Discuss
One of four burners no ignition
 in
I have one burner of four which will not spark. I have to use a stick match to ignite.I believe
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » One of four burners no ignition
  #1 (permalink)
Old 06-04-2017, 05:58 AM
Junior Member
Sodbuster is on a distinguished road
Default One of four burners no ignition
Model Number: 31MA-3KX   Brand: Magic Chef   Age: More than 10 years
I have one burner of four which will not spark. I have to use a stick match to ignite.I believe it is the switch. However, I cannot find out how to disassemble the range to fix it. The manual states because it is a sealed burner, the top cannot be removed. I would appreciate any direction on the disassembly of this Magic Chef range model 31MA-3KX.
Related Models
Magic Chef 31MA-3KX RANGE- F/S STD GAS
Magic Chef 31MA-3KX-OC RANGE- F/S STD GAS
Magic Chef 31MA-3KX-ON RANGE- F/S STD GAS
Magic Chef 31MA-5KLX RANGE-F/S CONT CLEAN GAS
Magic Chef 31MA-5KV RANGE- F/S STD GAS
Magic Chef 31MA-5KX RANGE- F/S STD GAS
Magic Chef 31MN-23KX-ON RANGE- F/S STD GAS
Magic Chef 31MN-3KX RANGE- F/S STD GAS
Magic Chef 31MN-3KX-OC RANGE- F/S STD GAS
Magic Chef 31MN-3KX-ON RANGE- F/S STD GAS
Magic Chef 31MN-5KLX RANGE-F/S CONT CLEAN GAS
Magic Chef 31MN-5KV RANGE- F/S STD GAS
Magic Chef 31MN-5KX RANGE- F/S STD GAS
Hoover 32
Frigidaire 32-0007-00-02 Tap(v1) / Gas Range
Frigidaire 32-0007-00-03 Tap(v3) / Gas Range
Frigidaire 32-0007-00-05 Tap(v1) / Gas Range
Frigidaire 32-0007-23-02 Tap(v2) / Gas Range
Frigidaire 32-0007-23-03 Tap(v4) / Gas Range
Frigidaire 32-0007-23-05 Tap(v2) / Gas Range
Frigidaire 32-0027-00-02 Tap(v1)
Frigidaire 32-0027-00-03 Tap(v3)
Frigidaire 32-0027-00-04 Tap(v5)
Frigidaire 32-0027-23-02 Tap(v2)
Frigidaire 32-0027-23-03 Tap(v4)
Frigidaire 32-0027-23-04 Tap(v6)
Frigidaire 32-0117-00-02 Tap(v1) / Gas Range
Frigidaire 32-0117-00-03 Tap(v3) / Gas Range
Frigidaire 32-0117-23-02 Tap(v2) / Gas Range
Frigidaire 32-0117-23-03 Tap(v4) / Gas Range
Frigidaire 32-0127 ELECTRIC RANGE
Frigidaire 32-0127-00-02 Tap(v1) / Gas Range
Frigidaire 32-0127-00-03 Tap(v3) / Gas Range
Frigidaire 32-0127-23-02 Tap(v2) / Gas Range
Frigidaire 32-1002-00-01 (v1)
Frigidaire 32-1002-00-02 (v2)
Frigidaire 32-1002-00-03 (v3)
Frigidaire 32-1002-00-04 (v4)
Frigidaire 32-1002-00-05 (v5)
Frigidaire 32-1002-00-06 (v6)
Frigidaire 32-1002-00-07 (v7)
Frigidaire 32-1002-00-08 (v8)
Frigidaire 32-1002-00-09 (v9)
Frigidaire 32-1002-00-10 (v10)
Frigidaire 32-1002-00-11 (v11)
Frigidaire 32-1002-00-12 (v12)
Frigidaire 32-1002-23-01 (v13)
Frigidaire 32-1002-23-02 (v14)
Frigidaire 32-1002-23-03 (v15)
Frigidaire 32-1002-23-04 (v16)
Frigidaire 32-1002-23-05 (v17)
Frigidaire 32-1002-23-06 (v18)
Frigidaire 32-1002-23-07 (v19)
Frigidaire 32-1002-23-08 (v20)
Frigidaire 32-1002-23-09 (v21)
Frigidaire 32-1002-23-10 (v22)
Frigidaire 32-1002-23-11 (v23)
Frigidaire 32-1002-23-12 (v24)
Frigidaire 32-1002-32-01 (v13)
Frigidaire 32-1002-32-02 (v14)
Frigidaire 32-1002-32-03 (v15)
Frigidaire 32-1002-32-04 (v16)
Frigidaire 32-1002-32-05 (v17)
Frigidaire 32-1002-32-06 (v18)
Frigidaire 32-1002-32-07 (v19)
Frigidaire 32-1002-32-08 (v20)
Frigidaire 32-1002-32-09 (v21)
Frigidaire 32-1002-32-10 (v22)
Frigidaire 32-1002-32-11 (v23)
Frigidaire 32-1002-32-12 (v24)
Frigidaire 32-1002-45-01 (v1)
Frigidaire 32-1002-45-02 (v2)
Frigidaire 32-1002-45-03 (v3)
Frigidaire 32-1002-45-04 (v4)
Frigidaire 32-1002-45-05 (v5)
Frigidaire 32-1002-45-06 (v6)
Frigidaire 32-1002-45-07 (v7)
Frigidaire 32-1002-45-08 (v8)
Frigidaire 32-1002-45-09 (v9)
Frigidaire 32-1002-45-10 (v10)
Frigidaire 32-1002-45-11 (v11)
Frigidaire 32-1002-45-12 (v12)
Frigidaire 32-1002-57-01 (v13)
Frigidaire 32-1002-57-02 (v14)
Frigidaire 32-1002-57-03 (v15)
Frigidaire 32-1002-57-04 (v16)
Frigidaire 32-1002-57-05 (v17)
Frigidaire 32-1002-57-06 (v18)
Frigidaire 32-1002-57-07 (v19)
Frigidaire 32-1002-57-08 (v20)
Frigidaire 32-1002-57-09 (v21)
Frigidaire 32-1002-57-10 (v22)
Frigidaire 32-1002-57-11 (v23)
Frigidaire 32-1002-57-12 (v24)
Frigidaire 32-1002-66-01 (v1)
Frigidaire 32-1002-66-02 (v2)
Frigidaire 32-1002-66-03 (v3)
Frigidaire 32-1002-66-04 (v4)
Frigidaire 32-1002-66-05 (v5)
Frigidaire 32-1002-66-06 (v6)
Frigidaire 32-1002-66-07 (v7)
Frigidaire 32-1002-66-08 (v8)
Frigidaire 32-1002-66-09 (v9)
Frigidaire 32-1002-66-10 (v10)
Frigidaire 32-1002-66-11 (v11)
Frigidaire 32-1002-66-12 (v12)
Frigidaire 32-1004-00-01 Tap(v1) / Gas Range
Frigidaire 32-1004-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-00-01 Tap(v1) / Gas Range
Frigidaire 32-1007-00-02 Tap(v3) / Gas Range
Frigidaire 32-1007-00-03 Tap(v5) / Gas Range
Frigidaire 32-1007-00-04 Tap(v4) / Gas Range
Frigidaire 32-1007-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-23-02 Tap(v4) / Gas Range
Frigidaire 32-1007-23-03 Tap(v6) / Gas Range
Frigidaire 32-1007-23-04 Tap(v8) / Gas Range
Frigidaire 32-1008-00-01 Tap(v1) / Gas Range
Frigidaire 32-1008-00-02 Tap(v3) / Gas Range
Frigidaire 32-1008-23-01 Tap(v2) / Gas Range
Frigidaire 32-1008-23-02 Tap(v4) / Gas Range
  #2 (permalink)
Old 06-12-2017, 03:19 AM
Junior Member
Default
Looks like I stumped the panel on this one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no ignition spark to 5 top burners robert ga Oven Repair (including Ranges and Cooktops) 0 09-16-2015 01:52 PM
No ignition of burners and oven Memphisflier Oven Repair (including Ranges and Cooktops) 0 11-19-2014 06:02 PM
whirlpool cooktop burners heats slow minimum heat on all burners wigginscallie@yahoo,com Oven Repair (including Ranges and Cooktops) 1 08-15-2013 08:37 PM
no gas or ignition to one of four burners molson Oven Repair (including Ranges and Cooktops) 0 03-12-2012 06:55 PM
