Discuss
Gas stove no bake or broil, ignitors glow, safety valve has continuity
 in
I tried poring over the posts here before posting. Lots of folks offer up control board. Is there a way
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas stove no bake or broil, ignitors glow, safety valve has continuity
  #1 (permalink)
Old 06-17-2017, 05:35 AM
Junior Member
arpee is on a distinguished road
Default Gas stove no bake or broil, ignitors glow, safety valve has continuity
Model Number: FGFL77ASE   Brand: Frigidaire   Age: Less than 1 year
I tried poring over the posts here before posting. Lots of folks offer up control board. Is there a way to troubleshoot the board before ordering?
Bake and Broil both stopped working at the same time, both ignitors glow cheerfully. I tested the safety valve and there is continuity across the posts.
TIA,
rp
Related Models
Frigidaire FGFL77ASE Frigidaire/gas Range
Frigidaire FGFL77ASF Frigidaire/gas Range
Frigidaire FGFL77ASH Frigidaire/gas Range
Frigidaire FGFL77ASJ Frigidaire/gas Range
Frigidaire FGFL79DBA Frigidaire/gas Range
Frigidaire FGFL79DBB Frigidaire/range
Frigidaire FGFL79DBC Frigidaire/range
Frigidaire FGFL79DBE Frigidaire/range
Frigidaire FGFL79DBF Frigidaire/range
Frigidaire FGFL79DBG Frigidaire/range
Frigidaire FGFL79DBH Frigidaire/range
Frigidaire FGFL79DCA Frigidaire/gas Range
Frigidaire FGFL79DCB Frigidaire/gas Range
Frigidaire FGFL79DCC Frigidaire/range
Frigidaire FGFL79DCD Frigidaire/range
Frigidaire FGFL79DQA Frigidaire/gas Range
Frigidaire FGFL79DQB Frigidaire/range
Frigidaire FGFL79DQC Frigidaire/range
Frigidaire FGFL79DQE Frigidaire/range
Frigidaire FGFL79DQF Frigidaire/range
Frigidaire FGFL79DQG Frigidaire/range
Frigidaire FGFL79DQH Frigidaire/range
Frigidaire FGFL79DSA Frigidaire/gas Range
Frigidaire FGFL79DSB Frigidaire/range
Frigidaire FGFL79DSC Frigidaire/range
Frigidaire FGFL79DSE Frigidaire/range
Frigidaire FGFL79DSF Frigidaire/range
Frigidaire FGFL79DSG Frigidaire/range
Frigidaire FGFL79DSH Frigidaire/range
Frigidaire FGFL79ECA Frigidaire/gas Range
Frigidaire FGFL79ECB Frigidaire/gas Range
Frigidaire FGFL79ECD Frigidaire/range
Frigidaire FGFL79FCA Frigidaire/gas Range
Frigidaire FGFL79FCB Frigidaire/range
Frigidaire FGFL79FCC Frigidaire/range
Frigidaire FGFL79GBA GAS RANGE
Frigidaire FGFL79GBB GAS RANGE
Frigidaire FGFL79GBC GAS RANGE
Frigidaire FGFL79GBD GAS RANGE
Frigidaire FGFL79GBE GAS RANGE
Frigidaire FGFL79GBF GAS RANGE
Frigidaire FGFL79GCA GAS RANGE
Frigidaire FGFL79GCB GAS RANGE
Frigidaire FGFL79GCC GAS RANGE
Frigidaire FGFL79GCD GAS RANGE
Frigidaire FGFL79GCE GAS RANGE
Frigidaire FGFL79GCF GAS RANGE
Frigidaire FGFL79GCG GAS RANGE
Frigidaire FGFL79GCH GAS RANGE
Frigidaire FGFL79GQA GAS RANGE
Frigidaire FGFL79GQB GAS RANGE
Frigidaire FGFL79GQC GAS RANGE
Frigidaire FGFL79GQD GAS RANGE
Frigidaire FGFL79GQE GAS RANGE
Frigidaire FGFL79GQF GAS RANGE
Frigidaire FGFL79GSA GAS RANGE
Frigidaire FGFL79GSB GAS RANGE
Frigidaire FGFL79GSC GAS RANGE
Frigidaire FGFL79GSD GAS RANGE
Frigidaire FGFL79GSE GAS RANGE
Frigidaire FGFL79GSF GAS RANGE
Frigidaire FGFL83DQA Frigidaire/gas Range
Frigidaire FGFL83DQB Frigidaire/range
Frigidaire FGFL83DQE Frigidaire/gas Range
Frigidaire FGFL83DSA Frigidaire/gas Range
Frigidaire FGFL83DSB Frigidaire/range
Frigidaire FGFL83DSE Frigidaire/gas Range
Frigidaire FGFL87DCA Frigidaire/gas Range
Frigidaire FGFL87DCB Frigidaire/gas Range
Frigidaire FGFL87DCC Frigidaire/range
Frigidaire FGFL87DCD Frigidaire/range
Frigidaire FGFL87DCE Frigidaire/range
Frigidaire FGFL87DCF Frigidaire/gas Range
Frigidaire FGFL87DCG Frigidaire/range
Frigidaire FGFL87DQA Frigidaire/gas Range
Frigidaire FGFL87DQB Frigidaire/range
Frigidaire FGFL87DQC Frigidaire/range
Frigidaire FGFL87DQE Frigidaire/range
Frigidaire FGFL87DQF Frigidaire/range
Frigidaire FGFL87DQG Frigidaire/range
Frigidaire FGFL87DSA Frigidaire/gas Range
Frigidaire FGFL87DSB Frigidaire/range
Frigidaire FGFL87DSC Frigidaire/range
Frigidaire FGFL87DSE Frigidaire/range
Frigidaire FGFL87DSF Frigidaire/range
Frigidaire FGFL87DSG Frigidaire/range
Frigidaire FGFL87GSA GAS RANGE
Frigidaire FGFL87GSB GAS RANGE
Frigidaire FGFL87GSC GAS RANGE
Frigidaire FGFL87GSD GAS RANGE
Frigidaire FGFL87GSE GAS RANGE
Frigidaire FGFL87GSF GAS RANGE
Frigidaire FGFL87GSG GAS RANGE
Frigidaire FGFL87GSH GAS RANGE
Frigidaire FGFL88ACA Frigidaire/gas Range
Frigidaire FGFL88ACB Frigidaire/gas Range
Frigidaire FGFL88ACC Frigidaire/gas Range
Frigidaire FGFL88ASA Frigidaire/gas Range
Frigidaire FGFL88ASB Frigidaire/gas Range
Frigidaire FGFL89CCA Frigidaire/gas Range
Frigidaire FGFL89CCB Frigidaire/gas Range
Frigidaire FGFLMC55ECA Frigidaire/gas Range
Frigidaire FGFLMC55ECB Frigidaire/range
Frigidaire FGFLMC55ECC Frigidaire/range
Frigidaire FGFLMC55GCA GAS RANGE
Frigidaire FGFLMC55GCB GAS RANGE
Frigidaire FGFLMC55GCC GAS RANGE
Frigidaire FGFLMC55GCE GAS RANGE
Frigidaire FGFLMC55GCF GAS RANGE
Frigidaire FGFLMC55GCG GAS RANGE
Frigidaire FGFLMC55GCH GAS RANGE
Frigidaire FGFLMC55GCJ GAS RANGE
Frigidaire FGFLMC55GCK GAS RANGE
Frigidaire FGFLZ87GCA GAS RANGE
Frigidaire FGFLZ87GCB GAS RANGE
Frigidaire FGFLZ87GCC GAS RANGE
Frigidaire FGFLZ87GCE GAS RANGE
Frigidaire FGFLZ87GCF GAS RANGE
Frigidaire FGFLZ87GCG GAS RANGE
Frigidaire FGFLZ87GCH GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bad safety valve or 3 bad ignitors? cappy319 Oven Repair (including Ranges and Cooktops) 0 02-08-2015 06:17 AM
Kenmore, no bake/broil and no glow on ignitors cpy911 Oven Repair (including Ranges and Cooktops) 0 10-01-2014 04:31 PM
If bake and broil ignitors glow but don't ignite, could it be just bake? jfryjfry Oven Repair (including Ranges and Cooktops) 0 09-15-2014 04:20 PM
New oven bake/broil Ignitors not working, and only 60v power at ignitor wires. mnalep Oven Repair (including Ranges and Cooktops) 2 07-15-2013 07:35 PM
Oven Bake and Broil ignitors jsam Oven Repair (including Ranges and Cooktops) 10 06-17-2009 01:40 PM
