Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Double Ovens bottom element shuts off when top oven turned on. (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/570418-double-ovens-bottom-element-shuts-off-when-top-oven-turned.html)
boxpin 06-27-2017 01:30 PM
Picture this. Double oven. Top with upper and lower elements. Bottom with upper and lower elements.
Turn on the bottom oven. Both upper and lower elements heat up. Everything going well.
With the bottom oven heating, turn on the top oven. The top oven heats up, both elements BUT the bottom ovens lower element shuts off. The bottom ovens upper element continues to heat. Now three of the four elements are heating.
Turn off both ovens. Turn on the bottom oven and both elements heat. Everything is going well...again.
Turn on the top oven and change the default temperature to something other than 350deg. Both ovens work fine.
For some reason when both ovens are used and the temp is not changed the bottom ovens lower element shuts off. Change the temp and the oven works fine.
