Discuss
Kitchen Aid KEBC207KSS04 Slow to Heat Up
 in
Sorry about the length of this post, but I wanted to include as much detail as possible for anyone who
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchen Aid KEBC207KSS04 Slow to Heat Up
  #1 (permalink)
Old 05-31-2017, 05:46 PM
Junior Member
curlw is on a distinguished road
Default Kitchen Aid KEBC207KSS04 Slow to Heat Up
Model Number: KEBC207KSS04   Brand: Kitchen Aid   Age: More than 10 years
Sorry about the length of this post, but I wanted to include as much detail as possible for anyone who may be able to respond. Our Kitchen Aid KEBC207KSS04 Double Oven takes what seems to be a long time to reach the desired temperature setting. Over the 11 years since new, I have replaced a thermal fuse (self-cleaning gone bad), a thermostat and the control panel (display went out). We use standard in-oven mechanical thermometers to monitor actual oven temperature (TruTemp 3506). With the assistance of a friend who is an electrician, we checked the continuity of all 5 elements (2 bake, 2 broil, 1 convection) and they all tested fine. We checked incoming voltage at the junction box and at each element and all fine at 240v. We checked the temperature sensors in each oven and their resistance readings for room temperature and for an oven temperature at 400 degrees were spot on with the numbers in the oven's technical pamphlet. I can't find anything specifically wrong, but as an example of what is happening, when I set our lower oven to bake at 400 degrees, the display shows both the broil and the bake element as on (red squiggly lines) during the preheat phase. The display reflects Lo, then maybe 250, 300, etc. until at about the 10 minute mark the display reflects the desired 400 degrees, the beep occurs to let you know that preheat is complete, and the broil element turns off (I can tell because the red glow quickly goes away). However, the actual temperature in the oven at this point as monitored by 2 of the TruTemp oven thermometers placed in the left and right halves of the oven is only about 340 degrees. From this point, the temperature continues to climb more slowly towards 400 degrees as the broiler element is no longer helping the baking element. At the 15 minute mark, the actual temperature in the oven is 375. At the 20 minute mark, the actual temperature in the oven is 380, and at the 25 minute mark (since start) the actual oven temperature finally reaches and maintains 400 degrees. The upper oven provides similar results when tested but actually takes a few minutes longer to reach 400 degrees. My questions are the following - shouldn't the ovens reach the desired temperature more quickly? Why does the display (control panel) think the oven temperature is 400 degrees and end the preheat function (using both elements) well before the actual oven temperature reaches 400 degrees? If the control panel thinks the oven is at 400 degrees when it is actually at 340 degrees, why does the actual temperature in the oven continue to go up to finally reach a real 400 degrees? Why doesn't it stop and maintain at 340 degrees? When I replaced the control board 3 years ago, I did not "calibrate" the new control board for oven size as described in the oven's technical pamphlet. I actually just saw that requirement today for the first time. I tried to perform the calibration as described but could not get it to work. Is there a chance that the board thinks my 30 inch ovens are a different size and that is the cause of the disparity between the actual oven temperature and the displayed temperature? Do I maybe need to replace the control panel again? Is this all maybe just a quirk of these KitchenAid ovens and an annoyance we have to account for and live with? Thanks in advance for any help provided.
Related Models
Whirlpool KEBC207KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION-UPPER SELF-CLEAN
Whirlpool KEBC207KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC207KWH0 OVEN
Whirlpool KEBC207KWH02 30" BUILT-IN ELECTRIC THERMAL CONVECTION-UPPER
Whirlpool KEBC207KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION-UPPER SELF-CLEAN
Whirlpool KEBC207KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION-UPPER SELF-CLEAN
Whirlpool KEBC207KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC207KWH1 DOUBLE OVEN
Whirlpool KEBC208HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC208HBL1 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBL2 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBL4 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC208HBT1 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBT2 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HBT4 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC208HWH1 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HWH2 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HWH3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208HWH4 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC208KBL0 OVEN
Whirlpool KEBC208KBL02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBL03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBL1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KBS0 OVEN
Whirlpool KEBC208KBS1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KBT0 OVEN
Whirlpool KEBC208KBT02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBT03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KBT1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KBU1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KSS0 OVEN
Whirlpool KEBC208KSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KWH0 OVEN
Whirlpool KEBC208KWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC247KBL0 OVEN
Whirlpool KEBC247KBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH0 OVEN
Whirlpool KEBC247KWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247VBL00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC247VSS00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VSS02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC276KBL0 OVEN
Whirlpool KEBC276KBL02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KBL1 DOUBLE OVEN
Whirlpool KEBC276KSS03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH0 OVEN
Whirlpool KEBC276KWH02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH1 DOUBLE OVEN
Whirlpool KEBC277KBL0 OVEN
Whirlpool KEBC277KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBL1 DOUBLE OVEN
Whirlpool KEBC277KBT0 OVEN
Whirlpool KEBC277KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBT1 DOUBLE OVEN
Whirlpool KEBC277KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH0 OVEN
Whirlpool KEBC277KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH1 DOUBLE OVEN
Whirlpool KEBC278HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBL1 OVEN
Whirlpool KEBC278HBL2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBL3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBT1 OVEN
Whirlpool KEBC278HBT2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH0 BUILT-IN ELECTRIC OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
slow to heat crys Oven Repair (including Ranges and Cooktops) 0 12-05-2015 12:24 PM
kitchen aid oven slow to heat up dheist Oven Repair (including Ranges and Cooktops) 0 04-18-2011 01:14 PM
kitchen aid oven very slow to heat 1/2 hour or more gimmeluck Oven Repair (including Ranges and Cooktops) 0 10-11-2009 07:03 PM
heat very slow pierretoch Oven Repair (including Ranges and Cooktops) 0 05-03-2009 09:52 AM
Slow to heat yostkm@gmail.com Oven Repair (including Ranges and Cooktops) 1 02-27-2009 07:16 PM
