Discuss
Magic Chef Oven Won't Heat to Set Temp
 in
Hey folks! Oven won't get up to proper cooking temp! It's an older magic chef model, I can supply pictures
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic Chef Oven Won't Heat to Set Temp
  #1 (permalink)
Old 06-21-2017, 09:54 AM
Junior Member
MovingUp7 is on a distinguished road
Default Magic Chef Oven Won't Heat to Set Temp
Model Number: Magic Chef   Brand: Maytag   Age: Less than 1 year
Hey folks! Oven won't get up to proper cooking temp! It's an older magic chef model, I can supply pictures but I don't have the model number. Symptoms:
- Set oven to 400. In a couple minutes, display shows room temp and slowly climbs up as high as 250 or so. Doesn't go higher than that. It used to say 400 until the preheat cycle was done.
- While "preheating", the top and bottom heating elements do now glow.
- If oven is set to the broil setting, the top element does glow bright orange and seems to work.
It seems like it must be something in the computer or control center as it just seems spazzy, but maybe a sensor is confusing the computer?
The picture showing temp at 195 is after setting it to 400 and it pathetically crawling to 195. It shows the heating elements as brown and not glowing while the display is 195.
Related Models
Maytag MAH14PDAAL MANUAL, PARTS (WASHER)
Maytag MAH14PDAAQ MANUAL, PARTS (WASHER)
Maytag MAH14PDAAW MANUAL, PARTS (WASHER)
Maytag MAH14PDABL MANUAL, PARTS (WASHER)
Maytag MAH14PDABW MANUAL, PARTS (WASHER)
Maytag MAH14PDAEW MANUAL, PARTS (WASHER)
Maytag MAH14PDAGW MANUAL, PARTS (WASHER)
Maytag MAH14PDBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDSAW MANUAL, PARTS (WASHER)
Maytag MAH14PNAEW MANUAL, PARTS (WASHER)
Maytag MAH14PNAGW MANUAL, PARTS (WASHER)
Maytag MAH14PNAWW MANUAL, PARTS (WASHER)
Maytag MAH14PNBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNSAW MANUAL, PARTS (WASHER)
Maytag MAH14PRAWW MANUAL, PARTS (WASHER)
Maytag MAH14PSAAW MANUAL, PARTS (WASHER)
Maytag MAH20PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PSAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDD3W LAUNDRY PRODUCT (WASHER)
Maytag MAH21PDDGW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWQ LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDXW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PNAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDWW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PRAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PRDWW LAUNDRY PRODUCT (WASHER)
Maytag MAH21PSAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PSDWW LAUNDRY PRODUCT (WASHER)
Maytag MAH22PDAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAWW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAXW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDBWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDBXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRAWW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRBWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH2400AWW WASHER- HORIZONTAL AXIS
Maytag MAH2440AGW WASHER- HORIZONTAL AXIS
Maytag MAH2440BGW WASHER- HORIZONTAL AXIS
Maytag MAH3000AAW WASHER- HORIZONTAL AXIS
Maytag MAH3000AEW WASHER- HORIZONTAL AXIS
Admiral MAH3000AGW WASHER- HORIZONTAL AXIS
Admiral MAH3000AKW WASHER- HORIZONTAL AXIS
Maytag MAH3000AWA WASHER- HORIZONTAL AXIS
Maytag MAH3000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH3000AWW WASHER- HORIZONTAL AXIS
Admiral MAH3000BGW WASHER- HORIZONTAL AXIS
Maytag MAH4000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000AWW WASHER- HORIZONTAL AXIS
Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000BWW WASHER- HORIZONTAL AXIS
Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500AWW WASHER- HORIZONTAL AXIS
Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
File Type: jpg 57c64cfcc58d3ac29af3d46dd58450483c2b1358-1.jpg (50.1 KB, 1 views)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef oven temp probe thermos Duane22 Oven Repair (including Ranges and Cooktops) 0 02-04-2010 04:35 PM
Magic Chef oven , broiler, will not turn on NO temp display jeffL Oven Repair (including Ranges and Cooktops) 0 11-24-2009 11:08 AM
Magic Chef oven temp bioblues Oven Repair (including Ranges and Cooktops) 3 11-07-2009 08:58 AM
Magic Chef Oven does not reach indicated temp szp5f3 Oven Repair (including Ranges and Cooktops) 1 09-01-2009 10:12 AM
Magic Chef Oven Not Heating to Set Temp djandm1 Oven Repair (including Ranges and Cooktops) 1 10-10-2008 09:26 AM
