ELECTRIC OVEN
Whirlpool RBD305PDQ8 ELECTRIC OVEN
Whirlpool RBD305PDQ9 ELECTRIC OVEN
Whirlpool RBD305PDS12 ELECTRIC OVEN
Whirlpool RBD305PDS14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDS15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT11 ELECTRIC OVEN
Whirlpool RBD305PDT12 ELECTRIC OVEN
Whirlpool RBD305PDT13 ELECTRIC OVEN
Whirlpool RBD305PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB1 Built-In Oven, Electric
Whirlpool RBD306PDB10 OVEN
Whirlpool RBD306PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB12 OVEN
Whirlpool RBD306PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB2 Built-In Oven, Electric
Whirlpool RBD306PDB4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDB8 ELECTRIC WALL OVEN
Whirlpool RBD306PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ1 Built-In Oven, Electric
Whirlpool RBD306PDQ10 OVEN
Whirlpool RBD306PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ12 OVEN
Whirlpool RBD306PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ2 Built-In Oven, Electric
Whirlpool RBD306PDQ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT12 OVEN
Whirlpool RBD306PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDZ1 30" BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ10 OVEN
Whirlpool RBD306PDZ2 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDZ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD307PDB1 ELECTRIC OVEN
Whirlpool RBD307PDB2 ELECTRIC OVEN
Whirlpool RBD307PDQ1 ELECTRIC OVEN
Whirlpool RBD307PDQ2 ELECTRIC OVEN
Whirlpool RBD307PDQ4 ELECTRIC OVEN
Whirlpool RBD307PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVS03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Maytag RBE170PA REF - TOP MOUNT
Maytag RBE170PW REF - TOP MOUNT
Maytag RBE170TA REF - TOP MOUNT
Maytag RBE170TM REF - TOP MOUNT
Maytag RBE170TV REF - TOP MOUNT
Maytag RBE170TW REF - TOP MOUNT
Maytag RBE17KA-0A REF - TOP MOUNT
Maytag RBE17KN-0A REF - TOP MOUNT
Maytag RBE193PA REF - TOP MOUNT
Maytag RBE193PW REF - TOP MOUNT
Maytag RBE193TA REF - TOP MOUNT
Maytag RBE193TM REF - TOP MOUNT
Maytag RBE193TV REF - TOP MOUNT
Maytag RBE193TW REF - TOP MOUNT
Maytag RBE19KA-3A REF - TOP MOUNT
Maytag RBE19KN-3A REF - TOP MOUNT
Maytag RBE19KY-3A REF - TOP MOUNT
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stove top element heats up when oven is turned on and will not turn off garysmart2@gmail.com Oven Repair (including Ranges and Cooktops) 0 05-16-2016 06:27 PM
GE double oven (both ovens) will not stay on KTBryant Oven Repair (including Ranges and Cooktops) 1 09-27-2015 07:40 PM
GE Double Oven Bottom Oven shuts off bobgto65 Oven Repair (including Ranges and Cooktops) 0 03-29-2014 03:38 PM
Ovens top bake element will come on and heat up but the bottom one will not ah1988 Oven Repair (including Ranges and Cooktops) 5 05-25-2013 02:50 AM
ovens dont come on maytag gas double oven daveadawn Oven Repair (including Ranges and Cooktops) 1 04-03-2012 11:04 AM
