Discuss
Whirlpool Double Oven - Control Board & Door latch assembly???
 in
So my whirlpool double oven ran into the same issue that it seems many peoples do - the oven stopped
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven - Control Board & Door latch assembly???
  #1 (permalink)
Old 06-06-2017, 09:09 PM
Junior Member
Bhauer is on a distinguished road
Default Whirlpool Double Oven - Control Board & Door latch assembly???
Brand: Whirlpool   Age: 5 - 10 years
So my whirlpool double oven ran into the same issue that it seems many peoples do - the oven stopped working during the self cleaning cycle.
I was told the oven needed a control board and door latch assembly replaced. Does that sound correct? Seems to me if the control board went out, the door latch assembly wouldn't work. Can I assume I was given the right diagnosis? or should I be skeptical...
I know this is very broad without a model# but the does the logic make sense to have both replaced? Cost differences are pretty significant to do both vs only 1.
Any help would be great!
  #2 (permalink)
Old 06-06-2017, 09:55 PM
Junior Member
Default
Its a Whirlpool Gold GBD307PRS.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Board or Door Latch Assembly - Error D0 E40 E41 Scotts_Spot Washer Repair 0 04-13-2013 12:07 PM
Whirlpool Double Oven Control Board Replacement destan Oven Repair (including Ranges and Cooktops) 2 06-29-2012 11:21 AM
Whirlpool Double Oven Control Board Alan100 Oven Repair (including Ranges and Cooktops) 1 05-22-2012 12:40 PM
Whirlpool Double Oven Control Board issue djalbright Oven Repair (including Ranges and Cooktops) 0 10-05-2011 08:53 PM
whirlpool double oven control board burnt out? nevadamike Oven Repair (including Ranges and Cooktops) 0 12-25-2009 06:25 PM
