Discuss
Amana oven not keeping correct temp
 in
Hi, First time poster. I have an AMANA Range Model: AGR5735QDB that will not keep a constant temp. It took
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana oven not keeping correct temp
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-21-2008, 06:31 PM
jlandwehr jlandwehr is offline
Junior Member
jlandwehr is on a distinguished road
Default Amana oven not keeping correct temp
Model Number: AGR5735QDB   Brand: Amana   Age: 1 - 5 years
First time poster. I have an AMANA Range Model: AGR5735QDB that will not keep a constant temp. It took 35 min. to cook a frozen pizza last nite. I replaced the igniter 7 mo. ago, so it's likely not that. My question is, is the oven temp controlled by the "oven sensor kit"? If so, that looks easy enough to replace, is it?
Any help appreciated. This cursed stove is less than 3 years old. Doesn't anyone make anything that lasts anymore? I think the part # I need is PS46172.
Thanks in advance.
Jim
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-22-2008, 03:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Thanks in advance.
Jim
Hi Jim,
Before making any decision I need you to measure the oven temperature.
Place the regular oven thermometer in the middle of the oven, set the temperature control for 350° and wait at least 15 minutes after the oven preheated.
Post the result, please.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-23-2008, 08:18 AM
Junior Member
Default Amana oven not setting correct temp
Quote:
Originally Posted by Gene View Post
Hi Jim,
Hi Gene,
It's varying between 297-307, but occasionally will dip to as low as 237. It's just not staying consistent at all.
Thanks in advance for any advice.
Jim
  #4 (permalink)
Old 02-24-2008, 03:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jim,
There are two suspects of the failure: the oven temperature sensor and the control board.
The first thing I would check is the oven temperature sensor resistance at the control board.
Remove the sensor plug from the board and measure the resistance across the sensor wires. It suppose to be about 1100 Ohms at the room temperature.
If the reading is right then the control board has to be replaced.
If the reading is wrong then pull the range, remove the rear cover and measure the sensor resistance at the sensor plug (where it's coming through the wall). I would recommend to eliminate the sensor plug and hardwire it using a high temperature porcelain wire nuts to ensure proper connection.
If the reading is wrong then replace the sensor.
If the reading is right then check the wires and the plug connection at the control board.
- The part number for the oven temperature sensor is AP204835
- The part number for the high temperature porcelain wire nuts is AP3440522
- The part number for the control board is AP3503544
__________________
  #5 (permalink)
Old 02-24-2008, 03:39 PM
Junior Member
Default Thanks
Gene,
Thanks for the recommendations. Being a bit of a novice, I may just replace the sensor (the $40.00 route) and see if that fixes the problem. If it's a control board, that's expensive and then the fine folks at Amana will hear from me!
Thanks again.
Jim
  #6 (permalink)
Old 03-02-2008, 03:16 PM
Junior Member
Default
Hi again,
FYI, I replaced the sensor, and the oven, though a few degrees hot, is at least maintaining a constant temp again. Thanks for your help/advice!
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't reach correct heat AnnH Oven Repair (including Ranges and Cooktops) 3 01-16-2008 03:55 PM
Oven not keeping correct Temperature Andrew Mail Oven Repair (including Ranges and Cooktops) 1 11-27-2007 03:34 PM
Oven will not heat to correct temperature Luapam Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:19 AM
correct burner element 123harlan Oven Repair (including Ranges and Cooktops) 0 09-26-2007 12:49 PM
not keeping cold or freezing davidsargeant Refrigerator & Freezer Repair 0 07-25-2007 06:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
