Discuss
Range not lighting
 in
Hi all, My first time here. Electronic ignition. 4 ranges on top. Oven on bottom. Everything works but here's the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Range not lighting
  #1 (permalink)
Old 05-23-2017, 05:28 PM
Junior Member
Fisher Man Sam is on a distinguished road
Default Range not lighting
Model Number: 790.74333310   Brand: Kenmore   Age: 1 - 5 years
Hi all,
My first time here.
4 ranges on top.
Oven on bottom.
Everything works but here's the problem.
Front burner on the right sparks (I can hear and see the spark).
Getting gas because I can smell it.
No flame.
Won't light.
Now here's the weird thing.
If I strike a match it lights.
Doesn't add up.
Getting spark getting gas it should light right?
But it doesn't
What am I missing?
Thank you in advance.
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 05-23-2017, 07:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello, Sam.
Make sure the burner cap is in place and all burner parts are dry. Verify it and give it a try.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-24-2017, 03:56 AM
Junior Member
Default
Hello Gene.
Thank you for your answer.
Wetness issue was the first thing I suspected.
Not wet.
Made sure of that.
Cap is on correctly as well.
If it was a car (with a timing belt) it would be easy.
Getting gas???
Getting spark???
Won't start???
Replace the belt.
Just used it 20 minutes ago to boil water for coffee.
Didn't light on it's own, but lit with a match.
This is nuts.
What's being missed here???
Again thank you Gene.
  #4 (permalink)
Old 05-24-2017, 06:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
Next step is to remove the burner cap and the burner (secured with two screws). Then carefully inspect the ignition electrode for any cracks or other damage. If there are any, the electrode would need to be replaced. Make sure the electrode is clean and there is no grease on it or around. Also, inspect the wire connected to the electrode for any insulation damage.
If there is nothing wrong with the electrode and harness, very likely the spark module is the culprit.
The ignition electrode (igniter) Part number: AP2123862
The spark module Part number: AP6041423
P.S. Possible you would need to remove all burners and the top panel for good inspection and to get access to the spark module.
__________________
  #5 (permalink)
Old 05-25-2017, 04:35 AM
Junior Member
Default
Hi Gene,
Thank you my friend.
With all due respect to you and you skills.
Don’t think this is a “Spark Issue”.
Tell you why.
Did an experiment last night.
Experiment went like this.
Wanted to physically see the amount of spark going to all the burners.
Wanted to compare the spark at each burner to see they were the same and even.
Shut off the gas going to the oven.
Waited till nighttime.
Shut off all the lights in the house as well.
Turned on all the burners.
House was good and dark.
Was easy to see that the AMOUNT of spark at ALL the burners was EVEN and the SAME.
I have precision drill bits.
I’m an “ASE Certified Master Auto Mechanic”.
I’m a decorated “Marine Scout Sniper” as well, so I have an analytical mind.
As you well know there’s a small hole in the burner head for the gas to pass through, so it can reach the spark from the igniter.
I intend end to ever so slightly enlarge that hole.
Goal here is to increase the “Volume Of Gas” reaching the igniter.
Will do that over this weekend.
Will post back with the results.
Again thank you sir.
Enjoy the weekend.
  #6 (permalink)
Old 05-26-2017, 06:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
It could be a good idea.
Good luck.
__________________
  #7 (permalink)
Old 05-27-2017, 04:25 AM
Junior Member
Default
Hello Gene,
Well I was right.
Not a spark issue.
Was a “Gas Volume” issue.
Enlarging the hole in the burner head increased the volume of gas reaching the igniter and now the burner lights normally.
Glad I did this experiment.
Happy the oven is working normally.
What really makes me happy is helping you.
In other words:
Use my experiment Gene. It will save you a misdiagnoses and selling parts to people that they don’t need.
Thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range burners not lighting whereandrewgo@yahoo.com Oven Repair (including Ranges and Cooktops) 0 09-29-2011 10:57 AM
jen-air range not lighting up venustiano Oven Repair (including Ranges and Cooktops) 1 06-16-2011 06:11 PM
Gas range not lighting jaspergreen Oven Repair (including Ranges and Cooktops) 0 08-14-2010 01:31 PM
Range - Not lighting/clicking on any eye weinsjs Oven Repair (including Ranges and Cooktops) 5 06-15-2010 04:11 PM
Gas range not lighting Nashville1967 Oven Repair (including Ranges and Cooktops) 0 01-03-2010 11:55 AM
