I have an oven that won't heat. I checked resistance of elements and around 20 ohms. Thermostat has resistance. I checked from each element to chassis and there is 120 volts. I checked from L1 to Bake and Broil terminal on circuit board and have no voltage. Does this mean that the circuit board in defective or is there other checks I should do before ordering circuit board.
