Discuss
Electrolux Range E - 15 Error
 in
I have an Electrolux slide-in Range/Oven combo. Model # EW30ES65GSE I had the ubiquitous E 15 error, which renders the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electrolux Range E - 15 Error
  #1 (permalink)
Old 05-22-2017, 12:37 PM
Junior Member
Jeff_P is on a distinguished road
Thumbs down Electrolux Range E - 15 Error
Model Number: EW30ES65GSE   Brand: Electrolux   Age: 1 - 5 years
I had the ubiquitous E 15 error, which renders the touch controls (and therefore the range and oven) entirely useless. I tried two things to resolve, per Electrolux customer service: 1. turn the circuit breaker to the stove and leave off for 10 minutes, then turn back on. If you are very lucky, this may be a one-time "false error" and you might be OK. 2. if you can get to the "user preference" option, try to reset the stove to factory default. Unlikely this will work, but worth a try.
In my case, neither worked, but if you can time it properly, between "beeps", sometime you may be able to turn a stove burner on, and then the E 15 may errors/beeping, may go away, but unfortunately just for a while, even when the burner is turned off.
If you are out of warranty, Electrolux customer service will advise you that you should have purchased an extended warranty, which is ridiculous considering how much this range costs initially.
Customer Service indicated there is no way to diagnose which part is bad, so they will sell you two different boards that will hopefully address the problem. These parts are a control board and a relay board. The control board is the digital pad that mounts in the front of the range, and the relay board mounts behind the rear cover, in the upper right. Parts numbers are: 316443916 and 316576612, respectively. After replacing BOTH parts, that seemed to fix it. Note - the Electrolux parts have a tremendous mark-up. You might be able to obtain these parts for less $ elsewhere - certainly worth a try.
There are literally hundreds of posting regarding this E 15 error, and it seems more "popular" in the inductive cook top model (mine is non-inductive). If the range is over 1 year old, forget about Electrolux standing behind their products. I firmly believe this is a manufacturing error (cheap boards) and Electrolux refuses to stand behind their products.
In my experience Bosch does a tremendous job in customer support, perhaps top in the industry and Electrolux is at the VERY BOTTOM. As consumers, we all have a choice on what to purchase, and based on this Electrolux experience, I WILL NEVER PURCHASE AN ELECTROLUX PRODUCT AGAIN.
Related Models
 EW30ES65GSE ELECTRIC RANGE
 EW30ES65GSF ELECTRIC RANGE
 EW30ES65GSG ELECTRIC RANGE
 EW30ES65GWA ELECTRIC RANGE
 EW30ES65GWB ELECTRIC RANGE
 EW30ES65GWC ELECTRIC RANGE
 EW30ES65GWD ELECTRIC RANGE
 EW30ES65GWE ELECTRIC RANGE
 EW30ES65GWF ELECTRIC RANGE
 EW30ES6CGB1 ELECTRIC RANGE
 EW30ES6CGB2 ELECTRIC RANGE
 EW30ES6CGS1 ELECTRIC RANGE
 EW30ES6CGS2 ELECTRIC RANGE
 EW30ES6CGS3 ELECTRIC RANGE
 EW30ES6CGS4 ELECTRIC RANGE
 EW30ES6CGS5 ELECTRIC RANGE
 EW30ES6CGS6 ELECTRIC RANGE
 EW30ES6CGS7 ELECTRIC RANGE
 EW30ES6CGW1 ELECTRIC RANGE
 EW30ES6CGW2 ELECTRIC RANGE
 EW30EW55GB1 WALL OVEN
 EW30EW55GB2 WALL OVEN
 EW30EW55GB3 WALL OVEN
 EW30EW55GB4 WALL OVEN
 EW30EW55GB5 WALL OVEN
 EW30EW55GB6 WALL OVEN
 EW30EW55GS1 WALL OVEN
 EW30EW55GS2 WALL OVEN
 EW30EW55GS3 WALL OVEN
 EW30EW55GS4 WALL OVEN
 EW30EW55GS5 WALL OVEN
 EW30EW55GS6 WALL OVEN
 EW30EW55GS7 WALL OVEN
 EW30EW55GW1 WALL OVEN
 EW30EW55GW2 WALL OVEN
 EW30EW55GW3 WALL OVEN
 EW30EW55GW4 WALL OVEN
 EW30EW55GW5 WALL OVEN
 EW30EW55GW6 WALL OVEN
 EW30EW5CGB1 WALL OVEN
 EW30EW5CGB3 WALL OVEN
 EW30EW5CGB4 WALL OVEN
 EW30EW5CGS1 WALL OVEN
 EW30EW5CGS2 WALL OVEN
 EW30EW5CGS3 WALL OVEN
 EW30EW5CGS6 WALL OVEN
 EW30EW5CGS7 WALL OVEN
 EW30EW5CGW1 WALL OVEN
 EW30EW5CGW3 WALL OVEN
 EW30EW5CGW4 WALL OVEN
 EW30EW65GB1 WALL OVEN
 EW30EW65GB2 WALL OVEN
 EW30EW65GB3 WALL OVEN
 EW30EW65GB4 WALL OVEN
 EW30EW65GB5 WALL OVEN
 EW30EW65GB6 WALL OVEN
 EW30EW65GB7 WALL OVEN
 EW30EW65GS1 WALL OVEN
 EW30EW65GS2 WALL OVEN
 EW30EW65GS3 WALL OVEN
 EW30EW65GS4 WALL OVEN
 EW30EW65GS5 WALL OVEN
 EW30EW65GS6 WALL OVEN
 EW30EW65GS7 WALL OVEN
 EW30EW65GS8 ELECTROLUX/WALL OVEN
 EW30EW65GW1 WALL OVEN
 EW30EW65GW2 WALL OVEN
 EW30EW65GW3 WALL OVEN
 EW30EW65GW4 WALL OVEN
 EW30EW65GW5 WALL OVEN
 EW30EW65GW6 WALL OVEN
 EW30EW65GW7 WALL OVEN
 EW30EW6CGB1 WALL OVEN
 EW30EW6CGB3 WALL OVEN
 EW30EW6CGS3 WALL OVEN
 EW30EW6CGS4 WALL OVEN
 EW30EW6CGS5 WALL OVEN
 EW30EW6CGS6 WALL OVEN
 EW30EW6CGS7 WALL OVEN
 EW30EW6CGS8 WALL OVEN
 EW30EW6CGW1 WALL OVEN
 EW30EW6CGW3 WALL OVEN
 EW30GC55GB1 COOKTOP
 EW30GC55GB2 COOKTOP
 EW30GC55GS1 COOKTOP
 EW30GC55GS2 COOKTOP
 EW30GC55GW1 COOKTOP
 EW30GC55GW2 COOKTOP
 EW30GC60IS1 COOKTOP
 EW30GC60IS2 COOKTOP
 EW30GF65GBA GAS RANGE
 EW30GF65GBB GAS RANGE
 EW30GF65GBC GAS RANGE
 EW30GF65GBD GAS RANGE
 EW30GF65GBE GAS RANGE
 EW30GF65GSA GAS RANGE
 EW30GF65GSB GAS RANGE
 EW30GF65GSC GAS RANGE
 EW30GF65GSD GAS RANGE
 EW30GF65GSE GAS RANGE
 EW30GF65GSF GAS RANGE
 EW30GF65GSG GAS RANGE
 EW30GF65GSH GAS RANGE
 EW30GF65GSJ GAS RANGE
 EW30GF65GSK GAS RANGE
 EW30GF65GWA GAS RANGE
 EW30GF65GWB GAS RANGE
 EW30GF65GWC GAS RANGE
 EW30GF65GWD GAS RANGE
 EW30GF65GWE GAS RANGE
 EW30GS65GB1 GAS RANGE
 EW30GS65GB2 GAS RANGE
 EW30GS65GB5 GAS RANGE
 EW30GS65GB6 GAS RANGE
 EW30GS65GB7 GAS RANGE
 EW30GS65GB8 GAS RANGE
 EW30GS65GB9 GAS RANGE
 EW30GS65GS1 GAS RANGE
 EW30GS65GS2 GAS RANGE
 EW30GS65GS3 GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux Range Error code 15 Robert Roney Oven Repair (including Ranges and Cooktops) 24 06-21-2017 03:52 PM
Electrolux Slide in Range error code korniemd Oven Repair (including Ranges and Cooktops) 4 04-09-2017 02:05 AM
Electrolux error code E59 margo_r2009 Washer Repair 0 12-26-2015 09:42 PM
Electrolux Error Code 03-THIS FIXES IT! Whitney1210 Dishwasher Repair 0 06-25-2015 04:18 PM
Electrolux error code 737joe Dishwasher Repair 3 12-04-2012 05:04 PM
