Discuss
just bake and broil elements not heating
 in
I'm at a loss. All components are working on oven except bake and broil. I have reset breaker, unplugged and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » just bake and broil elements not heating
  #1 (permalink)
Old 05-23-2017, 12:18 PM
Junior Member
mackie6399 is on a distinguished road
Default just bake and broil elements not heating
Model Number: ffes3015lwa   Brand: Frigidaire   Age: 5 - 10 years
I'm at a loss. All components are working on oven except bake and broil. I have reset breaker, unplugged and checked for fuse. This model does not have one I believe. clock has not worked for several months. It comes on for time set once breaker reset but goes off once time set. This never stopped oven from working before. No warning signs, worked last night then nada the next day.
Related Models
Frigidaire FFES3015LWA ELECTRIC RANGE
Frigidaire FFES3015LWB ELECTRIC RANGE
Frigidaire FFES3015LWC ELECTRIC RANGE
Frigidaire FFES3025LBA ELECTRIC RANGE
Frigidaire FFES3025LBB ELECTRIC RANGE
Frigidaire FFES3025LBC ELECTRIC RANGE
Frigidaire FFES3025LSA ELECTRIC RANGE
Frigidaire FFES3025LSB ELECTRIC RANGE
Frigidaire FFES3025LSC ELECTRIC RANGE
Frigidaire FFES3025LWA ELECTRIC RANGE
Frigidaire FFES3025LWB ELECTRIC RANGE
Frigidaire FFES3025LWC ELECTRIC RANGE
Frigidaire FFES3027LSA ELECTRIC RANGE
Frigidaire FFES3027LSC ELECTRIC RANGE
Frigidaire FFET2725LBA WALLOVEN
Frigidaire FFET2725LSA WALLOVEN
Frigidaire FFET2725LWA WALLOVEN
Frigidaire FFET3025LBA WALL OVEN
Frigidaire FFET3025LSA WALL OVEN
Frigidaire FFET3025LWA WALL OVEN
Frigidaire FFEW2425LSA WALLOVEN
Frigidaire FFEW2725LBA WALLOVEN
Frigidaire FFEW2725LBB WALLOVEN
Frigidaire FFEW2725LSA WALLOVEN
Frigidaire FFEW2725LSB WALLOVEN
Frigidaire FFEW2725LWA WALLOVEN
Frigidaire FFEW2725LWB WALLOVEN
Frigidaire FFEW3025LBA WALLOVEN
Frigidaire FFEW3025LSA WALLOVEN
Frigidaire FFEW3025LWA WALLOVEN
Frigidaire FFF318AWA Frigidaire/range
Frigidaire FFF335ESF ELECTRIC RANGE
Frigidaire FFF384HCA ELECTRIC RANGE
Frigidaire FFF384HCB ELECTRIC RANGE
Frigidaire FFFC04M1LW FREEZER
Frigidaire FFFC05M1LW FREEZER
Frigidaire FFFC05M2KW FREEZER
Frigidaire FFFC07M1LW FREEZER
Frigidaire FFFC07M2KW FREEZER
Frigidaire FFGC2605LWA COOKTOP
Frigidaire FFGC3005LWA COOKTOP
Frigidaire FFGC3015LBA COOKTOP
Frigidaire FFGC3015LBB COOKTOP
Frigidaire FFGC3015LSA COOKTOP
Frigidaire FFGC3015LSB COOKTOP
Frigidaire FFGC3015LWA COOKTOP
Frigidaire FFGC3015LWB COOKTOP
Frigidaire FFGC3025LBA COOKTOP
Frigidaire FFGC3025LBB COOKTOP
Frigidaire FFGC3025LSA COOKTOP
Frigidaire FFGC3025LSB COOKTOP
Frigidaire FFGC3025LWA COOKTOP
Frigidaire FFGC3025LWB COOKTOP
Frigidaire FFGC3603LWA COOKTOP
Frigidaire FFGC3613LBA GAS COOKTOP
Frigidaire FFGC3613LBB GAS COOKTOP
Frigidaire FFGC3613LSA GAS COOKTOP
Frigidaire FFGC3613LSB GAS COOKTOP
Frigidaire FFGC3613LWA GAS COOKTOP
Frigidaire FFGC3613LWB GAS COOKTOP
Frigidaire FFGC3625LBA COOKTOP
Frigidaire FFGC3625LBB COOKTOP
Frigidaire FFGC3625LSA COOKTOP
Frigidaire FFGC3625LSB COOKTOP
Frigidaire FFGC3625LWA COOKTOP
Frigidaire FFGC3625LWB COOKTOP
Frigidaire FFGF3000MWA GAS RANGE
Frigidaire FFGF3005MQA GAS RANGE
Frigidaire FFGF3005MWA GAS RANGE
Frigidaire FFGF3011LBA GAS RANGE
Frigidaire FFGF3011LBB GAS RANGE
Frigidaire FFGF3011LBC GAS RANGE
Frigidaire FFGF3011LWA GAS RANGE
Frigidaire FFGF3011LWB GAS RANGE
Frigidaire FFGF3011LWC GAS RANGE
Frigidaire FFGF3013LBA GAS RANGE
Frigidaire FFGF3013LBB GAS RANGE
Frigidaire FFGF3013LBC GAS RANGE
Frigidaire FFGF3013LBD GAS RANGE
Frigidaire FFGF3013LWA GAS RANGE
Frigidaire FFGF3013LWB GAS RANGE
Frigidaire FFGF3013LWC GAS RANGE
Frigidaire FFGF3013LWD GAS RANGE
Frigidaire FFGF3015LBA GAS RANGE
Frigidaire FFGF3015LBB GAS RANGE
Frigidaire FFGF3015LBC GAS RANGE
Frigidaire FFGF3015LBD GAS RANGE
Frigidaire FFGF3015LMA GAS RANGE
Frigidaire FFGF3015LMB GAS RANGE
Frigidaire FFGF3015LMC GAS RANGE
Frigidaire FFGF3015LMD GAS RANGE
Frigidaire FFGF3015LWA GAS RANGE
Frigidaire FFGF3015LWB GAS RANGE
Frigidaire FFGF3015LWC GAS RANGE
Frigidaire FFGF3015LWD GAS RANGE
Frigidaire FFGF3017LBA GAS RANGE
Frigidaire FFGF3017LBB GAS RANGE
Frigidaire FFGF3017LBC GAS RANGE
Frigidaire FFGF3017LBD GAS RANGE
Frigidaire FFGF3017LSB GAS RANGE
Frigidaire FFGF3017LSC GAS RANGE
Frigidaire FFGF3017LWA GAS RANGE
Frigidaire FFGF3017LWB GAS RANGE
Frigidaire FFGF3017LWC GAS RANGE
Frigidaire FFGF3017LWD GAS RANGE
Frigidaire FFGF3019LWA GAS RANGE
Frigidaire FFGF3019LWB GAS RANGE
Frigidaire FFGF3019LWC GAS RANGE
Frigidaire FFGF3019LWD GAS RANGE
Frigidaire FFGF3021LBA GAS RANGE
Frigidaire FFGF3021LBB GAS RANGE
Frigidaire FFGF3021LBC GAS RANGE
Frigidaire FFGF3021LWA GAS RANGE
Frigidaire FFGF3021LWB GAS RANGE
Frigidaire FFGF3021LWC GAS RANGE
Frigidaire FFGF3023LBA GAS RANGE
Frigidaire FFGF3023LBB GAS RANGE
Frigidaire FFGF3023LBC GAS RANGE
Frigidaire FFGF3023LMA GAS RANGE
Frigidaire FFGF3023LMB GAS RANGE
  #2 (permalink)
Old 05-23-2017, 10:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to the wiring diagram, there is the thermal circuit breaker. It is located under the top panel or on the back of the unit.
Check the thermostat for continuity. If it's open, the thermostat would need to be replaced. If it shows continuity, the EOC (clock/timer) would need to be replaced.
The range hi limit thermostat Part number: AP4587847
The EOC Part number: AP4552111
Here are the break down diagrams for the Frigidaire electric range Model FFES3015LWA
Good luck. Keep us posted.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven heating elements not working - also light doesn't turn on when bake/broil dial i rnelson Oven Repair (including Ranges and Cooktops) 0 06-07-2011 04:59 PM
Bake and broil elements not cycling in Bake Dante_M Oven Repair (including Ranges and Cooktops) 4 04-12-2011 09:04 PM
bake or broil elements don laansma Oven Repair (including Ranges and Cooktops) 3 05-29-2010 10:38 AM
bake or broil elements don laansma Oven Repair (including Ranges and Cooktops) 1 05-29-2010 04:08 AM
Bake & Broil elements stopped heating... MrsP111 Oven Repair (including Ranges and Cooktops) 1 10-25-2008 06:01 PM
