Discuss
Viking range oven smells of gas when lit
 in
I am seeking help determining the cause of an intermittent natural gas smell that happens when igniting the oven on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking range oven smells of gas when lit
  #1 (permalink)
Old 06-06-2017, 04:59 AM
Junior Member
millergd999 is on a distinguished road
Default Viking range oven smells of gas when lit
Model Number: VGRC365   Brand: -other-   Age: More than 10 years
I am seeking help determining the cause of an intermittent natural gas smell that happens when igniting the oven on my 13 year old Viking VGRC365 range.
The issue is that when the oven is turned on for pre-heating, it leaves a pungent natural gas smell for the first few seconds before ignition that permeates the house. This happens during about 50% of the time when turning the oven on. Once the burner ignites, the smell mitigates, so it seems to be an issue during start-up.
The Tytronic spark module and the lower two oven glow ignitors were replaced in the last 4 months with OEM parts yet the problem persists.
Also, during oven pre-heat, the stove burners have difficulty lighting and produce a constrained flame. Often during pre-heat, the burner is slow to ignite and only forms a semi-circle of flames. The flames are blue, even if a full ring is not formed.
I'm trying to figure out if this is a gas pressure issue, normal behavior, or if I need to look elsewhere within the oven. I welcome any thoughts the forum may have on next steps.
Related Models
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000 VENTILATOR
Thermador VQT600 VENTILATOR
Thermador VR-1000 VENTILATOR
Thermador VR-1400 VENTILATOR
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Viking Range Oven Not Working clevergirl Oven Repair (including Ranges and Cooktops) 0 05-01-2016 01:33 PM
Viking Range smells of gas Gregavi Oven Repair (including Ranges and Cooktops) 0 09-07-2015 10:04 AM
Viking range replace oven thermostat rbcole123 Oven Repair (including Ranges and Cooktops) 0 08-15-2013 11:53 AM
Range only smells when oven is used zombiemomma Oven Repair (including Ranges and Cooktops) 2 01-01-2011 11:52 AM
Viking range oven won't heat mitchelllee Oven Repair (including Ranges and Cooktops) 0 10-04-2009 12:22 PM
