Discuss
Oven wont heat to temp
 in
My oven wont heat to temp. I bought an oven thermometer and set the oven at 400 and it will
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven wont heat to temp
  #1 (permalink)
Old 07-20-2007, 03:47 PM
rickm1959 rickm1959 is offline
Junior Member
rickm1959 is on a distinguished road
Default Oven wont heat to temp
Model Number: cgs365hq   Brand: Crosley   Age: 5 - 10 years
My oven wont heat to temp. I bought an oven thermometer and set the oven at 400 and it will only heat to 175. I am guessing that it is the oven ingiter?
thanks
Rick
Related Models
Whirlpool CGS365HQ0
Whirlpool CGS365HQ5
Whirlpool CGS365HQ6
Whirlpool CGS365HQ7
Whirlpool CGS365HQ8 30" Gas Freestanding Self Clean Range Sealed Burn
Whirlpool CGS365HZ0
Magic Chef CGS3760ADA Range - S/c S/i Gas
Magic Chef CGS3760ADB Range - S/c S/i Gas
Magic Chef CGS3760ADC Range - S/c S/i Gas
Magic Chef CGS3760ADQ Range - S/c S/i Gas
Magic Chef CGS3760ADW Range - S/c S/i Gas
Crosley CGS831GK Surface Unit - Gas
Whirlpool CGW2761AN0
Whirlpool CGW2761AN1
Whirlpool CGW2761AW0
Whirlpool CGW2761AW1
Whirlpool CGW2761EW0
Whirlpool CGW2791EW0
Crosley CGW2D2 Range - F/s Std Gas
Crosley CGW2D21 Range - F/s Std Gas
Crosley CGW2D2K Range - F/s Std Gas
Crosley CGW2D2K-1 Range - F/s Std Gas
Magic Chef CGW3330ADB Walloven - S/c Gas
Magic Chef CGW3330ADW Walloven - S/c Gas
Crosley CGW3C6CLVK Range - F/s Cont Clean Gas
Crosley CGW3C6CVK Range - F/s Std Gas
Crosley CGW3D1 Range - F/s Std Gas
Crosley CGW3D1K Range - F/s Std Gas
Crosley CGW3D1X Range - F/s Std Gas
Crosley CGW3D3WK Range - F/s Std Gas
Crosley CGW3D3X Range - F/s Std Gas
Crosley CGW3D5VK Range - F/s Std Gas
Crosley CGW3D5WK Range - F/s Std Gas
Crosley CGW3D5XK Range - F/s Std Gas
Crosley CGW3D6CLVK Range - F/s Cont Clean Gas
Crosley CGW3D6CSVK Range - F/s Std Gas
Crosley CGW3D6CSVK-1 Range - F/s Std Gas
Crosley CGW3D6CVK Range - F/s Std Gas
Crosley CGW4C58CZKW Range - S/c F/s Gas
Crosley CGW4D59EZK Range - S/c F/s Gas
Crosley CGW4D59TSK-1 Range - S/c F/s Gas
Crosley CGW4D59TSZK Range - S/c F/s Gas
Crosley CGW4D59TZK Range - S/c F/s Gas
Crosley CGW6C5GWK Range - F/s Std Gas
Crosley CGW6C5W Range - F/s Std Gas
Crosley CGW6C5WK Range - F/s Std Gas
Whirlpool CGX215VX0
Whirlpool CGX215VX1
Thermador CGX304UB
Thermador CGX304US
Thermador CGX304UW
Whirlpool CGX310VL0
Whirlpool CGX310VL1
Whirlpool CGX310VW0
Whirlpool CGX310VW1
Whirlpool CGX310VX0
Whirlpool CGX310VX1
Whirlpool CGX315VB0
Whirlpool CGX315VB1
Whirlpool CGX315VL0
Whirlpool CGX315VL1
Whirlpool CGX315VW0
Whirlpool CGX315VW1
Whirlpool CGX315VX0
Whirlpool CGX315VX1
Thermador CGX365UB
Thermador CGX365US
Thermador CGX365UW
Thermador CGX456UB
Thermador CGX456US
Thermador CGX456UW
Whirlpool CGX635VL0
Whirlpool CGX635VW0
Whirlpool CGX635VX0
Whirlpool CGX655VL0
Whirlpool CGX655VW0
Whirlpool CGX655VX0
Thermador CH30
Thermador CH36
Hardwick CH4-34A9 Surface Unit - Gas
Hardwick CH4-34B9 Surface Unit - Gas
Hardwick CH4-34W9 Surface Unit - Gas
Hardwick CH4-34Y9 Surface Unit - Gas
Hardwick CH4-44A9 Surface Unit - Gas
Hardwick CH4-44B9 Surface Unit - Gas
Hardwick CH4-44W9 Surface Unit - Gas
Hardwick CH4-44Y9 Surface Unit - Gas
Hardwick CH7241819R Walloven - Cont Clean Gas
Hardwick CH9616A79R Range - F/s Std Gas
Hardwick CH9616W79R Range - F/s Std Gas
Hardwick CH9626A79R Range - F/s Std Gas
Hardwick CH9626W79R Range - F/s Std Gas
Whirlpool CHA1300W0
Whirlpool CHCH8AE
Whirlpool CHCH8AS
Whirlpool CHCH8WE
Whirlpool CHCH8WS
Whirlpool CHCS51AE
Whirlpool CHCS51AE1
Whirlpool CHCS51AE2
Thermador CHCV30
Thermador CHCV36
Whirlpool CHE12RC
Whirlpool CHE12RC1
Whirlpool CHE12RS
Whirlpool CHE12RS1
Whirlpool CHE5A
Whirlpool CHE5A2
Whirlpool CHE5R
Whirlpool CHE5W
Whirlpool CHE5W2
Whirlpool CHE7R
Whirlpool CHE7RC
Whirlpool CHE7RS
Maytag CHE9000ACB Range - S/c S/i Ele
Maytag CHE9000BCB Range - S/c S/i Ele
Maytag CHE9000BCE Range - S/c S/i Ele
Maytag CHE9800ACB Range - S/c S/i Ele
Maytag CHE9800ACE Range - S/c S/i Ele
Maytag CHE9800BCB Range - S/c S/i Ele
  #2 (permalink)
Old 07-24-2007, 04:52 PM
Adam / APP Team Adam / APP Team is offline
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
Dear rickm1959,
It seems your model number was missing a number at the end. The complete model number on those are usually located toward the bottom, behind the drawer, on the body on the left hand side.
It will be on a metallic sticker that says model and serial number.
In most cases it does have to do with the igniter. If the igniter doesn't get hot enough it wont open the valve
The only way to test it properly is by taking an amp draw reading to see if it is reaching what is indicated on the valve.
That is if it has that type of ignition and not using the spark module as used on these later models.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat up at all. acillatem Oven Repair (including Ranges and Cooktops) 27 07-27-2007 12:32 AM
